67_13Deluxe Samba Resident Alien
Joined: February 18, 2005 Posts: 912 Location: Salt Lake City, Utah
Posted: Fri Nov 10, 2006 2:04 pm Post subject: Clutch issues |
What would make my clutch do this? it was completely sheared off by the rivets. Just wondering if there is anything else i should check before I replace the parts.
_________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
56 Beetle - Wilbur. I found a lot of lipstick on this pig so far.
63 Beetle - Luna
66 13 window Bus - Tetanus
71 Bay Window - Lola. Totaled. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Nov 10, 2006 2:13 pm Post subject: clutch |
Abuse _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Fri Nov 10, 2006 2:18 pm Post subject: Re: clutch |
60ragtop wrote: |
Abuse |
Its my wifes car and she is very easy on it. But i wouldnt put it past her!!! _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
Posted: Fri Nov 10, 2006 2:19 pm Post subject: |
EverettB wrote: |
I did something very similar in my old Single Cab hauling too much concrete.
I replaced the clutch disk and had no further problems. |
So i shouldnt worry about anything mechaincal just maybe its old and was under a rough load before i bought it. _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
Posted: Fri Nov 10, 2006 2:24 pm Post subject: clutch |
Does it look like any thing hit the rivits and sheared them off? At one time there was some Korean disc out there that the rivit heads were to big and hit on the inside side of cover when the clutch was pushed in all the way
Your wife is probably as gentle as mine on her car _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Fri Nov 10, 2006 2:32 pm Post subject: Re: clutch |
60ragtop wrote: |
Your wife is probably as gentle as mine on her car |
There doesnt appear to be anything in there that would shear them off. _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
Posted: Fri Nov 10, 2006 3:21 pm Post subject: |
67_13Deluxe wrote: |
EverettB wrote: |
So i shouldnt worry about anything mechaincal just maybe its old and was under a rough load before i bought it. |
Mine didn't break on the rivets but it broke between all the little holes inward of the rivets. I figure it was fatigued or had some hairline cracks. Especially since I've hauled the same size loads again with no trouble. _________________ How to Post Photos
