miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sun Oct 29, 2006 9:22 pm Post subject: type 1 conversion (calling Jake) |
I'm crossing over!
Picked up a type IV 2.0L (GE005743 case)today for $100 complete today, and it's gonna need a rebuild. I plan on using one of Jake's kits, and converting it to upright cooling to go in my Beetle.
I'm just wondering what I need to order to complete the conversion, and I didn't want to just start buying stuff I don't need.
I already know I need the DTM conversion shroud, the conversion flywheel, new P+C's, a cam+lifters, exhaust and a gasket set, but beyond that, I don't really know. Budget is around $2600, any guidance is appreciated in advance. |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Mon Oct 30, 2006 1:29 am Post subject: |
good luck on thst budget. |
Oldkoot Samba Member
Posted: Mon Oct 30, 2006 1:58 am Post subject: |
Get the heads rebuilt (Headflow masters or Hoffman Automotive), a set of carbs(either 40 drla dells or webber 44idf), a set of manifolds, a type 1 alternator. Also check out the Shoptalk Forums website. Lots of info about type 4 conversions. Good luck with your project. _________________ Common sense is a myth. |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Mon Oct 30, 2006 6:57 am Post subject: |
If the engine is in good shape you can do the conversion for that budget..
BUT I'd do a minimum to the engine just to get it up to standard and go from there after its in the car..
I'd do rod bearings, rings and have the heads looked at by a specialist, if you listen to the latest 4th Dimension Radio show ou can take advantage of a GOOD deal on head work from Len Hoffman..
Listen to ALL the 4th Dimension shows to date, you'll benefit in amazing ways! _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
Posted: Mon Oct 30, 2006 12:08 pm Post subject: |
I'll look into getting the heads done, they looked pretty good though.
Quote: |
I'd do a minimum to the engine just to get it up to standard and go from there after its in the car. |
OK, so basically just do a stock rebuild, and upgrade from there. Sounds good to me. Since I'm in the market for pistons, I'd kind of like to go with the 96mm ones. I can just get the jugs bored out and get oversize gaskets, right? |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6029 Location: CONGERS, N.Y.
Posted: Mon Oct 30, 2006 9:58 pm Post subject: |
Hey I just saved you some money--you don't need a Flywheel conversion!! Just keep the Flywheel and clutch. AHHHHHHHHHHHH unless it is a 1700 914 engine then you need a VW T-4 flywheel, clutch and fit a T-1 pilot bearing in the flywheel.
But if it is a VW T-4 you don't need anything to bolt up, you got it.
As for your budget, doing the heads and doing some simple stuff like Jake said. You can do it. Things like carbs you can't include because you would have to get them to do a T-1 engine anyway.
Keep us informed, this will be a good low budget to track. A stock 1700 goes like a T-1 2.0 and your engine will be a tad above stock 1700 t-4.
Do listen to the Radio shows. Very interesting for any Air cooled guy. I loved the Carb show.
Joe _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Posted: Mon Oct 30, 2006 10:29 pm Post subject: |
Hmmm. Very interesting. I did a quick google search for type 4 flywheels and came up with this:http://www.tunacan.net/t4/tech/flywheel.htm
So apparently, if the vehicle I got the engine from was a VW, then I should be golden. The guy I bought it from said it came from a 'terrorist vehicle', and when I told him that sounds like a transporter he said 'yeah, that's the one.'
So basically, as long as I dont have the 228mm version I should be good to go. |
Posted: Mon Oct 30, 2006 10:31 pm Post subject: |
BTW, the engine will be fuel injected, so no, I won't need to buy carbs. |
Posted: Mon Oct 30, 2006 11:38 pm Post subject: |
The stock injection will not fit on the DTM. Carbs are the cheapest option. You can use fuel injection but it alone will blow your budget and then some. I think you need to do more research on the DTM. I would use your cylinders and pistons if they are in good shape and just put in a set if rings. That will save you a few bucks. Manifolds will cost about $65 and a set of 40 drla Dells will cost $375 from Ebay from a seller Alpha1750. He has a good rep from what I have heard. Keep looking around at shoptalkforums.com and the samba, there's alot of info to be had. _________________ Common sense is a myth. |
Posted: Tue Oct 31, 2006 6:42 am Post subject: |
I make the mods to your flywheel for 40 bucks, or sell one already modified and surfaced for 140.00
The stock EFI will not work with the DTM, as mentioned above- carbs are cheap! _________________ Jake Raby
Posted: Tue Oct 31, 2006 8:52 am Post subject: |
The 228 requires some pretty serious grindage in the bellhouse area... It will fit, BUT isn't worth the hassle in my opinion..
The other issue is the starter, the 228 requires a different starter than the standard TI or 210-215mm Bus flywheels do.. _________________ Jake Raby
tuna Samba Member
Joined: October 04, 2004 Posts: 475 Location: Fontana, SoCal, USA
Posted: Tue Oct 31, 2006 12:02 pm Post subject: |
To use a 228 flywheel/clutch in a Type 1 transaxle, attention has to be focused on the height of the pressure plate in relation to the bellhousing. The pressure plate is larger over a greater area, so it has a tendency to interfere with the sloping parts of the tranny's bellhousing. _________________ Click to view image
Type 4: Secrets Revealed
Tom's Type 4 Corner
EMPI Imp Homepage
1970 EMPI Imp
1969 Bug - 2056cc Type 4 powered Cal-Look'r |
Posted: Wed Nov 01, 2006 11:59 am Post subject: |
Oldkoot wrote: |
The stock injection will not fit on the DTM. Carbs are the cheapest option. You can use fuel injection but it alone will blow your budget and then some. |
I should have cleared that up a little. I won't be using the stock injection stuff, and I don't recommend keeping it even on a stock engine. I always hear from people that it's pretty unreliable, and I already have a V2.2 Megasquirt and a Techedge Wideband with data logging.
I think the stock jetronic system is responsible for burning a piston and breaking an oil ring on the engine I bought, the intake tubes don't even have clamps on them! It obviously had been run lean and detonated. Now I'm torn between boring the stock jugs for 96's, or just getting new 94mm P+C's.
Jake Raby wrote: |
carbs are cheap! |
True, but Megasquirt is cheaper!
I didn't pay more than $175 for the ECU, and everything else can be had @ the scrapyard for less than you think...if you know what I mean! |
