Busdepot Samba Member
Posted: Mon Nov 24, 2014 5:51 pm Post subject: |
Quote: |
BusDepot appears to be out of the Koni shocks for 69 model. |
We were sold out, but we just got them back. Koni agreed to do a custom run of the '68-69 fronts and '68-71 rears for us, complete with period graphics. (To recap, the early rears have slightly different specs and valving due to the type 1 engines reduced weight compared to the type 4 engine.) We also have the later ones back in stock ('70-79 fronts and '72-79 rears). As always, these are not cheap shocks, but between the excellent handling and quality, the adjustable ride, and the lifetime factory warranty they are literally the last shocks you'll ever buy.
Links:
http://www.busdepot.com/801966 ('68-69 front)
[urlhttp://www.busdepot.com/802110 ('70-79 front)
http://www.busdepot.com/801967 ('68-71 rear)
http://www.busdepot.com/802220 ('72-79 rear) _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Mon Nov 24, 2014 6:09 pm Post subject: |
Ron, thanks for letting us know, AND for restocking them! These are one of the few parts out there that pass my quiz:
If something costs three times as much but lasts ten times as long, which is REALLY cheaper?
www.airschooled.com |
Brian Samba Moderator
Posted: Mon Nov 24, 2014 10:07 pm Post subject: |
asiab3 wrote: |
If something costs three times as much but lasts ten times as long, which is REALLY cheaper? |
VW people _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
flat4powerhouse Samba Member
Joined: May 18, 2007 Posts: 27 Location: rapid city sd
Posted: Mon Nov 24, 2014 10:30 pm Post subject: |
Brian wrote: |
asiab3 wrote: |
VW people |
hahahaha so so true, the peoples car _________________ because i live in a bus down by the river
78 bay window truck
68 baja bug |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Tue Nov 25, 2014 12:52 am Post subject: |
Ill get on the boat soon enough.... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
mack00 Samba Member
Joined: October 28, 2005 Posts: 173 Location: marietta georgia usa
Posted: Tue Nov 25, 2014 4:27 pm Post subject: |
Busdepot wrote: |
Links:
http://www.busdepot.com/802220 ('72-79 rear) |
So I have a 69 single cab. Installing a Suby 2.5 DOHC. This engine probably is close in weight to the type 4 engine. Should I consider using the later 72-79 shock in the rear? I would think the rear of a single cab weighs less than a bus/camper. Does this equal out and put me back to the early shock? |
Posted: Tue Nov 25, 2014 5:25 pm Post subject: |
mack00 wrote: |
No easy answer for that one, since Koni didn't differentiate between pickups and Buses. Your single cab is a bit lighter than a Bus in the rear when unladen, but it may be heavier when hauling a full load. If you typically drive it with an empty bed and treasure chest, I'd concur that the extra engine weight is probably offset by the lower total rear weight and suggest the early shocks. But if you often haul heavy loads I'd probably use the later ones. _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
Posted: Tue Nov 25, 2014 8:08 pm Post subject: |
Busdepot wrote: |
mack00 wrote: |
No easy answer for that one, since Koni didn't differentiate between pickups and Buses. Your single cab is a bit lighter than a Bus in the rear when unladen, but it may be heavier when hauling a full load. If you typically drive it with an empty bed and treasure chest, I'd concur that the extra engine weight is probably offset by the lower total rear weight and suggest the early shocks. But if you often haul heavy loads I'd probably use the later ones. |
The later Koni is also 11mm shorter composed, and 20mm longer fully extended, so you SHOULD be fine. I wouldn't go the other way and put an early shock on a late rear end, though.
Someone also mentioned that the rear shock towers were slightly different as well, so I would stick with the '69 shock and adjust it until you find your preferred resistance. See, aren't these things neat-o?
Posted: Wed Nov 26, 2014 6:41 pm Post subject: |
Stuartzickefoose wrote: |
Ill get on the boat soon enough.... |
Pft, I'm going Fox 2.0s. Who needs the torsion bars? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
DougB Samba Member
Joined: January 09, 2007 Posts: 1076 Location: Falls Church, Virginia, USA
Posted: Mon Jun 08, 2015 6:51 am Post subject: |
Just got my Konis installed on my '75 Westy over the weekend My old shocks were definitely gas charged...black...looks like they've been on there a while. I didn't look at them closely enough to see any stamped numbers.
Initial impressions of the ride: it really didn't feel that different at first. I went with the softest setting on the front and one half turn on the rears. There was definitely less lean on turns and then this morning, on the highway, the ride was steady and sure with a tighter feel...much less affected by crosswinds. That said, the ride at lower speeds, hitting potholes and speed bumps, is still quite supple. I also don't feel the car bobbing as much, and maybe there's a bit less dive with the brakes.
I got mine from ShockWarehouse.com and think the deal was pretty good. It took them maybe a week to get them in the mail.
- Doug _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
A very, very understanding wife |
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1399 Location: Cambridge, MA
Posted: Mon Jun 22, 2015 3:55 am Post subject: |
I put the Koni's on the front a few days ago. Gonna do the rears eventually, but I need to set aside the time to do the torsion bars as well (currently running coil-overs in the rear).
The old front shocks where maybe original... black Boge shocks made in "West Germany". They still had good resistance throughout the full stroke and didn't seem obviously worn out. But the Koni's make a huge difference. I set mine at one half turn. Ride on the highway is much, much improved. Straighter tracking, less affected by wind, less brake dive, and still pretty supple over bumps although more "new Mercedes" than the previous "old Cadillac". A worthwhile improvement. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Mark70baja Samba Member
Joined: August 13, 2008 Posts: 152 Location: Heron, MT
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Mon Jun 22, 2015 11:37 am Post subject: |
Vanagon shocks are different than Bay Bus shocks. |
Xevin Samba Member
Posted: Mon Jun 22, 2015 11:45 am Post subject: |
I read these shocks are wonderful. I get it. Bus gets used only for camping and day offs. Mostly 6 months a year. I'm not usually thrifty on parts but 4 bills on shocks seems steep. Is there a less expensive shock worth looking into? I only average about 3500 miles a year. The KYBs on there now seem OK.
I run sway bars too. Just thinking budget might be better spent on essentials. Apologizes if this is the wrong place to ask. Thanks.
72 Campmobile. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Mon Jun 22, 2015 12:10 pm Post subject: |
Xevin wrote: |
72 Campmobile. |
I really think the Monroes sold from FLAPS are worthwhile if you want something cheap and decent for a "weekend ice cream car". I didn't love them off road, but the Konis were a surprisingly anti-climactic upgrade compared to them. I think it's around $80 for the whole bus.
CAVEAT! Some people report them being too short in the rear. I installed them with the bus off the ground last year on a '76, and they fit fine. YMMV.
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Mon Jun 22, 2015 8:34 pm Post subject: |
Xevin wrote: |
72 Campmobile. |
I'm thinkin of trying bilstein I saw them for about $75 a pop. They made a huge improvement on my bug. |
static Samba Member
Joined: March 22, 2002 Posts: 1831 Location: The High Desert
Posted: Mon Jun 22, 2015 9:02 pm Post subject: |
Xevin wrote: |
Is there a less expensive shock worth looking into? |
I'm pretty happy with my KYB GR2s
(A lot happier than I was with the KYB Gas-Adjust) |
Posted: Tue Jun 23, 2015 9:32 am Post subject: |
Xevin wrote: |
Is there a less expensive shock worth looking into? I only average about 3500 miles a year. |
I've been happy with the Boge/Sachs "High Performance" rear shocks I got through BusDepot (http://www.busdepot.com/211513031rhd) and the NOS VW/Boge front shocks I put on a couple of years ago, and I daily-drive mine.
Before that I was running KYB GR2's up front with Gas-A-Justs in the rear, which was "conventional wisdom" around here for quite some time .. and while I thought the front was fine, I *hated* (absolutely HATED!) the rears. Way too stiff and bouncy IMO, and I would have taken them off years earlier if I'd had anything to put on in their place... |
Posted: Wed Mar 01, 2017 7:03 pm Post subject: Re: The KONI Shocks have arrived! |
If you've been thinking of upgrading to Koni's this may be the time. Koni is running a $50 factory rebate on a set of 4, and I have confirmed that they will honor the rebate on '70-79 font and '72-79 rear Bus shocks purchased through us even though they're not a normal production shock for Koni. That would be these ones...
The earlier ones are a bit murkier. Those are officially a Bus Depot only product (meaning they won't do custom runs for anyone else regardless of quantity). Technically the terms of the rebate are that custom shocks like these qualify for the rebate IF they appear in the Koni online catalog at koni-na.com. Which these do. However Koni has said they did not intend to include them and plan to remove them from the e-catalog during the rebate period to avoid paying out. As of this posting they're still there, but even so it wouldn't shock me if the rebate center gave you a fight over it (and I couldn't guarantee a win, even though you'd have a good argument as per the rebate terms). Therefore we're not mentioning a rebate for the early ones. However if you were planning on buying them anyway, if it were me I'd submit the rebate form and a screenshot of the e-catalog listing, as the worst they can say is no. As another alternative, if you have a '70 or '71 you could use the '72 up rears, as they will fit (and are confirmed for the rebate) only the valving is slightly different to compensate for the heavier Type 4 engine.
Anyway, I don't see Koni ever dropping the price on these Bus shocks (to the contrary they seem to go up every year, and at some point will probably go NLA entirely), so a $50 rebate is probably the closest thing to a price reduction you're ever likely to see. _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
