1621 Samba Member
Posted: Wed Oct 18, 2006 1:59 pm Post subject: Norcold... Is it really any better? |
I'm not that familiar with the Norcold refridgerators, and the search here didn't produce too much. For those of you who have made the change, is the Norcold much different from the stock Dometic? Also, which model did you use and what has the maintenance been like? Thanks for your replies in advance.
Lundy |
tds3pete Samba Member
Joined: April 04, 2004 Posts: 914 Location: Seattle, WA
Posted: Wed Oct 18, 2006 4:33 pm Post subject: |
I have the Norcold Model 3163 in my '95 Eurovan camper. It works like a champ.
The car has 120k and the PO used it to camp a lot, and never had a problem. I just returned from a one month cross country trip using it every day.
It will run a month steadily on one tank of propane, and it is so cold you have to watch out to avoid freezing the food.
I recommend it highly. I did have the factory 12v cooler in my '79 bay window which was not much of a unit ....big amp draw and not much poop.
Good luck _________________ '58 Westy camper-come and gone
'73 Westy-bought new in Holland,now gone
'86 Syncro weekender-come and gone
'79 Westy...Oscar
'95 Eurovan Camper/5 spd...Marsha Mellow |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Wed Oct 18, 2006 4:44 pm Post subject: |
I too am curious how the Norcold compares with the standard Westy 3-way (which normally keeps things about 40 degrees colder than ambient temperature). |
Terry Kay Banned
Posted: Wed Oct 18, 2006 10:02 pm Post subject: |
I don't have a Norcold in my Westy, but I do in my Sportsmobile, and can say this.
The difference in keeping food / drinks ice cold is like night and day.
The Norcold actually has a refrigerant compressor, which in turn will make ice and keep ice cream rock hard in the freezer compartment.
The smaller model for the Westfalia is also just an AC /DC unit.
I haven't ever seen or heard of a 3 way Norcold including gas running.
In my opinion the Norcold is a much more efficiant refrigerator than the ammonia heat transfer Dometic 3 way unit.
It actually works just as your household unit would, and very well at that.
I'll have to do some research on which model fit's into the Vanagon Westy--I do know there is one-- _________________ T.K. |
Terry Kay Banned
Posted: Wed Oct 18, 2006 10:14 pm Post subject: |
The Norcold Model that will fit into a Westfalia is a DC0040
It's a two way--AC/DC box. _________________ T.K. |
1621 Samba Member
Posted: Wed Oct 18, 2006 11:21 pm Post subject: |
I'll check them out later. So do I understand you correctly that there are no 3-way versions to fit the Westy?
Lundy |
wolfej1 Samba Member
Joined: August 15, 2005 Posts: 679 Location: North Royalton, Ohio
Posted: Thu Oct 19, 2006 5:22 am Post subject: |
It's a two way--AC/DC box. |
I was considering this unit. Since it cools so well, I wonder if it could be used intermittently on DC with a good deep cycle aux battery. Just for those times when there was no AC available, but you are parked.
Lets say you are driving and the fridge is ice cold. Then you stop for the night at a rest stop. Let the fridge continue to run for a few hours on DC then turn off before bed. Get up in the morning turn back on and hit the road. Would the fridge stay cold enough for the 8 hours that it was off?
If this worked, then the fact that there is no propane might not be as big a factor. However, for those folks who are on extended stays away from AC, it is still probably a no go. |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Thu Oct 19, 2006 7:37 am Post subject: |
Anyone have a link to a supplier of these units |
Terry Kay Banned
Posted: Thu Oct 19, 2006 9:17 am Post subject: |
Let your finger's do the walking---
Do a web search for Norcold.
There are 41,637 places to look and read about them.
I think Camper's World sells them.
They do have a gas model too---
But--it's back to the low performance coolng through absobtion process.
Not much better than what you have.
The AC / DC refrigerator works very well, and puts the Dometic to shame. _________________ T.K. |
gears Samba Member
Posted: Thu Oct 19, 2006 10:33 am Post subject: |
Yeah... it's just that battery power doesn't last long enough (and it's nice to be able to go camping without a separate generator). |
Terry Kay Banned
Posted: Thu Oct 19, 2006 11:02 am Post subject: |
No,
It's just that you don't have the correct battery capacity to handle the draw.
There are several places to mount a decent sized house battery besides the whimpy, lame battery box under the driver's seat. _________________ T.K. |
Posted: Thu Oct 19, 2006 2:31 pm Post subject: |
The Norcold 3-way unit in my Eurovan is Model 3163G.
I don't know if it will fit in a Westy. Operating on propane is definately it's strong suit. Runs 30 days on 5 gallons and easily freezes if not careful.
Doing the dance on 12v by turning it off at night will work, but sooner or later you will forget and leave it on for a day and oops...dead battery.
Propane is the way to go. _________________ '58 Westy camper-come and gone
'79 Westy...Oscar
gears Samba Member
Posted: Thu Oct 19, 2006 2:58 pm Post subject: |
Pete, do you have experience with the original Westy 3-way Dometic? |
vansmack Samba Member
Joined: February 09, 2006 Posts: 18 Location: GR Michigan
Posted: Thu Oct 19, 2006 3:20 pm Post subject: |
Check out www.rvmobile.com. They sell both Dometic and Norcold units. After a couple simple upgrades to my Dometic (new fan & air valve), the sucker works much better and stays very cold. Also, I think it would stink not being able to use propane. Its all I ever use to run the fridge. Too bad Norcold doesn't make a three way to fit the westy! _________________ Cheers,
Tim
______________
'86 Westy
'03 Passat Wagon Turbo
'03 Ford F150 4x4
'91 Volvo 740 Turbo SOLD
'79 Ford F150 Ranger SOLD |
Posted: Thu Oct 19, 2006 4:46 pm Post subject: |
Gears-
No I don't. We removed the 12v unit in the '79 Westy and replaced it with a stock cooler to gain the extra space taken up by the fridge mechanics. That fridge was too weak and drew too much power.
My synchro was not a Westy, so no fridge experience there.
The Norcold in the Euro was modified by the PO to increase circulation with three holes in the face trim. I now have to run it below at medium or lower to avoid freezing! _________________ '58 Westy camper-come and gone
'79 Westy...Oscar
Tomswesty Samba Member
Joined: July 06, 2005 Posts: 194 Location: Moscow, ID
Posted: Fri Oct 20, 2006 6:27 am Post subject: |
Here is my Norcold and it is cold compared to the old westy frig. This is the DC0040 1.7 cuft model that I got off Ebay for $350. The other is in the garage where it belongs. The second battery will run it for a couple of days without have to recharge but I do have a solar trickel charger that keeps the battery up. |
1621 Samba Member
Posted: Sat Oct 21, 2006 12:26 pm Post subject: |
Tomswesty wrote: |
Interesting set-up with the microwave as well. It looks very clean. I'm not certain of the Dometic's size (cubic capacity), but it looks like the Norcold model pictured is smaller. Are my eyes deceiving me, or does it actually compare favorably to the Dometic?
Lundy |
Posted: Sun Oct 22, 2006 9:31 am Post subject: |
It actually is about the same, maybe a little smaller. The main thing is that it keeps things cold something the Dometic has a problem doing well. |
1621 Samba Member
Posted: Sun Oct 22, 2006 9:33 am Post subject: |
Tomswesty wrote: |
Excellent point, thanks for showing us your set-up.
Lundy |
wbx Samba Member
Joined: April 11, 2005 Posts: 1254 Location: Monterey, CA
Posted: Sun Oct 22, 2006 11:54 am Post subject: |
Tomswesty wrote: |
Here is my Norcold and it is cold compared to the old westy frig. This is the DC0040 1.7 cuft model that I got off Ebay for $350. |
That's pretty cool, and looks good, too! I think my "hot setup" seeing this would be to mount the fridge so the top is flush, and the spacer is down below, but then see if i could fit a propex heater in the bottom there... 2 days of continuous use via battery would be plenty for me.
-Damon _________________ '84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go. |
