EverettB Administrator
Joined: April 11, 2000 Posts: 69802 Location: Phoenix Metro
barndoormambo Samba Member
Joined: April 25, 2005 Posts: 443 Location: East Coast, Homeland
Posted: Sat Apr 03, 2010 12:44 am Post subject: |
bigbulli wrote: |
You can buy british army webbing straps on ebay, I think either '37 or' 44 issue are very close....nice work Tim! |
Thanks, Rich. I'm on the hunt _________________ ....just cause you don't see it, doesn't mean it isn't there!.... |
bigbulli Samba Member
Joined: September 30, 2000 Posts: 575 Location: ENGLAND
Posted: Sat Apr 03, 2010 12:33 am Post subject: |
You can buy british army webbing straps on ebay, I think either '37 or' 44 issue are very close....nice work Tim! _________________ 1954 Barndoor
1955 Oval |
Posted: Thu Apr 01, 2010 7:33 am Post subject: |
..first attempt done- not too bad-49" long..
Posted: Thu Apr 01, 2010 6:33 am Post subject: |
..my tray's not quite as shiney & black as yours , either..
Posted: Thu Apr 01, 2010 6:18 am Post subject: |
..looks just fine
- as my parts are dirt cheap, i'm gonna have a couple of goes- one folded, one cut , & see what i prefer..
-the Jute is VERY similar in weave to original..
- middle is a piece of my original, left is folded & sealed & right is cut with edge sealed; last one looks best , but is dependant on accurate cutting & has a border akin to a snail's trail in order to avoid the cut edge fraying..
..size comparisson- a reasonable match all round..
Rusting Hulk Samba Member
Joined: August 20, 2002 Posts: 646 Location: Malvern UK
Posted: Thu Apr 01, 2010 4:33 am Post subject: |
Here's what i did Tim, not great but looks ok when the wheels in...The belt i bought is slightly wider, i just hand stitched the two together
_________________ 64 356 C Coupe |
Posted: Thu Apr 01, 2010 4:08 am Post subject: |
ah. The webbing i've found is very similar, and seems the right colour.
The buckle is still in place , but the other side of the strap is decomposing..I'll re rivet a complete new strap to the tray, once i've worked out which 'system ' works best.. _________________ ....just cause you don't see it, doesn't mean it isn't there!.... |
Posted: Thu Apr 01, 2010 3:59 am Post subject: |
No end on mine Tim..its just cut to a point. I repaired mine using a belt from an army supplies stores, and used the original part i had left for the piece that is showing. _________________ 64 356 C Coupe |
Posted: Thu Apr 01, 2010 2:46 am Post subject: |
..Ok. I have a 'reasonable' modern equivalent. Natural Jute Webbing is very similar in texture & weave; however i can only find it in 2" widths.
Will post how i get on 'modifying' it
by the way- how did the strap end finish on 'late' BDs ?- a metal 'cap' of somesort, i pressume? _________________ ....just cause you don't see it, doesn't mean it isn't there!.... |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2922 Location: San Diego, CA
Posted: Tue Nov 14, 2006 12:01 pm Post subject: |
Stanagon wrote: |
According to the Eccles bus spec guide, the spare wheel strap changed to textile (previously leather) on 8.2.52 (Feb. 8, '52) at chassis 20 021 511. |
The very early straps I have seen were leather, the next generation were some sort of textile (cotton?). The bay window straps are nylon. |
Clara Samba Member
Posted: Tue Nov 14, 2006 7:37 am Post subject: |
June '53 standard, original strap buckle part attached to spare tire tray |
Stanagon Samba Member
Joined: July 11, 2003 Posts: 4186 Location: Boston, MA
Posted: Thu Nov 09, 2006 2:08 am Post subject: |
Thanks for the info, much appreciated _________________ 64 356 C Coupe |
uberwagen Samba Member
Posted: Wed Nov 08, 2006 4:54 pm Post subject: |
my strap measures 47" from the edge of the tire tray to the end. Annother 2" overlaps the tire tray where it is riveted.
...so 49" total. |
Posted: Tue Nov 07, 2006 4:42 pm Post subject: |
Here is a picture that shows it's length in reference to the tire tray
I can take an exact mesurement tomorrow.
Barndoor Mafia Il Capo
Joined: August 23, 2001 Posts: 6194 Location: EUSKAL HERRIA
Posted: Tue Nov 07, 2006 10:37 am Post subject: |
I used my FUBU belt to strap down my chromed 4-1/2!!! |
Posted: Tue Nov 07, 2006 1:52 am Post subject: |
uberwagen wrote: |
close-up of original strap and rivet detail from 54 a micro.
Could you tell me if your strap is all there? And if so how long it is. I have a piece of that stuff but not sure how long it should be.
Thanks everybody else for info. _________________ 64 356 C Coupe |
Posted: Mon Nov 06, 2006 9:42 pm Post subject: |
felix ehrhardt Samba Member
Posted: Mon Nov 06, 2006 2:27 pm Post subject: |
I have got a brown one in my 52 :
