73kombi Banned
Joined: April 11, 2006 Posts: 1215 Location: ~The London Bridge, AZ~
Posted: Tue Oct 31, 2006 3:09 pm Post subject: Squeaking noises from the Front End! |
OK, so last week before I wrapped my heater ducts with insulation......I drove Bessie up to the Car Wash to wash her under belly. After leaving the car wash she was squeakin' like an alter boy with "father murphy" gettin' too close! ......I mean just getting in and out, the front end would make noise. (she was quiet b 4)
Today I greased the shit outta the front end, (about 30~40 pumps with a hand gun) into each zert fitting.......the center fitting took only 20.......the top driver side fitting, actually pushed water outta the tube, but the noise is still there!
I drove for about 20 miles, tryin to hit "ALL" the bumps, and it is getting a bit better........but I am wondering.......is there some other place I need to lubricate to get the squeak to stop?
peace
p.s. thanks in advance if anyone has has this issue, and can steer me in the "NO SQUEAK" dirrection.......
on edit: Bessie~n~me~Moses do live on a dirt road......1 mile up from the highway |
atmellovw Samba Member
Joined: September 05, 2006 Posts: 1652 Location: Minnesota
Posted: Tue Oct 31, 2006 3:35 pm Post subject: |
Maybe you trapped a mouse or some other varmint in your heat ducts. |
zacaroo Samba Member
Joined: October 18, 2006 Posts: 80 Location: somewhere in arizona?
Posted: Tue Oct 31, 2006 4:33 pm Post subject: |
seems like it may be the suspension itself. its not happend to my bus but on my old toyota truck I had a similar squeak and found i had a squeaky spring, a hit with some wd40 every other month nips that in the butt. hope that helps. _________________ 1974 bus, blue/white |
Randy in Maine Samba Member
Posted: Tue Oct 31, 2006 4:43 pm Post subject: |
Really have to remove the weight off the front end to get the important parts to accept the grease where it counts.
Might also try spraying a little silicon or "tire dressing" in the rubber bushings of the shocks and steering stabilizer. |
dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
2 words...Ball Joints. Most are not greaseable. Take a hypodermic needle, fill it with trans fluid and inject it through the rubber ball joint boots. Once the noise goes away, few bounces should do it, inject grease into the same hole the needle made using a grease needle.
It happened on 2 of my busses.
Hope this helps
Dan
Last edited by dan macmillan on Tue Oct 31, 2006 7:23 pm; edited 1 time in total |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Oct 31, 2006 5:39 pm Post subject: |
A little slippery spray of some kind on the shock rubbers might help. |
VW_kaa_ohua_driver Samba Member
Posted: Tue Oct 31, 2006 8:58 pm Post subject: |
My bus, now in shop for body work, made that noise constantly. Sometimes the noise would go away for a while if the temperature changed appreciable but the sound seemed to be worse in the cold. I couldn't figure it out either! The ball joints idea sounds interesting... |
ChiTwnVW Samba Member
Joined: November 18, 2004 Posts: 1174 Location: Home. Sweat home.
Posted: Tue Oct 31, 2006 10:05 pm Post subject: |
dan macmillan wrote: |
Dan |
I don't have one of these lying around, where does one get one? |
73kombi Banned
Posted: Wed Nov 01, 2006 6:09 am Post subject: |
Randy in Maine wrote: |
Really have to remove the weight off the front end to get the important parts to accept the grease where it counts. |
This kinda makes sense.......the grease wasn't pushing out of the spring tube ends (bad terminology?) evenly. I will give that a try. I kinda figured driving it arround would push the grease into the squeak......and it may, after 1000 miles........(but it's driving me nuts) I really don't think it's the ball joints, as they appear in pretty good shape, but the hypodermic trick sounds interesting.......just don't want to add another issue!
peace, and thanks for the input!
p.s. it's only squeaking on the driver's side......but damn if I can issolate the noise! |
