bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Mon May 15, 2017 9:45 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
bajaleo:
Yes, there are some that are able to be fitted. Good luck. The problem is that very few tires will be an option. These rigs are the equivalent of a 1 ton truck. Thus, they require minimum of C rated tires. Then you have the wheel well, which was designed for somewhere around 25.5" total diameter tires.
I looked and looked. Never found a match. Not saying I don't want 18" or + rims, just in practical terms, never was able to make it work as a whole.
Good luck tho. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Jaerl Samba Member
Wangta Samba Member
Joined: November 04, 2016 Posts: 56 Location: Inland Empire, CA
Posted: Thu May 18, 2017 11:20 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
This may have been asked before but does anyone know what wheels these are on this van (from the north westy website)? They are so clean!
Posted: Mon May 22, 2017 8:45 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
As they came on a Mercedes, the front wheels are 17x7.5 ET36 (part number 2034013402) and the rear wheels are 17x8.5 ET34 (part number 2034013602), but I think that Syncro has four of the 17x7.5s on it. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Wangta Samba Member
Posted: Mon May 22, 2017 8:47 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Christopher Schimke wrote: |
As they came on a Mercedes, the front wheels are 17x7.5 ET36 (part number 2034013402) and the rear wheels are 17x8.5 ET34 (part number 2034013602), but I think that Syncro has four of the 17x7.5s on it. |
Thanks Chris. Yeah I looked at those and they come staggered. Both the 7.5 and he 8.5 should fit on a Syncro, no? Also wondering if these will bolt on without spacers or need other stuff? |
Posted: Tue May 23, 2017 6:12 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Wangta wrote: |
You would need to install longer studs front and rear and run small ball seat lugs, but no spacers. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Wangta Samba Member
Posted: Tue May 23, 2017 9:55 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Wangta wrote: |
You would need to install longer studs front and rear and run small ball seat lugs, but no spacers. |
Chris - forgot to ask - are these wheels "strong" enough to support Vanagons? I'm trying to research and see what the load rating is - or if the wheels are forged, etc. Completely forgot we have to think about these things!
Wangta Samba Member
Posted: Tue May 23, 2017 10:20 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
No spacers - even for the 8.5? Huh, surprised. |
Posted: Tue May 23, 2017 10:56 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Wangta wrote: |
Nope, no spacers, but that's assuming you would only be using them on the rear. If you tried to use them on the front, yes, you would need spacers, but I would not recommend them on the front. Too wide!
Wangta wrote: |
Chris - forgot to ask - are these wheels "strong" enough to support Vanagons? I'm trying to research and see what the load rating is - or if the wheels are forged, etc. Completely forgot we have to think about these things! |
OE Mercedes wheels are notoriously strong and strength is not something that I would worry about in the least. They are so much stronger than any of the cheap aftermarket wheels being mounted on Vanagons today. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Wangta Samba Member
Posted: Tue May 23, 2017 11:00 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Nope, no spacers, but that's assuming you would only be using them on the rear. If you tried to use them on the front, yes, you would need spacers, but I would not recommend them on the front. Too wide! |
Thanks Chris - so I'm guessing for a syncro, 7.5 on all four wheels is the max width you wanna go? I think most of the stock VW Vanagon wheels are 7 wide so that would make sense. |
Posted: Tue May 23, 2017 11:03 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Wangta wrote: |
The widest stock Vanagon wheel is 6" so yeah, 7.5" wide make for a much better fit than 8.5" wide. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Wangta Samba Member
Posted: Tue May 23, 2017 11:13 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Wangta wrote: |
The widest stock Vanagon wheel is 6" so yeah, 7.5" wide make for a much better fit than 8.5" wide. |
Thank you so much for your insight - I'm a fairly new Vanagon owner and your insight and patience is invaluable. I hope I can repay you one day! |
Italjohn Samba Member
Joined: October 29, 2016 Posts: 193 Location: Molde, Norway
Robw_z Samba Member
Posted: Wed Jun 21, 2017 5:14 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Italjohn wrote: |
My new wheels.
2WD TD 1,6 (JX)
Rim 16" - 7,5 wide - ET36 - spacer 6mm
Tires 205/65R16 speedometer 4km/h off.
Better to choose 205/60R16 as the engine is too weak to pull uphill.
Italjohn, I have these same wheels yet have not installed them. Do you have 6mm spacers all around, or just on the front or back? What did you use for wheel hardware?
Thanks for any input or advice!
-Rob |
Posted: Thu Jun 22, 2017 12:20 pm Post subject: Re: My new wheels! |
Back on page 52 of this thread, I see the below rims. I looked and looked around on the surrounding pages, but never found the info on what these take for hardware to mount. I really like the looks, and there is a set of 4 near me for cheap.
(thanks in advance ChrisToph3r)
aolive wrote: |
I just got my Westy a couple of months ago. My friends are all jealous!
Mercedes SLK 10 spoke.
removed crapped out photobucket links. The pix were good, but didn't last _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch
makina Samba Member
Posted: Sun Jul 02, 2017 1:34 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I need help asap, I found these wheels I love I know that if I search enough I can find my answers but I really need to know fast before they sell. The wheel diameter is 5x120 there BBS from a beamer 5 what all do I have to do any help is greatly appreciate thanks all |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Sun Jul 02, 2017 8:32 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
5x120 BCD will not fit without adaptors. Vanagon is 5x112. _________________ '87 Westy in Wolfram Grey Metallic |
bigEZbob Samba Member
Joined: March 30, 2016 Posts: 34 Location: Ontario Canada
Posted: Mon Jul 17, 2017 11:49 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I have a 1983 WB vanagon. Extensive work on the motor, lines, gas muffler, gas tank are complete and it's time for tires. Inside can wait till winter.
Our VW dealer in town recommended the Michelin Defenders 2156016.
He too has a Westy, 1974.
I was chatting with my mechanic who thought Passat rims would fit these tires.
He asked me if there are there any particular year Passat makes that work better (than others) with these tires?
i`m asking here since this place is golden!
I'm open to suggestions or leads-bottom line is, as stated here, good tires are inexpensive insurance.
Thanks in advance |
Ride_On Samba Member
Joined: August 27, 2015 Posts: 385 Location: Ottawa, Canada
Posted: Tue Jul 18, 2017 8:28 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
For our Bus, we're going to go with Michelin Defender LTX M/S in 215/55r16 as they have a higher load rating (97H vs 95T). This is the source of much (anecdotal?) debate, but ultimately GoWesty sells the Defenders so they are in use by lots of folks.
For rim fitment, check out Christopher at T3Technique.com - he has all the knowledge and hardware you need and does ship to Canada. We have some new lug nuts en route now.
Good luck!
bigEZbob wrote: |
Thanks in advance |
_________________ 1977 Westfalia 2.0 FI Skills EJ25 w SubaruGears 5sp
https://www.thesamba.com/vw/forum/viewtopic.php?t=687254
2018 Golf Sportwagen 4MO DSG (Dieselgated 2013 Golf Wagon TDI DSG) |
Posted: Tue Jul 18, 2017 2:38 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Merci mon ami! We are off to Cypress Lake Friday. |
