Worth Chasing #'s?
Mark Evans Premium Member
Mark Evans is offline
PostPosted: Fri Nov 10, 2006 8:34 am    Post subject: Worth Chasing #'s? Reply with quote
My '55 ragtop is on a '65 pan. The pan itself is in good shape and I am readying to pull the body off this winter. I saw a recent ad for a '55 pan for sale in the classifieds and was wondering if it would be worthwile to exchange for this pan. The #'s wouldn't match, but would be within 20,000 of mine. What would that help or hinder for originality? Or no change from the '65?
'63 Ragtop
Rusties
Rusties is offline
PostPosted: Fri Nov 10, 2006 8:54 am    Post subject: Same deal Reply with quote
I'm in the same situation Mark, wondering if I should search out a year appropriate pan for my 56, which now sits on a 63 pan. Thing is I just finished my restoration after 7 years of part hunting, collecting and refinishing. I believe it is the right thing to do, but my current pan is mint, hmmmm decisions decisions.
You however are starting the pan off procedure, and would have a year appropriate car, however... the numbers would still not match. ;]
Good luck ... and take pics! Lots of em!
Matt K.
Paint and Body Nutcase
Matt K. is offline
PostPosted: Fri Nov 10, 2006 9:01 am    Post subject: Reply with quote
I think that it is a toss up. One side is that the pan has been changed for whatever reason and the #'s do not match. On the other hand even if the pan you track down is correct for the car the #'s still do not match. I guess if it were me i would prefer the pan that is correct for the car but it is really a judgement call.
This is my 23rd year in the Auto Body/Paint Game!
*Take a look at some of my custom paint: http://s110.photobucket.com/albums/n119/mrpaint_2006/ .( NOTE: these are some older jobs but still neat.)
coad Premium Member
Samba Scapegoat
coad is offline
PostPosted: Fri Nov 10, 2006 9:11 am    Post subject: Reply with quote
It still won't be original and the numbers still won't match, so what do you gain? It's like being a virgin, once it's over there's no going back.
PostPosted: Fri Nov 10, 2006 9:38 am    Post subject: Reply with quote
Well put!
'63 Ragtop
druid57
druid57 is offline
PostPosted: Fri Nov 10, 2006 11:35 am    Post subject: Reply with quote
For my two 'penneth I'd say go with the early pan.
Yes the numbers won't match, but in essence you'd have a 'correct'
car with the exact same parts and look as when it left the factory.
In my opinion a 'correct' car is better than a generic beetle beetle made up from bits and pieces of cars from different eras. The early pan would have the correct pressings in the floor and would look the part.
You have the luxury of being partway through your restoration, therefore you still have a choice. The most important thing is that you make the right decision - one that you can live with.
PostPosted: Fri Nov 10, 2006 1:50 pm    Post subject: Reply with quote
I'm not an expert on 55s but isn't the 55 pan significantly different? Position of the heater knob, etc. ,etc.?
If that is true, it's worth swapping back to a '55 pan, even the wrong one.
vdubinit
vdubinit is offline
PostPosted: Fri Nov 10, 2006 1:58 pm    Post subject: Reply with quote
yes you are right 55 and earlier pans are completly different compared to 56 and later pans heater knob, e brake cables, e brake handle and the whole shape of the pan were it meets the rear crossmember
the numbers wont match but atleast it will be correct for your car Wink
**WANTED** ONE 4 1/2 EARLY FUCH
Bruce
Bruce is offline
PostPosted: Fri Nov 10, 2006 2:14 pm    Post subject: Reply with quote
Dead on! It is still on the 100% wrong pan, it is still not numbers matching.
Besides that, the expense of restoring an early pan is significant for ZERO gain.
RareAir
RareAir is offline
PostPosted: Fri Nov 10, 2006 3:45 pm    Post subject: Reply with quote
Is your car going to be a daily driven car or a show pony? The later pan will give you more options on performance upgrades whereas restoring a Pre '55 pan can be a very expensive route. The braking system alone can easily deflate a fat wallet.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
PostPosted: Fri Nov 10, 2006 6:20 pm    Post subject: Reply with quote
Bodywise, it will look a '55, but I already have a 2007 with Weber's, Airkewlds's Bad Ass brakes all around(in boxes). Have 4.5's and '6" Fuch's. No, it won't be mechanically correct in those ways, but ALL my sheetmetal is. Another issue with the earlier pan is having to run correct seats, where as now I have good early lowbacks. As mentioned, the looks of the correct positions for the heater knob and e-brake handle is another concern I had, but I'm running a Gene Berg shifter, so would that really matter?
'63 Ragtop
RareAir
RareAir is offline
PostPosted: Fri Nov 10, 2006 7:12 pm    Post subject: Reply with quote
The heater knob is located behind the e-brake handle on a '55 pan. The shifter is also located further back away from the firewall, hence a straight shifter is used. If you install a curved Berg shifter, the shifter handle may be too far back for a regular length arm. But if you've got short arms, then it'll be comfortable......
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
steven wood
steven wood is offline
PostPosted: Fri Nov 10, 2006 7:13 pm    Post subject: Reply with quote
I would change the pan to the '55 pan. I hate seeing a split or oval with a 60's pan. It's just something about it.....50's and 60's put together. I think it would hold a better resell value if you ever decide to sell it. If you swap the seats to a set of H pattern seats, atleast you will not have people telling you that you have the wrong seats.
Alan Willis
Banned
Alan Willis is offline
PostPosted: Fri Nov 10, 2006 8:08 pm    Post subject: Reply with quote
I would also switch to the '55 pan. Another benefit is that in states like California where they register the car by the pan, your title would be correct, and you could run '55 plates!
die schwarzen Schafe #666
RareAir
RareAir is offline
PostPosted: Fri Nov 10, 2006 8:42 pm    Post subject: Reply with quote
Alan Willis wrote:
... states like California where they register the car by the pan, your title would be correct, and you could run '55 plates!
Mark is in Oregon Wink Does the Oregon DMV recognize the YOM program?
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
PostPosted: Sat Nov 11, 2006 7:07 am    Post subject: Reply with quote
I bought the car from Washington, when I registered it here, I managed to get it titled as a '55 but they used the '65 Vin #. I think what I dislike most is the positions of the dual heater controls.
'63 Ragtop
billmetric
billmetric is offline
PostPosted: Sat Nov 11, 2006 8:56 am    Post subject: Reply with quote
I remember Shawn Supanich had a '53 with a later pan, he had a fake heater knob glued down behind the parking brake !
There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there...
