oompa_loompa Samba Member
Posted: Wed Oct 11, 2006 10:08 pm Post subject: Tricky wipers |
I just want to know if there's something odd you have to do in order to remove the windshield wiper arms on a 71 bus? I removed the bolts on top but they still seems firmly attached. I assume they are just stuck due to time but I didn't want to tear something up if there's something else to do. Thanks! _________________ 1971 Bus
1915cc
94 bore 40x35.5mm heads
Dual Weber IDF 44
SVDA |
robgohome Samba Member
Posted: Wed Oct 11, 2006 10:11 pm Post subject: |
They may be kept on by the pressure of the wiper against the window. Flip the wipers up and try to gently ease them off. |
Posted: Wed Oct 11, 2006 10:12 pm Post subject: |
Okay, thanks! _________________ 1971 Bus
1915cc
Dual Weber IDF 44
SVDA |
innocenti Samba Member
Joined: June 30, 2004 Posts: 136 Location: bristol uk
Posted: Thu Oct 12, 2006 1:29 pm Post subject: Re: Tricky wipers |
oompa_loompa wrote: |
I just want to know if there's something odd you have to do in order to remove the windshield wiper arms on a 71 bus? I removed the bolts on top but they still seems firmly attached. I assume they are just stuck due to time but I didn't want to tear something up if there's something else to do. Thanks! |
hi just a little to add on wiper problem . they are on a splined taper , so the nut holds them firm as in previous posters reply just need a little gentle persuasion to break taper free. hope this is of help ... |
