240Gordy Samba Member
Joined: May 15, 2008 Posts: 2354 Location: Vancouver, BC
Posted: Thu Apr 01, 2010 9:41 am Post subject: |
where did you score those tires Baxta? local or from the internets?
Beauty !
Bet you were planning to show them off at the weekend get together? _________________ Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR |
Baxta Samba Member
Joined: November 09, 2008 Posts: 356 Location: Abbotsford, BC
Posted: Thu Apr 01, 2010 12:36 pm Post subject: |
240Gordy wrote: |
Beauty !
Bet you were planning to show them off at the weekend get together? |
Thanks! I'm looking forward to showing them off next week now.
The tires came from Tirerack.com - landed at $105/tire all in - I guess it helped that the border guard was motivationally challenged and waved us through last week! (GST + PST + Tire predisposal charges would have added another $75 or so to the bill...)
I'd like to get the big brakes on before the meet, but I'm looking for a later Vanagon (doesn't have to be Syncro) carrier to match up the bolt holes...
See ya next weekend! _________________ Greg
'87 Syncro Westy 'Bastian'
2.2l |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
evansdd3 Samba Member
Joined: May 11, 2005 Posts: 78 Location: Sooke, Vancouver Island
Posted: Sat Apr 03, 2010 9:35 pm Post subject: Optimum tire height... |
I'm looking for the right tires for my 82 diesel.
The stock NA diesel engine has been replaced with a 1.9 TD and it's much easier to drive now but the transmission must have been seriously low-geared in VW's stock diesel vans as even with nearly double the hp the engine is revving pretty high at 65mph (though I don't have a tach).
So here's what I'm thinking...Got some 15 Porsche Phone Dials with spacers and adaptors and have been considering tires about 215 wide and between 75 and 85 tall (215/75R15 or 215/80/15 or 215/85/15) in order to change my gearing a bit.
How high of a sidewall can I go in 2wd van without rubbing?
And will the 215 be too wide?
Whaddya think?
Thanks for your help, _________________ C'mon, gimme your 71 type 2...And throw in a dash clock. |
Vanagonner Samba Member
Joined: September 15, 2009 Posts: 506 Location: Broomfield Colorado
Posted: Mon Apr 05, 2010 8:49 pm Post subject: |
I'm looking at much larger tires to compensate for my "alpine" transaxle. I think +10% -+12% is possible, but I haven't done it yet. I'm looking for 18's.
I don't know if even that would be enough rpm drop to make a 1.9 happy. I think the above would be good enough for my 1.6 though. _________________ Sage
'82 Westy 1.6 D
the mighty n/a |
VisPacem Samba Member
Joined: July 15, 2007 Posts: 1143 Location: Las Vegas
Posted: Tue Apr 06, 2010 3:59 am Post subject: Re: Optimum tire height... |
evansdd3 wrote: |
Whaddya think?
Thanks for your help, |
I have 215-70-15 on Mercedes Wheels 15x7 ET25. No rubbing, no problems of any kind. No spacer (of course) going on two years with those wheels. I needed to change to rear wheel studs (OEM studs too short with those wheels). Got them at SmallCar.
Also make sure you have the correct lug nuts and/or bolts for the wheels you will be using. The scuttlebutt on the forum and in 99% of the cases, well lets say in 98 1/2%, they know what they are talking about, is that you are taking your life (and perhaps mine) into your own hands using the wrong lug nuts/bolts
_________________ LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons) |
SeattleDownhill Samba Member
Posted: Fri Apr 09, 2010 10:25 am Post subject: |
Many thanks to Loogy on getting this set up! I am beyond stoked on how it turned out... Next it needs more low... some paint, big brakes and a new motor... Can I borrow your STI Motor for a few years Loogy?
The setup: 17" porsche twists.. 17x7 front 17x9 rear ET55. 17mm spacers up front (soon to have another 6mm from big brake kit) 30mm rear spacers (to have an extra 4mm from big brake kit down the road) Clearance is tight, but once the brake kit is on there will be no issues. I still need to modify the door... It barely hits the rear wheel right now...
I got a new door and body panel on the right side to fix the banged up van after my accident from back in December... Now I don't know if I should get the entire right side painted to match the stock color, or do some sort of black (maybe John Deere Blitz Black) with a white top...
Thoughts?
Before:
After:
Santana Samba Member
Joined: March 18, 2008 Posts: 146 Location: T-Town, WA
Posted: Fri Apr 09, 2010 1:35 pm Post subject: |
SeattleDownhill,
That is quite a before and after! Those wheels look awesome. Paired with the SA grill looks like a sweet custom looking van. _________________ PHOTO GALLERY |
Posted: Sat Apr 10, 2010 1:10 am Post subject: |
Quote: |
SeattleDownhill,
That is quite a before and after! Those wheels look awesome. Paired with the SA grill looks like a sweet custom looking van. |
Thanks man, I'm stoked with how the wheels turned out. The entire passenger's side needs some work... with the new sliding door and rear panel, it needs paint bad. But I don't know if I should stick with stock blue color, or paint the whole thing black... i like the black idea, but stock looks pretty good too.... The driver's side is in pretty good shape other than a tiny ding and that little spot of rust I took care of behind the driver's door.
I don't know what to do really... |
ARABUG69 Samba Member
Posted: Sat Apr 10, 2010 11:30 am Post subject: offset on rims |
hi im buying somemesh rims the guy doesnt know the offfset and i wanted to know is there any way i can lower the car alot with out making the tires stick out or tilt into the wheel well |
Crankey Samba Member
Posted: Sat Apr 10, 2010 1:12 pm Post subject: |
the ET is usually cast or stamped into the back of the whel spokes, can you ask him to look there ?
oh and seattledownhill, those look sweet on there, hopefully 'll see you tooling around seattle and wave |
magician Samba Member
Joined: February 20, 2007 Posts: 95 Location: Seattle, WA
Posted: Sun Apr 11, 2010 9:15 am Post subject: |
SeattleDownhill wrote: |
Thoughts?
A quick question ... I have similar / same wheels 17x7 ET 55 front and 17-8.5 ET50 rear ... are both your front and rear ET55? I am starting my homework on big brakes and in the process trying to account for the rotor thickness as I finalize adaptor thickness ... so your experience, I find valuable.
Oh, on the color, my vote would be for the blue ...
Your ride is headed in a good direction ! _________________ 04 R32 | 85 Cabrio | 79 Rabbit | 91 T3 Carat Auto
'00 Jetta TDI (sold)| 91 Cabrio (sold) | 81 Rabbit diesel (sold)| 87 T3 GL (sold) | 91 T3 Carat 4sp (sold) |
Posted: Sun Apr 11, 2010 9:26 am Post subject: |
What's the interest in bigger brakes?
Seems to me that a 2.1 or 1.9 litre engine pushing wider tires would slow down more quickly anyway...and bigger brakes just seems like somewhere to throw your money.
Am I missing something?
If everyone is running WRX mills then I understand but..? _________________ C'mon, gimme your 71 type 2...And throw in a dash clock. |
Posted: Sun Apr 11, 2010 9:58 am Post subject: |
yeah, mine are 55 front and rear. front rotors should push it out another 6mm or so and rear rotors about 4 mm.
You're right... I think I might just stick with the blue. The driver's side is pretty clean other than a few little scratches that could probably buff out.
As for why to go big brakes... I make the trip to Mt. Hood and Whistler several times a year, and when the van is loaded up with 4 bikes, 3 dudes along with riding and camping gear... brakes are not quite up to par if said deer or car jumps out in front of the van while I'm coming down from the pass an what not. That, and I want to throw a more powerful motor in there so I can make it up the hills as fast as I can go down them... ha ha! |
Posted: Sun Apr 11, 2010 12:50 pm Post subject: |
Quote: |
What's the interest in bigger brakes? |
Vented rotors. The stock solid rotors overheat and fade on long grades. Freeway speeds are higher than the van was designed for back in the day also. |
Posted: Sun Apr 11, 2010 6:05 pm Post subject: |
Makes sense.
Thanks for the Big Brake insight. _________________ C'mon, gimme your 71 type 2...And throw in a dash clock. |
tjamesj Samba Member
Joined: September 29, 2009 Posts: 7 Location: Boise, Idaho
Posted: Wed Apr 14, 2010 10:55 am Post subject: |
I found a set of 16" rims from a 2001 Mercedes S430. Here is the info: 8Jx16H2, ET40. What will I need to make these fit my '87 2wd Westy? Or is 8" just too wide?
Thanks for your help! |
Posted: Wed Apr 14, 2010 11:24 am Post subject: |
tjamesj wrote: |
Yeah sorry, 8" is too wide for practical use on the front of a 2wd. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
kounterkultured Samba Member
Joined: July 24, 2009 Posts: 78 Location: Eastern Townships, QC
Posted: Mon Apr 19, 2010 8:51 pm Post subject: New babies |
Check out my "new" babies
...old Audi wheels (period-corrrect for my 1989), freshly shod in Nokian Hakka C Van in 205-65-15.
Got them through the Samba Classifieds last autumn. I sanded off a few imperfections, glass-bead blasted them, cleaned them w/acetone, then on to a few coats of Dupli-Color wheel paint. In the meantime, got all the required H/W from loogy (thanks again).
Today I brought them to the tyre shop; they rolled as straight as new when balancing the tyres - I'll admit being a little stressed at that moment but thank God they were perfect.
Next step: installation!!
After reading a massive amount of information on C-rated tyres vs the rest I decided to replace the Kelly Explorer M+S rubbers that were on the van when we got it (I think those are rated at 85) :-/
Nothing bad happened with them but safety comes high on the list and I treated the tyre "problem" as if they were fuel lines.
I am more than optimistic about improving the van's handling with wheels 1in larger in Ø + tyres 1in wider... and we won't be annoyed with tyre-safety concerns anymore. _________________ Alex
1989 Vanagon GL
Audi A3 |
mrievaj Samba Member
Joined: April 10, 2009 Posts: 11 Location: Calgary, AB
Posted: Tue Apr 20, 2010 2:25 pm Post subject: audi rims |
I have a line on some Audi rims that are 16 inches with 5x112 spacing. Would these fit without spacers and without any modifications to the rims or is that never a possibility? It seems like every wheel on here needs some work done to it. With so many wheels out there what are the things that make some wheels a definite no go? I am looking for 16 inchers and it doesn't matter if they are steel or not. The less boring out and spacers that are needed the better for my situation.
Thanks
This thread is great but takes a lot of searching within it to find what I think I am looking for and then it ends up being partially over my head anyways. |
