elizer Samba Member
Joined: May 02, 2016 Posts: 1462 Location: Northern Virginia
Posted: Thu Jan 11, 2018 11:37 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Omg those Ronals are gorgeous |
zuhandenheit Samba Member
Posted: Wed Jan 24, 2018 7:45 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I've been looking at these Audi wheels: They're 16X7. I am not sure about the offset -- hoping someone can recognize them and let me know!
Thanks in advance! |
Van Geaux Samba Member
Posted: Thu Jan 25, 2018 7:51 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
A member in Jersey has these posted in the part it forward thread. Will they fit a 2wd vanagon? If so with what mods?
Written on the back:
A 220 401 01 02 (MB P/N)
Ronal
71/2J x 16H2 ET45
Posted: Sat Jan 27, 2018 8:35 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
zuhandenheit wrote: |
Sorry, no picture. If you can repost it, I'll take a look. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Sat Jan 27, 2018 8:38 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Van Geaux wrote: |
Ronal
71/2J x 16H2 ET45
Those wheels have lug holes that are already large enough (so, no drilling necessary) and they require large ball seat lugs. The best way to mount them is with spacers front and rear, new rear studs, new rear lug nuts, and either new front lug bolts or a set of high quality conversion studs (not the cheap studs. Those will pull out of the hub) and another set of lug nuts to match the rear.
And just for the record, those wheels are ET46, not ET45. Small detail, but it can be important. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Sat Jan 27, 2018 12:15 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thanks Chris. If I can figure out how to get them from Nj to NC I will give you my business for the parts if you have all that stuff? |
90Doka_Guy Samba Member
Joined: April 08, 2007 Posts: 548 Location: South Jersey
Posted: Sat Jan 27, 2018 3:03 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Christopher Schimke wrote: |
And just for the record, those wheels are ET46, not ET45. Small detail, but it can be important. |
You really know your wheels! I just double checked the writing on the back of the wheels in question for my own sanity. ET46 _________________ -'87 Westy
-'90 Tintop
-'90 DOKA |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Sat Jan 27, 2018 10:48 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Alaskaberrys wrote: |
A question for you, are the Autec wheels common on the T3’s in your location? With no suppliers here in the states our only tire shop in Juneau, LesSchwaub, was having a difficult time sourcing a wheel to match the offsets of the Autec 7,5 x 16" (KBA number: 45311) with a 205/80 R16 mounted to use as a spare with the same diameter. They took my info, but a week later and I still haven’t heard back... |
Do you know the offset of your Autec wheels? Also, have you checked to see if the previous owner installed any spacers front and/or rear? If so, how thick are they? If you let me know, I'll see what I can find for your spare. |
I found “ET35” stamped onto the back of a front tire I took off, seems pretty straight forward assuming European wheels use the same nomenclature - found no spacer. Was studs coming from the hub, didn’t measure them tho. Also found “A756” and “7.5JX16H2” along with another number that looks to be a serial number stamp but pretty indecipherable along with “Autec” and “Germany”.
Not 100% identical in appearance, but close. Size and offset are identical.
https://www.tirerack.com/wheels/WheelCloseUpServle...toModClar= |
Well, I misled you a few posts back it seems. I removed the front wheel to do a temp refinish as per your helpful methodology and realized that there was indeed a spacer under those Autec wheels after all
Looks like 15mm thick
with a 62mm center bore
and 46mm of studs w/o the spacer
Wondering if I'd have better luck finding a similar wheel with a shallower offset perhaps?
By the way, just finished the first etch prime coat after sanding today (like all day! ) and already looks better!
Before...
and 1st prime.
This will go along way to preserving these wheels till I can have them powdercoated down the road.
Thanks Chris! _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
Neptuno Samba Member
Joined: March 23, 2004 Posts: 141 Location: DelCo, PA
Posted: Mon Jan 29, 2018 11:19 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Well what do you think of these??
https://i.imgur.com/7Jy9e1T.jpg?1
Wheels:
Sparco Assetto Gara Black Painted
Offset: +35mm
Backspacing: 5.35"
Bolt Pattern: 5x112
Weight: 17.0 lbs
Finish: Black Painted
Hub Bore: 73.1mm (57.1mm hub rings are included) _________________ Lonely Vanagon running up and down Delco
joetiger wrote: |
Also, if you look closely, the drapes in the house match the Vanagon, illustrating outstanding thematic continuity. |
Pinetops Samba Member
Posted: Mon Jan 29, 2018 6:10 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Does anyone know anything about these wheels?
_________________ "A rolling bus gathers no rust." |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon Jan 29, 2018 8:13 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Ronal r9 15" _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Mon Jan 29, 2018 9:11 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thanks! Those are some good looking wheels. _________________ "A rolling bus gathers no rust." |
1of6 Samba Member
Joined: August 25, 2013 Posts: 39 Location: Qualicum Beach, British Columbia
Posted: Tue Jan 30, 2018 10:31 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Those look awfully similar to Ronal R9s...but not quite. _________________ 1958 Beetle, sold
1964 Cabriolet, sold (avatar)
1973 Westphalia, sold
2002 Turbo Beetle GLX, sold
1992 4 door Double Cab Transporter
1987 3 door Double Cab Transporter |
Posted: Wed Jan 31, 2018 9:23 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Yep, you're right. They are a little different. _________________ "A rolling bus gathers no rust." |
1of6 Samba Member
Posted: Wed Feb 14, 2018 7:11 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Definitely a question for Chris...
Still looking for wheels, guy says these were definitely on his brother's 450 Benz which should make them 5x112 but it looks like they measure 114.5???
Anyways, specs he sent are: Bolt pattern 5x114.3mm, Center bore 72.6 mm
Offset +40, Wheel size 18 x 8J, PCD 56, Style - American Racing AR883
Is he mistaken or are there adapters for this combo?
Thanks again if you can assist!
Posted: Wed Feb 14, 2018 9:28 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
1of6, judging from your drawing/tracing, i would say those are 5x114.3 too. It's possible to bolt a 5x114.3 wheel to a 5x112 car if the lug holes are large enough, but it's incredibly dangerous.
The problem with the adapter route is that the thinnest adapters we can make are 15mm thick. With a 40mm offset, the final offset would end up being 25mm. This isn't a problem on the rear, but the fronts will be positioned outward a little more than is necessary. If your van is stock height or raised, this may not pose a problem, but if it is lowered, just that little difference could result in some additional rubbing. The other issue is that with 15mm adapters, the lugs that mount the adapters to the hubs protrude from the wheel mounting surface by about 7mm. Some wheels have recesses in between the lug holes that can accommodate this, but not all wheels do.
The other issue with those wheels is that the the center caps will not fit and it's possible that the front hole that the center caps clip into may be too small to allow the front grease caps to pass through. That's just a guess based on the photo though. You would have to test fit them to know for sure. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 784 Location: WestWorld Nanaimo BC
Posted: Wed Feb 14, 2018 9:55 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
1of6 wrote: |
Probably running wobble-bolts...if not - eek!
_________________ 1991 Double door pop top conversion |
Posted: Wed Feb 14, 2018 10:03 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
RoryGirl wrote: |
1of6 wrote: |
Man, that video illustrates why ECS is known as the Walmart of the VW/Audi parts world. They pretty much gloss over the fact that in order to safely use wobble bolts, the wheels have to be perfectly hubcentric to the hubs and not a torque wrench in sight, just an impact. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Last edited by Christopher Schimke on Wed Feb 14, 2018 10:08 pm; edited 1 time in total |
1of6 Samba Member
Posted: Wed Feb 14, 2018 10:07 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thanks guys, I really appreciate the feedback! _________________ 1958 Beetle, sold
campism Samba Member
Joined: September 07, 2007 Posts: 4491 Location: Richmond VA
Posted: Thu Feb 15, 2018 5:51 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
On the 114.3 topic, here's a pic of my van with a neighbor's Nissan Maxima wheel with that BCD on the front. I'd seen pix of a van with these on them and decided to test. Not an "A" fit, as they say. Longtime forum members might remember reports of a Westy with a Nissan V6 swap that was being driven on a lengthy honeymoon trip by a young couple and wound up sliding off a mountain road out west and getting totaled. That van used these wheels and was my inspiration for the test fit. The radius of the BCD is 1.15mm larger; not much, but enough to make it almost a force fit to get the wheel on there with the lugs binding on the insides of the lug holes. Also takes a flat seat lug instead of the ball seat of the Merc and VW wheels. I got CLKs instead.
_________________ '87 Westy in Wolfram Grey Metallic |
