74 Thing Samba Member
Posted: Thu Feb 08, 2018 7:32 am Post subject: Re: Comparison of BJ and 181 Spindles/Trailing Arms |
Help me understand.
What did you do to the front end or are you just showing Type 1 vs Type 181 trailing arm differences? |
mackaymanx Samba Member
Joined: October 12, 2006 Posts: 479 Location: Australia
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1773 Location: Finland, Jakobstad
Posted: Wed Dec 21, 2016 2:07 am Post subject: |
tripicana wrote: |
i used thing spindles with type1 trailing arms. i just swapped the lowers from side to side and pressed in the thing balljoints from the bottom.
this picture shows type 1 trailing arms on my beam.
I would not swap the trailingarms from one side to the other... The end where the balljoints are fitted is in an angle and becomes totally wrong if you flip them...
Only correct way to fit Thing balljoint is to do as Mackaymanx did. I've done just the same now too.
Ready to be fitted into my -66 beetle.
_________________ ~Kris~
The Hebster52
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
The Doppel -67, SOLD
The Singlecab -72, SOLD |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Fri Mar 02, 2012 8:33 am Post subject: |
Will Thing front backing plates bolt directly on 66-67 Type 1 front spindles? thx _________________ 1963 Ragtop Bug |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Sun Dec 14, 2008 9:08 pm Post subject: |
I just built an adjustable beam for my thing. I will be swapping to Ghia discs as well. Everything on the beam is stock Thing parts, including arms. I just installed ghia/bug balljoints into the thing arms, with the lower one flipped the right way. No problems at all. Should save anyone head aches if they are going this way as well. You can keep the beefier Thing arms. |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Sun Dec 14, 2008 10:54 am Post subject: |
Posted: Fri Oct 13, 2006 3:05 pm Post subject: |
Ian use what you can, I've read some conflicting reports on the trailing arms and decided to make some comparisons. I got a 2nd hand set for my manx off another buggy owner(Apoligies to the purists). From what i've been able to work out the top trailing arm are directly interchangable and the lower with a minor modification. _________________ [url=http://www.vw-mplate.com/mplate2-18600.png]Click to view image[/URL] |
ztnoo Samba Member
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Fri Oct 13, 2006 3:14 am Post subject: Comparison of BJ and 181 Spindles/Trailing Arms |
I have some comparison pics of the BJ and 181 lower trailing arm and spindles.
http://forums.aussieveedubbers.com/viewtopic.php?tid=56811
You can see the difference in offset of the spindles from the ball joint centrelines.
You can see how the centres of the balljoints are the same for the BJ and 181 spindles
Standard ball joints, you can see the limited surface area that the lower ball joint(top one in this photo) has to work on.
BJ and 181 lower trailing arms
181 trailing arm has thicker wall thickness, upper BJ trailing arm has same thickness as lower 181 arms
BJ, modified BJ and 181 ball joint socket in lower trailing arm.
This shows the difference in the shock absorber mounts, but the axis and centre line of the shock absorber remain the same. The 181 stud is longer and the boss machined back closer to the ball joint to accommodate the longer sleeve on the 181 shocks. The 181 stud has a larger thread.
I can see no difference in the geometry of the 181 and standard ball joint trailing arms. I have easily modified a lower bj lower trailing arm to accept a 181 ball joint. _________________ [url=http://www.vw-mplate.com/mplate2-18600.png]Click to view image[/URL]
