katzenjammer Samba Member
Joined: September 22, 2005 Posts: 113 Location: Santa Cruz
Posted: Sun Jan 27, 2019 6:20 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Somebody in the SF Bay Area might be interested in these. Four Mercedes wheels (16x7.5 ET23) for $250. They look just like the Gowesty knockoffs, and in the pictures they look pretty clean, but I can't vouch for any of it. No financial interest.
https://sfbay.craigslist.org/eby/wto/d/crockett-mercedes-16-8-hole-wheels-set/6803989541.html
Dan _________________ 1990 Westy Multivan, Auto (3.08 R&P) 1.8T by SAH |
stevw72 Samba Member
Posted: Wed Jan 30, 2019 5:37 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thanks Levi ,I should have put a bit more info I have bored them out to 14mm but was unsure what hardware I would require for fitting them .That also clears up what tyres I require as for snow chains I don't think I need to worry about them I very rarely see snow nowadays apart from on the tops of hills away in the distance _________________ this radio station was named KOWalski, in honor of the last American hero, to whom speed means freedom of the soul. The question is not when's he gonna stop, but who is gonna stop him. |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
Posted: Mon Feb 04, 2019 12:49 pm Post subject: does A stock 14” alloy with a General Grabber AT2 fit as spare? |
TIA |
Zeitgeist 13 Samba Member
Posted: Thu Feb 14, 2019 2:45 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
https://seattle.craigslist.org/tac/wto/d/puyallup-lorinser-rs90-16x8-rims/6817216041.html
These would look super bitchin' on a van. The price is silly high because the rims are really rare. Fronts might be kinda tight on a 2WD
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
arvcube Samba Member
Posted: Sat Mar 02, 2019 2:06 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Finally got tires for my CLKs after years of sitting on them. Thanks to Christopher from T3 Technique for the hardware to get them fitted. 16x7, ET37, 215-55-16 tires, 5mm front spacers, 17mm longer ball studs, 17 ball nuts.
bajaleo Samba Member
Joined: March 21, 2009 Posts: 211 Location: San Juan Capistrano, CA
Posted: Sat Mar 02, 2019 3:26 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
arvcube wrote: |
Looks great! _________________ Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered. |
HOPS Samba Member
toomanyveedubs Samba Member
Joined: November 26, 2007 Posts: 596 Location: Great White North
Posted: Fri Mar 15, 2019 9:12 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Not much talk on this thread about wheel weight but I took some measurements when I took off my syncro 16" steel wheels and upgraded to CLK forged.
I was luckt to get a 16" spare with my truck and it had a brand new never run Tire mounted in the original 195R16 size that is not available in North America that I can find.
Steel wheel 27.6lbs
Mercedes CLK 14.4lbs
Factory Tire with rim 61.0lbs
CLK with 225/75R16 Goodyear Duratrac 57.2lbs! Almost 4lbs saving is really good! |
Snoww_ Samba Member
Joined: September 25, 2015 Posts: 73 Location: California
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Mon Mar 18, 2019 4:48 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
First post is in the Wheels thread. Hardcore!
Welcome! Change your fuel lines! YMMV. _________________ '87 Westy in Wolfram Grey Metallic |
Snoww_ Samba Member
Posted: Thu Mar 21, 2019 12:21 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
campism wrote: |
Welcome! Change your fuel lines! YMMV. |
I'm going in head first! Let's see where it takes me!
Posted: Thu Mar 21, 2019 12:41 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Show us the result!
Snoww_ wrote: |
campism wrote: |
Snoww_ Samba Member
Posted: Thu Mar 21, 2019 4:30 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
bajaleo wrote: |
Show us the result!
Snoww_ wrote: |
campism wrote: |
Oh you know I will!
Cobra88 Samba Member
Joined: May 28, 2018 Posts: 82 Location: Ipswich, Suffolk, UK
Posted: Fri Mar 22, 2019 11:30 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
finally fitted my Mercedes rims
7x15 et35 Rial KBA45818 e320 already 14mm holes
215/70R15 Geolandars 2WD lifted
6mm spacer on front 25mm on rear,
sliding door just clears
Correct wheel nuts from Brickwerx and +10mm studs on front.
No rubbing on anything and center caps fit even on front
Rick
_________________ 84 (85) model year Caravelle GL 1.9 DG Auto WBX Bronze Beige Metallic w Steel Sunroof |
SteveVanB Samba Member
Joined: June 01, 2008 Posts: 1645 Location: This side of Daytona
Posted: Sun Mar 24, 2019 1:54 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Porsche cup 1's
_________________ 91 CARAT |
Make America Vanagon Samba Member
Joined: October 14, 2017 Posts: 65 Location: Glendora, CA
Posted: Sun Mar 24, 2019 9:35 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
SteveVanB, you have the best taste in wheels. Can you share how you made this work? Also interested in shock/spring combo. |
Posted: Mon Mar 25, 2019 5:22 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Make America Vanagon wrote: |
Thanks!
The wheel specs escape me at the moment. 17x7 et52 in the front and 17x8.5 et 47 in the rear i think.....? 20mm adapters up front and 25mm adapters in the rear. Ill be getting thinner adapters for the rear as my slider just kisses the face of the wheel. I had already extended the hinge 1" to clear the lobster claws and Im not feeling like doing that job again! The springs are backyard fabbed until i can find some suitable replacements for the rears. And Koni shocks _________________ 91 CARAT |
LoveLearn Samba Member
Joined: May 11, 2018 Posts: 2 Location: South Dakota, USA
Posted: Tue Mar 26, 2019 9:04 am Post subject: Mercedes Mahle 7Jx15H2ET23 wheels on 1983 Diesel Westfalia |
Mercedes Mahle 7Jx15H2ET23 wheels on my 1983 Diesel Westfalia.
I asked Christopher Schimke of T3 Technique for help in obtaining replacement wheel studs and lug nuts for these wheels and then purchased them from him. I also asked his opinion, emphasizing cost/benefit ratio, what tires he felt would be good choices for this great-looking wheel set fitted to an original diesel powered Westy. Lots of factors needed to be considered there. He suggested Nokian eNTYRE 205/65R15. I guided my purchase selection based on his suggestion, so the tires visible in the attached photos are those exact Nokian model & size. I've owned my diesel Westy over 25 years yet it still has well under 100K miles.
If you took 100 flower lovers to a field of flowers asking each to select the flower they find most beautiful, you might get as many different favorite selections as the participant number. That's to say, taste varies and no person's favorite carries more truth than others. Yet to my eyes, having seen hundreds of different wheels on Mercedes/Audis & VWs, these are my favorite and it took effort to find this nice set. While they are not a low cost solution, I expect their market value will not decrease and may even increase. The center sections are a sparkly gold which contrasts pleasingly with their aluminum outer area.
Posted: Tue Mar 26, 2019 10:39 am Post subject: Re: Mercedes Mahle 7Jx15H2ET23 wheels on 1983 Diesel Westfalia |
Looks great!
LoveLearn wrote: |
tjet Samba Member
Posted: Tue Apr 30, 2019 6:51 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Custom 15x10 Mefro steel rims on rear...
