Daddybus Samba Member
Posted: Wed Nov 15, 2006 2:59 pm Post subject: 944 front discs and fuchs |
Anyone running 944 front disc brakes and Fuch alloys on their bus? Do the spindles interfere with the center caps on the wheels? If so, are there any fixes? Please post pictures if you can. |
happyhippo Segapone Wanna-B
Posted: Wed Nov 15, 2006 4:22 pm Post subject: |
Tony,
I'm running 944s all the way around and 15" fuchs. No problems so far.
Check out this thread for pics:
http://www.thesamba.com/vw/forum/viewtopic.php?t=181068&highlight= _________________ -- Jeff--happyhippo
Look, I'll do whatever you want...Just get that death-weiner away from me! -- Principal Skinner
Never let a stripper clog dance near your dangle. -- Bob Oblong |
shawn63deluxe Samba Member
Posted: Thu Nov 16, 2006 10:55 am Post subject: |
My 944 set up did cause the spindle interfere with the fitting of the centre cap, basically it was a couple of threads too long but I just neatly hacksawed off the last couple of threads to sort it
Oh, i've got 6x16 fuch's in case that matters! _________________ '63 RHD 13 window deluxe
2276 FI Turbocharged.
http://www.ssvc.org.uk/phpbb/viewtopic.php?t=6907 |
Posted: Wed Dec 27, 2006 10:32 pm Post subject: 14's |
FYI
On a split bus, 14x5.5 fuchs will clear 944 discs conversions in the front, but if you have 944 rear discs, then you will need 1/4" spacers in the rear or the face of the caliper will hit the inner face of the rim/hoop. |
mixedup59 Samba Member
Joined: August 07, 2002 Posts: 704 Location: Tacoma Washington
Posted: Fri Dec 29, 2006 2:01 pm Post subject: |
I've got 14x5.5's and 944 brakes all the way around and no spacers on my 23. I used Nate's (wagenswest) modified springplates and a bug tranny. The rear calipers had to be shaved down just a tad to clear. Besides that, it's sweet! _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=355803 |
Posted: Fri Dec 29, 2006 10:06 pm Post subject: 944 IRS |
I'm running an IRS set up with 944 rear trailing arms. Too much grinding needed to clear. Spacers are the nest best option aside from shimming the calipers. |
