Rowroy Samba Member
Joined: November 07, 2006 Posts: 1012 Location: The ass of nowhere
Posted: Sat Nov 11, 2006 8:07 pm Post subject: heater cable problem |
I tried to replace the cables that run from the passenger side lever to the heater boxes. I noticed that the previous owner only had one heater box connected (passenger side - only 1 cable). When I tried to run the cable back to the driver's side box, I hit some sort of clog in the tube. If I try to run a wire from the rear of the car, it hangs up in the same place (just as it comes into the cabin, under the rear seat). Whatever it is, it's solid. Blasting the tube with 125 psi of compressed air didn't help at all. I don't see how the tube could have been crushed because I can't even see the damn thing!
One side note: when I tried to "snake" the hole from the rear of the car, the wire came out wet, rusty, and smelled of stagnant water.
The next thing that I plan on trying is to snake it again with heavier gauge wire in a drill.
Do you guys have any tricks up your collective sleeve that I can try? |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Sat Nov 11, 2006 8:22 pm Post subject: Re: heater cable problem |
Rowroy wrote: |
What you suggest would be exactly what I'd try next. I might flatten the end of the wire I put in there with a hammer and use a sanding disc to put an edge on it before I snaked it in there, better to cut through the gunk it might encounter.
-Andy |
matt175 Samba Member
Posted: Sat Nov 11, 2006 8:35 pm Post subject: |
sounds like you have part of the old cable still in the tube.
try spraying alot of pb blaster down the tube to break all the rust out, and you should be able to clear the obstruction. |
birddog1 Samba Member
Posted: Sun Nov 12, 2006 11:23 am Post subject: |
An option just in case you get stuck. You can replace the cable vents with the lever type. You may need to cut a little off their bottom, but I actuallly like them better. You can adjust each side independent and no messing with cables
