bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Thu Nov 16, 2006 1:24 pm Post subject: |
Perhaps we can get "Mythbusters" to do an episode on this. |
mobowesty Samba Member
Joined: June 02, 2005 Posts: 101 Location: Central Massatucky
Posted: Thu Nov 16, 2006 2:08 pm Post subject: |
Hey, I like that! And maybe we can get that Boston cop to appear on MythBusters who escorted me out of the tunnel tollbooth and turned me around. He can explain to the world (as he explained to me) that even an EMPTY propane tank can create an explosion hazard in the tunnel.
Empty propane tanks. Be afraid... BE VERY AFRAID! _________________ ############################
86 Westy 2.1 wbx - off the road this year
and an "Empire of Junk"
My wife's photography site: http://www.lisadavenock.com |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1884 Location: Montreal
Posted: Thu Nov 16, 2006 2:22 pm Post subject: |
I inquired about going through tunnel here as my welding equipment was mobile. Funny thing is I was told fro personal use no problem. A company can not go through a tunnel. Must be the conception of quantity. |
erdonline Samba Member
Posted: Thu Nov 16, 2006 9:04 pm Post subject: propane bottles |
I believe the issus with bottled gases, at least with propane, is not necessarily the risk of explosion of the tank itself (although I'm sure that is of at least some concern) as it is with leaking gas and the fact that propane gas is heavier than air and would tend to "pool" in the tunnel, creating the explosion hazzard as sources of ignition drive by this accumulated propane pool.
Ed |
Old_Ben_Gun Samba Member
Joined: December 18, 2012 Posts: 30 Location: Spanaway Washington
Posted: Sun Sep 13, 2015 9:18 pm Post subject: |
Wellington wrote: |
Can you give us a line on this adapter please. I can't see it being widely advertised as the one pound bottles are clearly marked not to be refilled. |
Harbor Freight carries the adapter. Refilling the 1lb bottle or removing it and hooking it to anything can cause the neck valve to leak. Never carry any propane bottle inside a vehicle. |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Sun Sep 13, 2015 10:06 pm Post subject: |
Holy resurrected thread , Batman!
FYI; it is both safe and legal to carry lp in a vehicle if it is in a sealed, unlocked, vented-to-outdoors top and bottom, cabinet.
I posed this question a few weeks ago and the safety patrol nearly spilled their wine coolers replying that it was both illegal and unsafe.
I did my own research. Not true. As usual.
Neil2 |
Westified Samba Member
Posted: Mon Sep 14, 2015 9:06 am Post subject: |
furrylittleotter wrote: |
Neil2 |
Based on this we can't carry the 1 lb cylinders inside the Van unless we make a special vented, sealed cabinet, is that true? I have carried these cylinders, usually 2 inside my vanagon westy and prior to that my bus westy for years. Comments please. _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
danfromsyr Samba Member
Posted: Mon Sep 14, 2015 9:16 am Post subject: |
these people make refillable 1# bottles and a "system" for the DIY. not to bad if you use them alot like in small MR buddy heaters etc..
http://www.propane-refill.com/
the BIG BOOK on LPG rules
https://law.resource.org/pub/us/cfr/ibr/004/nfpa.58.2004.pdf
Quote: |
Below is an excerpt from the National Fire Protection Association's guidelines that almost every US State adopts verbatim:
NFPA 58, 2011 Edition: 7.2.2.10
“Single trip,” “nonrefillable,” or “disposable” cylinders shall not be refilled with LP-Gas.
Single-trip, nonrefillable, or disposable cylinders are not designed for extended service. Their small size increases the chance that they will be overfilled when commonly available filling equipment and procedures are used. The cylinders are designed for filling by weight and are equipped with filling connections that common filling equipment will not fit, in an effort to control these hazards. However, adapters for refilling are widely available because refillable cylinders come in the same sizes as nonrefillable cylinders.
Accidents have resulted from the refilling of nonrefillable cylinders, which is prohibited both by federal law in the DOT cylinder regulations and by NFPA 58 |
Abscate wrote: |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Mon Sep 14, 2015 9:18 am Post subject: |
The thread pot Neil is stirring is for hooking up an inside cylinder to run appliances. There is no sealed compartment in a Westy and no upper and lower vented compartment either. To comply you would have to seal off a compartment and then vent it to the outside with upper and lower vents. Then there is supposed to be a an outside door to allow the tank to be turned on/off. The outside door can also be one of the vents. So while it can be done in a safety compliant fashion that is not how a typical Westy owner would do it.
Mark |
Zeitgeist 13 Samba Member
Posted: Mon Sep 14, 2015 9:39 am Post subject: |
I can confirm that it's very easy to overfill those little green propane cylinder. If I do it again, I would weigh a new fully filled cylinder, and then use that weight as my guide regarding proper fill amounts. I was in a time pinch, so I followed instructions gleaned from the interwebz, which stated that you close the tap when it "sounds" like propane has stopped flowing--bad idea. I most definitely would not want to travel distances in high temps with these DIY filled cylinders, as they will in fact vent into the atmosphere _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Sep 14, 2015 11:56 am Post subject: |
Westified wrote: |
Based on this we can't carry the 1 lb cylinders inside the Van unless we make a special vented, sealed cabinet, is that true? I have carried these cylinders, usually 2 inside my vanagon westy and prior to that my bus westy for years. Comments please. |
That is a very good question indeed. I'm kinda curious about that one myself.
It may come down to a "letter of the law" vs "common practice" issue. For example: DOT requires the driver of the vehicle to carry in a readily accessible place a MSDS sheet for every can of wd40, tub of wheel bearing grease, can motor oil etc. and any officer can issue a citation for every single can they find you do not have a MSDS for.
Do they? No.
If you cause an accident and get belligerent they might though...they can.
Neil2 |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2237 Location: Olympia, Washington
Posted: Mon Sep 14, 2015 7:13 pm Post subject: |
1. Did anyone actually answer the OP's question?
2. Is there a pic of the 1lb Coleman can attached under the sink? _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
Posted: Mon Sep 14, 2015 7:47 pm Post subject: |
It was 9 years ago!
Mark
Corwyn wrote: |
2. Is there a pic of the 1lb Coleman can attached under the sink? |
msinabottle Samba Member
Posted: Mon Sep 14, 2015 9:22 pm Post subject: Problem Very Easily Solved |
It's very easy to use cylinders with one's standard propane system. Have a look HERE:
http://www.thesamba.com/vw/forum/viewtopic.php?t=353952
It works quite well and gives utter peace of mind.
Corwyn Samba Member
Posted: Mon Sep 14, 2015 9:59 pm Post subject: |
I just like to stir things up. I was looking for the info and didn't see the answer.
Nine years ago? Is there a date beyond using these threads is inappropriate? _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
~ Captain Ron ~ |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Mon Sep 14, 2015 11:55 pm Post subject: |
Look at the rough size of a small one use propane tank, like a really large coffee cup or small pot.
Would you carry a container of gasoline this size in your car open to the air?
If the valve fails , this is exactly what you are doing carrying around propane.
I've had three valves on cylinders fail in my lifetime.
The other issue about refilling them is that the 25# propane you buy for your grill is wet whereas the disposable grade LP is especially dry, to prevent corrosion of the tank. _________________ .ssS! |
vanagonjon Samba Member
Posted: Tue Sep 15, 2015 8:43 am Post subject: |
Why not just sit a Coleman two burner propane camping stove on top of your stove while is is closed up and use it. Golly, you could even move the stove outside on top of the picnic table at the campground in good weather and stop getting all the hot splashing debris from frying all over the inside of your expensive Westy. |
Posted: Tue Sep 15, 2015 8:53 am Post subject: |
When I lived in my '67 split for a year, I used a two burner Primus stove and those green cylinders. I had installed cabinets from a '78 Bay Westfalia, so I had the stove sitting right where the factory unit would normally reside. Worked perfectly adequate for my purposes _________________ Casey--
y u rune klassik? |
DLJ Samba Member
Joined: August 05, 2008 Posts: 554 Location: North California
Posted: Tue Sep 15, 2015 8:56 am Post subject: propane bottle mounting |
Think about the gas tank just under your passenger!
The sky is falling, the sky is falling!! |
Posted: Tue Sep 15, 2015 11:44 am Post subject: Re: propane bottle mounting |
DLJ wrote: |
Yep, under the car out of the passenger compartment. There is a reason for that.
I would carry new propane cylinders in a car in a prudent location but I would not leave them attached to anything nor leave them in the car long term. Travel to campground, then out they come. Back in the car, then remove at home.
When I removed by soldering head from a tank at home and the valve failed, I had a geyser of LP about 3 feet high. If that were in the car, Im don't know how that ends, but it wouldn't be good. _________________ .ssS! |
