1971BugGuy Samba Member
Joined: October 16, 2004 Posts: 426 Location: Ontario, CANADA
Posted: Mon May 20, 2013 3:57 pm Post subject: |
Quote: |
I would go with a set of 56mm rear studs, small ball seat lug nuts and a set of 45mm small ball seat front lug bolts. |
Thanks _________________ Only a fool or a child would judge a project before it reaches its completion.
1971 Super Beetle
1986 Vanagon Westfalia Weekender |
cheekoman Samba Member
Joined: July 29, 2006 Posts: 346 Location: Burlington, VT
Posted: Tue May 21, 2013 7:07 am Post subject: Mounted up the 928's |
Hi Guys:
Mounted up the 16" 928 wheels this week.
T3 Spacers
Running 215/55/16 97v Extra Load.
Amazing cornering and overall road handling, but that could also be because I put in all new wheel bearings, hubs etc as well.
bosruten Samba Member
Posted: Thu May 23, 2013 3:13 pm Post subject: |
Forgive me if I have missed it in the pages here....how would one go about determining offset on a rim if it could not be verified? For instance, I know I'm looking for a 16"X7" rim with a bolt pattern of 5X110. The bore and offset are my obstacles?
Thank you _________________ '87 Syncro Weekender |
Posted: Thu May 23, 2013 3:48 pm Post subject: |
bosruten wrote: |
Thank you |
Determining the offset begins by measuring the overall width of the wheel from the outer edges of the rim lips. A 7" wheel will usually have an overall width of about 7.6" to 7.9". Once you know the overall width, divide that in half. This will be your wheel centerline measurement.
Then you will need to lay a straight edge across the backside of the wheel and measure down from that straight edge to the wheel/hub mating surface. This is your backspacing measurement.
Subtract the wheel centerline measurement from the backspacing measurement to determine the offset.
If you have used imperial standard for all of your measurements, you will need to convert that to millimeters at some point. Offset is always expressed in millimeters and backspacing is always expressed in inches.
Here is an example:
Overall width of the wheel = 7.75"
Divided in half to determine the wheel centerline = 3.875
Backspacing measurement = 5.06"
Subtract the wheel centerline measurement from the backspacing measurement - 5.06" - 3.875" = 1.185"
Convert to millimeters 1.185 x 25.4 = 30.10mm
This would be considered a 30mm offset. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Thu May 23, 2013 6:50 pm Post subject: |
Christopher Schimke wrote: |
Here is an example:
This would be considered a 30mm offset. |
Awesome, thanks... the search continues ! About the center bore, it should be what diameter? _________________ '87 Syncro Weekender |
Posted: Thu May 23, 2013 7:23 pm Post subject: |
bosruten wrote: |
Awesome, thanks... the search continues ! About the center bore, it should be what diameter? |
Well, it kind of depends. For a 2wd, the lip on the front grease cap is about 64mm, so it needs to be at least that diameter. You could cut the lip off the grease caps which would drop the necessary diameter down to 60.1mm. Some people have machined the grease caps and rotors down to 57.1mm, but from what I understand, the grease caps get really thin when doing that. If you are looking to have wheels machined, I always suggest 66.56mm for several reasons.
For a Syncro, the front hub diameter is 67.08mm, but it tapers down a bit starting right at the rotor. The combination of this taper and the fact that most 66.56mm wheels have chamfer at the centerbore is how those wheels can fit a Syncro without machine work.
The rears on both 2wds and Syncros can accommodate a 57.1mm centerbore, but if you end up having wheels machined, I recommend doing all four to the same centerbore diameter so that you can swap the wheels rear to front if necessary. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
torchmonkey Samba Member
Posted: Sat May 25, 2013 5:07 am Post subject: |
Been looking for a set of wheels that I don't need to add spacers, longer bolts/ studs, etc... I found these:
They are a little too bling, but they re OEM MBZ wheels, 16x7 ET31 any chance they might fit with just a small spacer? This whole wheel figment thing makes my brain hurt. Oh yeah, I drive an '83 Westy 2WD. _________________ 1983 1/2 Westfalia |
Posted: Sat May 25, 2013 5:36 am Post subject: |
Monkey, I can't look up the specs of those wheels of myself at the moment but if they are as you say, 16x7 ET31, those will fit without spacers. You will still need new lugs front and rear as well as longer rear wheel studs. In addition, the center caps won't fit. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Sat May 25, 2013 6:30 am Post subject: |
Thanks for the help Chris. Both on here and elsewhere. I found it odd that they were ET31, still have to contact the seller to be sure. As you can see I'm still shopping around for wheels. I guess if I have to get new lugs/ studs its not the end of the world. I'm not overly concerned if the center-caps don't fit. Just want to be sure of what is involved before I drop pull the trigger on the right wheel. If these in fact are ET31 I'll be pretty happy cause the price is right. _________________ 1983 1/2 Westfalia |
Posted: Sat May 25, 2013 6:36 am Post subject: |
Is that a "1"? Doesn't look like the "1" in the 16 above it.
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Kombi///M3 Samba Member
Joined: March 16, 2011 Posts: 427 Location: Vancouver, BC
Posted: Sat May 25, 2013 10:24 am Post subject: |
I'm looking at these set but the seller is out of town at the moment.
I'm trying to get the specs, I've seen these set on our bus before just couldn't find it. I'm running H&R sport..looks like there's a lot of tire options
too. wonder if 215/70/15 would be ok. I know it's 15" audi wheels that's all.
What you gents think.
Thanks,
Ogi
Posted: Mon May 27, 2013 4:39 pm Post subject: |
Kombi///M3 wrote: |
Thanks,
Ogi
Talked to the seller and they are 15x7 et37. Do I need spacers?
Thanks. |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1867 Location: Pittsburgh PA (ish)
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Thu Jun 06, 2013 10:23 am Post subject: |
Phishman068 wrote: |
I'm not sure that you "need" spacers,
But I am running 15x7 (though they may be 7.5?) et 35 borbets on my 2wd and I run 10mm spacers in the front. |
Is that on your syncro that you're running w/out spacers?
With 2 wd, only a narrow width tire like 195 or 205, *possibly* 215 could get by without spacers, and then no tire chains could be used. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Thu Jun 06, 2013 4:39 pm Post subject: |
Kombi///M3 wrote: |
Thanks. |
Yep! A 15x7 ET37 wheel on a 2wd will absolutely need 7mm front spacers in order for the inner wheel lip to clear the upright. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
backyard_cnc Samba Member
Joined: July 20, 2012 Posts: 385 Location: MANITOBA CANADA
Posted: Sun Jun 09, 2013 8:36 pm Post subject: New Studz in - SIDE A! |
New wheels studs pressed in -Side A! One side done and one side to go. The studs are quite long to take the new MB CLK alloys but not so long that I can't still fit the stock 14" wheels and hubcaps! Have yet to buy correctly rated tires for new wheels so will likely roll on the still good 14" Wheels and Continental tires! And yes I did the brakes and trailing arm replacement at the same time. Other side to get the same treatment within the next week or so!
gerald
Posted: Mon Jun 10, 2013 9:01 pm Post subject: |
Kombi///M3 wrote: |
Thanks,
Ogi
Here she is, Big thanks to Chris (T3 technique) for all the info and hardware. Still need a set of spacer for the rears and long bolts.
Cheers,
Ogi
adamjjohn203 Samba Member
Joined: March 18, 2012 Posts: 187 Location: Bainbridge Island, WA
Posted: Wed Jun 12, 2013 6:13 pm Post subject: |
16x7 ET41 Audi A8 steelies
Nokian entyre 102XL load rating 215/65/16
Had to bore out the centers
Extended studs in the rear and longer stud conversion in the front
7/16" universal spacers all around
_________________ '87 Westfalia
2000 Volvo V70 "eVOLVOd" |
mxitup Samba Member
Joined: September 20, 2008 Posts: 7 Location: Lynnwood, WA
Posted: Thu Jun 27, 2013 11:29 am Post subject: VW Beetle Heritage Wheel |
First off, big thanks to Christopher @ T3 for the technical support and hardware.
Wheel Specs:
VW Heritage Wheel (CZ8)
5x112, 17x7, ET43
Center bore 57.1mm
17" Wheel Black: 5C0-601-025-M-AX1
17" Wheel White: 5C0-601-025-G-Y9C
Chrome Center: 5C0-601-149-D-QZQ
Chrome Ring: 5C0-601-157A
Fitment specs:
Bore the centers to 66.56mm
10mm front spacers
18mm rear spacers
(evens track width front/ rear)
Longer rear wheel studs
Longer front wheel bolts
Small ball seat lugs front and rear
Tire specs:
Conti PureContact
225/50R17 98V XL |
