"What wheels fit?" The ultimate wheel post.
Page: Previous  1, 2, 3 ... , 161, 162, 163  Next
jwallis
jwallis is offline
PostPosted: Sat Jul 04, 2020 10:25 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
@Chris -
I searched and couldn't find, though I imagine you've answered this before.
My question is would it be safe to use t3 Small Ball Seat lugs and nuts with a stock vanagon 14" steel spare... even if it was just 5-10 miles? Would the danger there being the lugs/nuts coming lose, or the small amount of metal on the wheel being grabbed?
I'm obviously trying to get out of carrying extra stuff around in the van. Thanks-
'84 Devon Moonraker - Bostig RG8
Youtube vids covering brakes, bearings, CV joints, 1.9/2.1 cooling system, Bostig and more...
"Use the SEARCH, Luke" But first visit the Vanagon FAQ! - stolen from/all glory to r39o : )
Life is short - get back in the van!
danfromsyr
danfromsyr is offline
PostPosted: Sat Jul 04, 2020 11:09 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
when I carry a stock steel spare.
I carry the 5 spare large ball lug nuts and 5 spare lug bolts. screwed together in the 5 holes in the spare rim.
use some anticorrosion agent of your choice.
kinda like this in this stolen internet image
Christopher Schimke
PostPosted: Wed Jul 08, 2020 11:11 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Dan is correct. You need to carry a set of large ball seat lugs that have a seat diameter equal or greater than stock to prevent them from pulling through the wheel.
Christopher
jwallis
jwallis is offline
PostPosted: Wed Jul 08, 2020 11:16 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Thanks again Chris for all that you do for the community.
I guess that means I'll either have to carry 2 wrenches (or t3's handy dandy 2-in-1 job http://t3technique.com/accessories/miscellaneous-accessories,-shirts,-etc/lug-wrench.html) or most likely I'll start keeping my breaker bar in the van along with sockets, which are already there.
campism
campism is offline
PostPosted: Wed Jul 08, 2020 1:27 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
That's clever. I just have mine all bagged together in the spare tray on top of the wheel. I did buy a special breaker bar with one short extension and dedicated deep sockets (stock and CLK) that I keep in the upper cabinet tray with the jack near the hatch. I have sometimes found the need for a little more leverage than the stock lug wrench or a 4-way (which does not fit both sets of lugs) can provide.
'87 Westy in Wolfram Grey Metallic
The breeze block
The breeze block is offline
PostPosted: Fri Jul 17, 2020 12:46 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Houston we have a problem...
Tried to mount a General grabber AT2 tire on a mb steel rim.
215/75/15 and 6 inch Et31 rim
A little too stiff tire and weak rim?
The machine couldn't make it around the whole way.
I guess a more powerful machine wouldn't help if the tire does this to the rim anyway.
Anyone else here know their shit around a tire machine?
jwallis
jwallis is offline
PostPosted: Fri Jul 17, 2020 1:33 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
After about 1/3-1/2 way getting the tire on, did you make sure to push the bead of the part that's already "on" into the middle of the rim so there's a little more length to get the tire the rest of the way on?
Right at 7:10 on this video https://www.youtube.com/watch?v=BsOUtR_lTeE
danfromsyr
PostPosted: Sun Jul 19, 2020 3:56 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
yeah this.. I have a tire'hammer' that I use to smack the tire down into the center to finish the 'stretch' on my machine.
and that tire will be 'ok' well in my opinion i've run worse bead bites..
hammer the rim back to shape with a ball pean and a dolly.
maybe some bead sealer if you think it'll leak but it'll be 'fine' that's the bottom edge.
well the lawyers say I can't give advice on tires... so your screwed it's puked and it's cheaper of a mistake than asking the lawyers was.. Laughing
bogswagen
bogswagen is offline
PostPosted: Mon Jul 20, 2020 12:49 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
hello!!!
will be running 15x6.5 Et38.... any suggestions on the spacer size I'd need to use? Will be using Michelin Ice, with no lift. Stock 87 AdventureWagen....
Any help will be awesome!
a2wolfsburggli
a2wolfsburggli is offline
PostPosted: Tue Jul 21, 2020 4:43 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
18x8 ET47 fitted:
https://www.thesamba.com/vw/forum/viewtopic.php?t=740290
Current: '87 Westfalia | '09 CC 3.6L 4motion "R36 wannabe"
Past: '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Last edited by a2wolfsburggli on Thu Aug 06, 2020 11:37 am; edited 1 time in total
jwallis
jwallis is offline
PostPosted: Tue Jul 21, 2020 9:49 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
a2wolfsburggli wrote:
18x8 ET47 fitted:
Wow, there's a lot of light coming through those rims!
I finally got some 16x8s from a good guy who had an ad here on theSamba, and included t3 5mm spacers for the front plus small ball seat lugs and nuts. After this experience I would definitely do 16x7 or maybe 16x7.5 in the future. I put on 215/60 r16 Nokians ($550 = purchase, put on wheels and balanced, no "certificates" from Discount Tire). The wider rim doesn't add any value because I would put the same tires on any of these rims (16x8, 16x7.5, 16x7).
This site is awesome for wheel info:
https://www.originalwheels.com/mercedes-wheels/eclass2008rims.php
2008-2009 Mercedes-Benz E Class (211 Type)
Size: 16" x 8", 5 Lug, 112mm Bolt Pattern, ET 36mm Offset
I ground a little off the steering knuckle where it was very close to the wheel for a little more clearance. The front tire sticks out which looks ok to me, but it will sling more road crap up behind it onto the van.
I'm also thinking about going darker (see poor photoshop below), but it sounds like a lot of work and they good as they are. Would like to be a little more subtle.
Went from 197/75 r14 to 215/60 r16 (see next to each other shot)
I hope this info is useful to someone in the future. These wheels can probably be found near you on car-part.com
vino de vano
vino de vano is offline
PostPosted: Tue Aug 04, 2020 8:59 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Thought I'd submit my wheels to the thread. Lorinser off Craigs list $400.00, bolt on no mods. Spacers studs bolts and nuts from T3, Thanks Chris.
I fixed the curbing and repainted the outer rim.
what a long strange trip it's been
bajaleo
bajaleo is offline
PostPosted: Wed Aug 05, 2020 10:58 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Those look great!
Leo in SoCal
1984 Wolfie Westy, Subaru EJ22 powered.
a2wolfsburggli
PostPosted: Thu Aug 06, 2020 11:38 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
What size spacers did you use?
vino de vano
PostPosted: Thu Aug 06, 2020 1:01 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
There 12 MM front, 20 MM rear. I would go with 15 MM on the rear, if I were to ever change it. Tire is touching bottom edge of slider at full open. It's ok but snug.
pechaaa
pechaaa is offline
PostPosted: Tue Aug 11, 2020 5:53 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Got a set of staggered wheels
Anyone here riding on 16x8, 16x9, ET-11?
S4VAGE
S4VAGE is offline
PostPosted: Sat Aug 15, 2020 12:34 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Those look amazing. Rare find, perfect application.
pechaaa
pechaaa is offline
PostPosted: Sun Aug 16, 2020 10:59 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Anyone Very Happy Rolling Eyes
vino de vano
PostPosted: Mon Aug 17, 2020 10:34 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
I would suggest you go to page 1 and start learning what fits. Unfortunately you need a wheel with at least ET 30 or more.
pechaaa
pechaaa is offline
PostPosted: Mon Aug 17, 2020 10:03 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Done that previously.
Despite small ET, there are some using them...
Page 162 of 163
