4c-ounce-jamboree Samba Member
Joined: November 07, 2005 Posts: 90 Location: philadelphia, pa
Posted: Sun Oct 29, 2006 7:17 pm Post subject: lining up and centering the clutch disc (edit- pp size too) |
just to be safe, im second guessing my work...
getting my 1914 ready to put in the bug. i bought it used with no clutch disc or pressure plate. today i bolted on a slightly used kennedy stage 2 pressure plate(with center ring for my early style throw out bearing) and a kush lok clutch disc underneath.
my method for centering the disc wasnt very scientific. i tightened the pressure plate just enough to put some pressure on the clutch disc. just enough pressure to hold the clutch disc in place but still be able to move it around. i eyeballed centering up the pressure plate ring, the center of the clutch disc, and the gland nut, then tightened down the presure plate.
it all looks very centered and ready for a trans shaft to slide right in. i just got that feeling that it was too easy and i must of overlooked something... something to do with the splines on the trans shaft, perhaps?
can anyone give me either some reassurance or direction?
thanks! _________________ 69 baja
Last edited by 4c-ounce-jamboree on Mon Oct 30, 2006 4:19 pm; edited 1 time in total |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Sun Oct 29, 2006 7:47 pm Post subject: |
The plastic tool is like $5. Buy one and take the guess work out of it. _________________ Glenn
Member #1009
#BlueSquare |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1851 Location: Grass Pants, Orygun
Posted: Sun Oct 29, 2006 8:32 pm Post subject: |
If you have an old junk transaxle laying around yank the output shaft and use that. I have been using one for 16 years now. Work great for pushing out wrist pins too. _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2020lbs with driver
7.76 @ 89.55mph 1/8 mile
12.34 and 108.10 mph 1/4 mile |
Posted: Sun Oct 29, 2006 8:50 pm Post subject: |
didnt know those tools existed. ill be ordering one in the morning.
while its on its way though...
if i can get my engine mounted the way it is now(via my eyeballin method), should that mean my clutch plate is in spec close enough to work correctly?
i guess what im asking here is if that tool is meant more for getting the trans shaft to fit, or is it more to get the clutch plate EXACTLY where its supposed to be in relation to the pressure plate?
i understand that it accomplishes both tasks, but can one assume that if one of those tasks is complete, than they both are? _________________ 69 baja |
Posted: Sun Oct 29, 2006 8:54 pm Post subject: |
ive installed engines where i didnt have the tool to line up the clutch plate properly. i managed to get it close and got the engine in with no bad side effects. however if you are off even by a little bit the engine wont go in...it will hang up on the last 2 inches or so. _________________ 67 bug x3
67 ghia
64 bug |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15280 Location: Deep in the 405
Posted: Mon Oct 30, 2006 9:00 am Post subject: |
You can try to install the engine and see if it will go. You either got it right and the engine bolts up, or the clutch is a little off center and the engine won't ever bolt up. Don't guess just buy the tool.
A stage II is way too much pressure plate for a 1915cc _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Mon Oct 30, 2006 4:18 pm Post subject: |
vwracerdave wrote: |
A stage II is way too much pressure plate for a 1915cc |
yeah, i was wondering about this. a couple of local bug guys seemed to think this set up would work for me with only a sore left leg as a result.
i figured id be able to tell pretty quickly after installing the motor if it was going to be overkill on my ole swing axle tranny, and if it was, id try a different combo.
will i have enough clutch for this motor with my stock 3 finger pressure plate and clutch disc? how about using the stock 3 finger pressure plate with the kush-lok disc(this is what im thinking of doing now)?
anyone wanna trade a stage 1 kep for my stage 2 kep?
if it matters... car is a baja(maybe a lil bit lighter than stock cuzza fiberglass kit), rear tires are 225/75 r15, and engine is probably around 85hp. _________________ 69 baja |
RIS Samba Member
Joined: December 18, 2003 Posts: 3043 Location: Youngstown, Ohio
Posted: Mon Oct 30, 2006 7:03 pm Post subject: |
RIS wrote: |
4c-ounce-jamboree wrote: |
rear tires are 225/75 r15, and engine is probably around 85hp. |
Stock pressure plate and kush-lok will handle that... |
even if my stock pressure plate is this one?...
i just went outside and grabbed my old pressure plate to give it a once over. its the same one as pictured above. found mention in an old post that it may be a 180mm plate. ill be doing some measuring and engine comparing in the morning.
how bout if i dont use the stage 2 or the above pressure plate and get a new pressure plate all together.
should i stick with a stock 200mm plate and save a couple bucks, or would it be worth it to step up to a kep stage 1? _________________ 69 baja |
volksfiend Samba Member
Joined: June 01, 2004 Posts: 283 Location: Mo....West of Mexico
Posted: Tue Oct 31, 2006 4:06 am Post subject: |
In a pinch you can use a socket to center the disk. Find a deep socket that fits tight in the gland bearing. Then wrap it with a little tape to make it fit snug in the clutch disc. Simple and effective centering tool. _________________
Chumley wrote: |
I just pissed me off |
Posted: Tue Oct 31, 2006 10:39 am Post subject: |
did some measuring, and that above pictured pressure plate has the same diameter and clutch disc surface area as the kep stage 2. i think it should work, but i think i might just spend the extra 50 clams and get a new stock pressure plate to be safe. _________________ 69 baja |
drrnsk8ter4 Samba Member
Joined: December 14, 2004 Posts: 340 Location: simi valley, ca
Posted: Tue Oct 31, 2006 5:26 pm Post subject: |
that pressure plate is just the old style, the new ones have the diaphragm look instead...they both should work fine _________________ (O\U|U/O)--->74 std bug... |
