llovette Samba Member
Joined: March 07, 2002 Posts: 377 Location: north of Philly
Posted: Sat Dec 26, 2009 4:25 pm Post subject: |
I would also like to know if this will do the job. I need to do my RGBs. Seems inexpensive!! |
guatebus Samba Member
Joined: May 12, 2003 Posts: 392 Location: Oakland, CA
Posted: Sun Dec 27, 2009 9:18 am Post subject: |
At first, I couldn't figure out how this puller was supposed to work, but yesterday I found these images from the Draper catalog.
The puller itself:
It has little semi-spherical balls on tips that screw into the puller arms. You're supposed to drill out the cage that holds the balls in the bearing, insert the puller tips, and rotate 90 degrees:
Then you just pull off the bearing:
I've never done an RGB rebuild before, but it seems that this puller should work. It doesn't look super strong and I get the feeling that Draper is the Harbor Freight of the UK, but unless the bearings are really frozen in place it seems like it could theoretically work. _________________ '64 standard microbus
'69 deluxe microbus |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4916 Location: Southern AB
mightymouse Samba Member
Posted: Sun Dec 27, 2009 4:51 pm Post subject: |
ahhh one of my fav threads. Thanks again for the info. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
Posted: Sun Dec 26, 2010 3:41 pm Post subject: |
Picked these up today:
They're Rillex 6304 pullers, designed for a slightly smaller bearing than the rest of the pullers in this thread. According to the bearing reference, the only 6304 bearing in use on a VW is the drive shaft front bearing on old split-case transaxles.
I was curious how this puller compares to the other Rillex 6306 puller. Is the central threaded puller part the same? Are the 6306 collets usable on this puller?
These ones seem to fit OK on a 6305 bearing I had laying around. Not sure if they'll fit on a 6306, which is even bigger. _________________ '64 standard microbus
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Sun Dec 26, 2010 8:25 pm Post subject: |
I got the Baum tools type puller from Sir tools.
Not happy with the service, it took almost a year to get everything right, so I won't link to them.
The puller kit, however works just fine.
Another one I researched was the Simatec Simatool BP-61 puller kit.
If anyone knows where to find this and at what price, the kit looks good, so please let us know. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
turkis-deluxe Samba Security
Posted: Sun Dec 26, 2010 9:33 pm Post subject: |
guatebus wrote: |
These ones seem to fit OK on a 6305 bearing I had laying around. Not sure if they'll fit on a 6306, which is even bigger. |
Were those the ones off CL today? If so I tried to get them and they poster wouldn't answer back. Looks nice and good score!! |
sventinker Samba Member
Joined: June 10, 2009 Posts: 1481 Location: the sandbox
Posted: Sun Dec 26, 2010 10:58 pm Post subject: |
guatebus wrote: |
I have two 6306 pullers. I do not know if the threaded shafts are the same as yours,it appears so. my 6306 puller is much longer, possibly double. no the 6306 collet will not work on the smaller 6304 puller. I would not recommend interchanging them each collet is made to fit inside the outer race fully. While doing this it holds the puller arms on the inner race. by using the 6304 puller on a 6305 bearing you run the risk of bending the tips as the 6304 collet won't slide far enough to cover the tip ends fully. good luck with your new find. I am looking for another 6306 collet and a broken 6306 puller to steal a few arms to fix another puller if you happen to find one on CL
Also if the puller in the rear of the pic was the one you used on the 6305 bearing it looks like it bent the heck out of it the arms should be straight no bent. and the arms fit between each bearing. larger bearings have more balls. My 6306 pullers have 8 arms. so if you try and pull a 6306 with that puller it will ruin the puller. when installed the collet sits up against the bearing with the thinner lip tucked inside the bearing if out you can bend the tips. _________________ April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote: |
Perfection only comes with delusion. |
http://www.oacdp.org/ |
Posted: Mon Dec 27, 2010 9:11 am Post subject: |
Thanks for the info...I did pick these up on CL the other day.
The puller in the back was bent when I got it...I suppose that's why it fit into the 6305 bearing I had. The unbent one doesn't fit.
Now that you mention that the 6306 puller has 8 arms I can see that this puller I have would never work on that bearing. It only has 7 arms. I suppose that a 6306 bearing has 8 balls and the 6305 and 6304 bearings only have 7 balls.
Interesting that each puller only really works on one kind of bearing. _________________ '64 standard microbus
BarryL Samba Member
Joined: November 01, 2004 Posts: 14255 Location: Casa de Oro, California
Posted: Mon Dec 27, 2010 10:45 am Post subject: |
Ones I've seen at transmission shops for pulling stub axle bearings are long enough to fit over the long splined part, too. |
Posted: Mon Dec 27, 2010 12:22 pm Post subject: |
BarryL wrote: |
mine are the long ones. I will never let them go. too damm hard to obtain. _________________ April 3rd 62 standard mgr/pw
Includes 6 popouts
025 Safety belts
dawerks wrote: |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Mon Dec 27, 2010 2:23 pm Post subject: |
guatebus wrote: |
Interesting that each puller only really works on one kind of bearing. |
don't give up - you will eventially find one....I watched e-bay for a year and would bid on several and never get them - then low and behold a couple of months ago i saw a man with 3 of them in atlanta with no reserve.......I won two of them one for the 6306 bearing and one for the 6305....I helped a friend of mine pull his stub axle bearing off two weeks ago.... it was effortless. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
EverettB Administrator
Joined: April 11, 2000 Posts: 69801 Location: Phoenix Metro
Posted: Mon Dec 27, 2010 4:58 pm Post subject: |
Flipseat wrote: |
Another puller... just for reference. Made by Krebsfer. This thing is a monster. It pulls on both the inner and outer races. 8 arms.
This puppy in action:
My friend's mint puller:
My puller I got off eBay for cheap (removed a couple arms as the tips are broken):
_________________ How to Post Photos
Tim MacDonald Samba Member
Joined: October 11, 2004 Posts: 1346 Location: Edmonton alberta
Posted: Sun Jan 02, 2011 9:49 am Post subject: |
Anybody have a puller they want to sell? _________________ 61 so34 flip seat
78 automatic champagne Westfalia
84 mint original paint westfalia
57 oval project barn find
88 cabriolet |
Posted: Sun Jan 02, 2011 6:02 pm Post subject: |
Tim MacDonald wrote: |
Anybody have a puller they want to sell? |
You can pry my puller kit from my cold dead hands. _________________ Founder and Chairman Emeritus, ECMSAS
Posted: Mon Jan 03, 2011 5:49 am Post subject: |
j.pickens wrote: |
You can pry my puller kit from my cold dead hands. |
OK sounds good.When would be a good time?LOL _________________ 61 so34 flip seat
88 cabriolet |
Snoop Bob Samba Member
Posted: Mon Jan 03, 2011 6:37 pm Post subject: |
j.pickens wrote: |
What was the part number? Was it the 1089?
BTW here is the US distributor info for Simatec listed on their site
Mr. Marcel Neuray
13900-C South Lakes Drive
Charlotte, NC 28273
Tel.: (704) 588-3320
Fax: (704) 588-2112
Toll-Free: 1-888-SIMATEC (1-888-746-2832)
E-Mail:
[email protected]
[email protected]
Website:
WWW.SIMATEC-USA.COM _________________
BarryL wrote: |
Put your lips onto the little tit with the hole in it inside and make a good seal. You can suck and blow but with a little resistance. It gets better after it's wet. |
EverettB wrote: |
I would be interested in knowing the sizes of the various shafts. |
Posted: Mon Jan 03, 2011 7:02 pm Post subject: |
Snoop Bob wrote: |
j.pickens wrote: |
Mr. Marcel Neuray
Charlotte, NC 28273
Fax: (704) 588-2112
E-Mail:
[email protected]
[email protected]
Website:
WWW.SIMATEC-USA.COM |
Is this the 1?and will it do all the bearings in a small nut rgb?Any idea of a price?
http://www.simatec.com/us_en/products/simatool/simatool-dismounting-tools_BP61.asp?navid=21 _________________ 61 so34 flip seat
88 cabriolet |
Posted: Tue Jan 04, 2011 10:33 am Post subject: |
WOW just answered my question.I called a distributor for simatec tools and it is $740 for the BP61 kit. _________________ 61 so34 flip seat
88 cabriolet |
Posted: Tue Jan 04, 2011 9:41 pm Post subject: |
Yikes, $740 does sound steep, but damn, it looks like it would pull both the 7 and 8 ball bearings.
I'll check on my Sir Tools part number and get back.
I believe I spent around $450, and waited nearly a year to get it right.
The first set they sent had a thread mis-match between the inner and outer pieces. The threads were so tight, you couldn't get the assembly to do the job.
Edit:
The Sir Tools is a Model #242 Body (the outer sleeve with the extraction threaded rod)
With a 242-A gripper for the 8 ball bearing, and a 242-B gripper for the 7 ball.
It also includes a 245-5 extension sleeve for the lower outer bearing to fit over the stub axle. _________________ Founder and Chairman Emeritus, ECMSAS
