"What wheels fit?" The ultimate wheel post.
Page: Previous  1, 2, 3 ... 160, 161, 162, 163  Next
jttosh
jttosh is offline
PostPosted: Wed May 13, 2020 3:59 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
I just had Bus Depot cancel my order for all my lug nuts for the alloys i posted above.
Anyone here source these locally at a parts store? Autozone near me did not have them.
"listening for the secret,searching for the sound"
VicVan
VicVan is offline
PostPosted: Wed May 13, 2020 4:08 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
http://t3technique.com/lug-nuts-studs-and-bolts/
Send Chris an email, he's extremely helpful and reliable.
'90 Westiti, 2.1 auto
jttosh
jttosh is offline
PostPosted: Wed May 13, 2020 4:12 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Thanks, if I can't source locally I will give him a try.
Anyone have luck at a chain parts store?
My tires just came in and are waiting on these.
bernier.evans
bernier.evans is offline
PostPosted: Thu May 21, 2020 6:26 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
VicVan wrote:
Hi
I found these, from a 2001 Mercedes E320. 16", ET 41.
Would they fit a stock 2WD Westfalia (auto)? I understand I would need some spacers.
Thanks
Hi VicVan, I found the same wheels. Did you installed them? If yes, can you share what you did to fit these?
Thanks
VicVan
VicVan is offline
PostPosted: Thu May 21, 2020 9:19 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Hi,
Haven't installed them yet. I've contacted Chris at T# Technique, and I ordered spacers for the front and the back, studs for the rear, nuts for the rear, longer bolts for the front. And a drill bit to make the bolt holes a bit wider (37/64").
tjet Premium Member
tjet is offline
PostPosted: Tue May 26, 2020 1:16 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Does anyone know what that maximum backspacing you could have on a 15" steel rim on a 1985 2wd tintop (front & rear)? I'm guessing it's around 5.25" maybe?
I have a spare rim that I will check the rear clearance on, both front & rear on a 2wd & a Syncro.
I will post my findings on max wheel backspacing with some detailed photos
rusty lifted '87 syncro tintop
clean original '85 tintop
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Jun 02, 2020 9:16 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
If you don't buy these, you're an even bigger idiot than me. Don't be that guy.
https://www.ebay.com/itm/MERCEDES-W208-CLK320-16X7...0290.m3507
Casey--
Volkswagens powered by Volkswagen
'01 Weekender VR6 -->2.5 TDI?
Oly Bulli
J-Rod's Van
J-Rod's Van is offline
PostPosted: Mon Jun 15, 2020 2:06 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
2WD Westfalia, will these work? If so, what size tires can I run. If I also add a GW 1.5" lift, can I increase the tire sidewall height?
VW 5x112 , 7.5jX17H2 ET51
Christopher Schimke
PostPosted: Mon Jun 15, 2020 6:37 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
J-Rod, you could run those, but you would need to have the center bore opened up to 66.56 by a machine shop and you would need spacers, studs, and lugs. There's a chance the center caps may not fit too.
Christopher
J-Rod's Van
PostPosted: Mon Jun 15, 2020 11:42 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
The center isn't at 66.56 already being a VW wheel? Any idea on the tire size that i could run with these? Thx
levi
levi is offline
PostPosted: Mon Jun 15, 2020 8:36 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Go to your van.
Write down the tire size you have now.
Plug that into google to find out what your current tire diameter is.
If you're happy with acceleration response, climbing hills now, etc, then find a 17" tire with the same diameter and a load range of 97 or higher.
The above is just a general guideline.
Since Christopher said you'll need to drill it out, you can be fairly sure you need to drill it out.
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
a2wolfsburggli
a2wolfsburggli is offline
PostPosted: Tue Jun 16, 2020 12:47 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
I searched this post and a couple others. Don't see the exact answer.
'87 2wd all stock running components.
Will the 7.5Jx17 ET25 rims from an '03 Audi AllRoad fit with just spacers? Will the center bore need to be machined on these?
If they rims fit (or can be made to,) what size tire would be recommended?
Currently they're sporting 225/55's.
Current: '87 Westfalia | '09 CC 3.6L 4motion "R36 wannabe"
Past: '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Christopher Schimke
PostPosted: Tue Jun 16, 2020 5:16 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
You would have to have the center bore opened up to 66.56mm and you would need to run new lugs front and rear. The center caps will not fit front or rear.
225/55R17s will fit, but are on the tall side. A 215/55R17 or a 225/50R17 would be preferable.
Christopher
a2wolfsburggli
PostPosted: Wed Jun 17, 2020 10:04 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Thanks Chris. Great info as always. I was good until the center plates won't be usable. Which makes sense because they clip to the inside of the hub bore if memory services me correct.
campism
campism is offline
PostPosted: Tue Jun 23, 2020 3:18 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
These look pretty neat, if anyone is interested. Never heard of the Hayashi brand.
https://www.facebook.com/marketplace/item/535721364048992
'87 Westy in Wolfram Grey Metallic
danfromsyr
danfromsyr is offline
PostPosted: Mon Jun 29, 2020 4:17 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
I don't see a center bore hub size but looks like these are a good fit??
6x16 et36
https://www.ebay.com/itm/4-Alcar-steel-wheels-rims...3512919709
also have
6.5x15 et37
https://www.ebay.com/itm/4-Alcar-steel-wheels-rims...3512920851
jwallis
jwallis is offline
PostPosted: Thu Jul 02, 2020 12:24 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
No one has mentioned this in a while, but you can basically find whatever wheels you want on https://www.car-part.com/ you just might have to drive to the yard.
'84 Devon Moonraker - Bostig RG8
Youtube vids covering brakes, bearings, CV joints, 1.9/2.1 cooling system, Bostig and more...
"Use the SEARCH, Luke" But first visit the Vanagon FAQ! - stolen from/all glory to r39o : )
Life is short - get back in the van!
markf1
markf1 is offline
PostPosted: Sat Jul 04, 2020 6:50 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
We need tires so....
We still have the stock 14” wheels. Have been advised by mechanic to upgrade to 15”.
Going to get 5. After researching here and on internet, we are considering the ones below.
https://www.vancafe.com/15Carrot-B-p/15carrot-b.htm
https://www.vancafe.com/T815-p/t815.htm
https://www.busdepot.com/j18754
We plan to put the BF Goodrich AT A K 02 tires on the rims
https://www.tirerack.com/tires/tires.jsp?tireMake=...;tab=Sizes
Any comments or advice on these choices?
We aren’t sure about the spare fitting in the clamshell under the van. Is there a possibility that one of these wheel/tires combos would fit in the existing clamshell?
We would like to avoid spending the $ on a swing out rear spare carrier. Van cafe has the one below but currently out of stock. Not sure if they will have more, need to call after the “holiday” is past.
https://www.vancafe.com/SPTIRECARRIER-p/rmw-tc-spare.htm
Thanks in advance for any advice!
1986 Westfalia Syncro
Some Westy supported adventure photos:
https://www.openrangeimaging.com/adventure.html
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Jul 04, 2020 9:06 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
You will have to modify the stock carrier to fit that size tire, period.
Even then it may not fit, depending on rim WIDTH and tire model.
That VanCafe spare carrier you linked to ISN'T a rear carrier!
Read the description and look at the photos.
Mark
markf1
markf1 is offline
PostPosted: Sat Jul 04, 2020 7:53 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Hi and thanks for your reply. If it is possible to modify the stock clamshell carrier to allow the 15” rim with the 215/75/r15 tires that would be great. Any advice or description of how that is done would be very helpful. I think OK even if we deflated the tire. We carry a small air compressor.
I know that van cafe carrier fits under the van and replaces the clamshell. That would be ideal imo, but out of stock and not sure if they are still being fabricated.
Page 161 of 163
