slowesty Samba Member
Joined: May 11, 2006 Posts: 63 Location: San Luis Obispo
Posted: Mon Nov 27, 2006 9:58 pm Post subject: thin-lite question |
So, after camping this week for thanksgiving in the cold & wet of N. California, where we spent a considerable amount of time inside the van, I decided my middle light (the one above the stove) is miserable & needs to be upgraded.
Does anyone have any experience with this light?
http://store.solar-electric.com/tl-171.html
I have a fluorescent thin-lite installed by the PO above the engine that I love, and would like to have a similarly bright light above the stove. I searched thesamba and found nothing about thin-lite products, except that MSinabottle dislikes N. Arizon Wind & Sun....
This one looks like it would fit nicely where the current light sits & at 17" would cover quite a bit of territory.
Anyone know anything? |
1621 Samba Member
Posted: Mon Nov 27, 2006 11:26 pm Post subject: |
Looks suspiciously like the overpriced ones I picked up from GoWesty not too long ago... hmmm
http://www.gowesty.com/ec_view_details.php?id=2415&search_phrase=light&start=
I really like having the two flourescents in my 85 over the stock 3-bulb light that sat over the side cabinets/back table. I just wish I had done a little more snooping around. Go for it, you won't regret it.
Lundy |
msinabottle Samba Member
NVVW Samba Member
Posted: Mon Nov 27, 2006 11:45 pm Post subject: |
I put one over the back table and one over the stove and have no regrets. It's not a huge improvement but it is pretty noticeable and well worth the money. |
r39o Samba Polizei
Posted: Mon Nov 27, 2006 11:51 pm Post subject: |
When I get a "round doit," I want 3. Here's some how and why. First I need to see the kids from time to time while driving. I also like a LOT of light. (I have a BIG aux battery.) So since I ditched that stupid stock heater, I still have the switch for it in the front. Wire that to turn an interesting combination of those lamps on. Of course, wire them so you can turn them on with the integral switch too. ( Now I have tons of mechanical work to do before I have time for lamps.) _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Yellow Rabbit Samba Member
Posted: Tue Nov 28, 2006 6:17 am Post subject: |
That looks very much like the stock light in my Wolfsburg Weekender. It puts out great light. |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Tue Nov 28, 2006 6:44 am Post subject: |
Terry sells these light at a reasonable price. I bought three for my 85.
I installed one where the original incandecents three bulb unit was. Second one is on opposite side of van so when you open the slider you can reach up and turn it on to see inside. The third is mounted to the bottow of the rear cabinet on the right side with the switch to the rear. You can open the hatch and light up the back, or when you go to bed you have light. Just the center two units light the interior up plenty. |
tikibus Samba Member
Joined: July 07, 2006 Posts: 834 Location: Rochester, NY
Posted: Tue Nov 28, 2006 8:28 am Post subject: |
Been looking for all sorts of alternatives to the stock lights in the Westy.
Here is one you all might be interested in:
http://www.dyersonline.com/pc-976-92-europa-double-surface-mount-light.aspx
They also carry a one light fixture as well.
Plus there is a product out there called EL wire:
www.worldaglow.com
Do some custom lighting set up for the Van with plexiglass tubing, etc.
Still on the drawing boards.
For plexiglass tubing:
www.curbell.com
Kinda wish to get away from the tungsten and get into LED or some type of lighting that draws very low amperage from the battery.
Not going the route of "Bling-Bling: Pimp My Ride" but rather pleasing indirect lighting.
Has anyone dealt with putting LED's or EL wire into the interior? _________________ Happy Trails!
Mark
______________
Founding member of the Empire State VW Camping Club.
http://www.empirevwcamping.org/
1984 Westy - Tiki
1997 Honda Civic -The Green Hornet
1971 Volvo P-1800E- needs TLC |
r39o Samba Polizei
Posted: Tue Nov 28, 2006 11:54 am Post subject: |
For a work application (replace a floursant tube) we custom made some LED lamps using 15 degree beam width white LEDs. Basically we had two long circuit boards at about 30 degrees or so and that made two long strings of LEDs. We just could not find anything like that, at the time. Now, I bet if you look at the LED lighting places you should be able to find something like that. We used two electrical conduit clamps to suspend them on each end. Pretty cheap, but lots of labor to assemble the protos. It ends up being a bunch of LEDs and resistors inside. I like the light they put out, but they are not something I can get my hands on because they are a custom production item. BUT, I bet some LED light house should have something like that, these days now. We did that two years ago. Guess that is another thing to go investigate.
Like I read somewhere, the Westy is the Swiss Army knife of campers, you just have to get the right stuff to flip out. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
atarasi Samba Member
Joined: October 19, 2004 Posts: 320 Location: Seattle, WA
Posted: Tue Nov 28, 2006 1:20 pm Post subject: |
Wellington wrote: |
Or, you can buy these same exact lights from N AZ Wind and Sun and save yourself $20 per light! Recently bought from them and was pleased with their careful packaging. |
Joined: April 12, 2003 Posts: 1839 Location: Englewood, FL
Posted: Tue Nov 28, 2006 2:28 pm Post subject: |
atarasi wrote: |
Wellington wrote: |
SWEET! Savings like THAT deserves a quick link!!!!!!
http://store.solar-electric.com/tl-171.html _________________ Markus |
