germansupplyscott Samba Member
Posted: Tue Nov 14, 2006 12:14 pm Post subject: Reduction Gearbox Retaining Pin Removal |
i am rebuilding some big nut RGB and i want to remove the pin that retains the axle tube to the RGB housing. it won't budge and is difficult to reach as well, not a straight shot and impossible to use a press to drive the pin out. i am using heat but the bugger won't move even with lots of pounding with a hardened drift and BFH.
i'm looking for any useful tips on getting this pin drifted out. also, are the pins available new? if so i could core drill it and then it should be much easier to drift it out. _________________ SL |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Tue Nov 14, 2006 1:29 pm Post subject: Re: Reduction Gearbox Retaining Pin Removal |
germansupplyscott wrote: |
i'm looking for any useful tips on getting this pin drifted out. also, are the pins available new? if so i could core drill it and then it should be much easier to drift it out. |
The procedure is outlined in the Bentley manual.
Why, exactly do you want to remove it? |
Posted: Tue Nov 14, 2006 2:54 pm Post subject: Re: Reduction Gearbox Retaining Pin Removal |
campingbox wrote: |
bentley isn't much help:
section H-5 pg 2 63-67 bentley wrote: |
8- remove reduction gear case locking pin
i want to remove the axle tubes from the RGB case so i can use the original style (non-split) rubber dust boots.
i figured out how to get the pins out - hit them much harder
they are 10mm straight dowel pins, 50mm long. i think i read something here on thesamba about the pins being tapered, but they are not. they do have 3 slits on one end that are (i reckon) to help keep the pins tight in the hole, but the diameter of the pin is consistent end to end. _________________ SL |
Posted: Tue Nov 14, 2006 4:47 pm Post subject: |
Get some grease and put those boots in warm water, you can get solid boots over the tranny end of the axle tube. |
Posted: Tue Nov 14, 2006 9:08 pm Post subject: |
thanks for the suggestion, i will try that. _________________ SL |
