BillyRx Samba Member
Posted: Thu Nov 30, 2006 7:07 pm Post subject: Oil Pump studs |
Hey has anyone removed oil pump studs? How are they installed and is it difficult to remove then. Any help would be appreciated. Thanks I'm doing my first rebuild of an old 40hp motor. _________________ 63 Ragtop Beetle
63 Ragtop Beetle Ruby Red
63 double door panel |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Thu Nov 30, 2006 7:11 pm Post subject: |
It shouldn't be hard at all. I just double-nut them to remove & install them. _________________ www.zwerks.ca |
Posted: Sat Dec 02, 2006 1:26 pm Post subject: |
Thanks Mark they came right out. Will be putting in 37mm studs so I can torque the nuts down to spec. _________________ 63 Ragtop Beetle
60sunroof Samba Member
Posted: Sun Dec 03, 2006 3:44 pm Post subject: |
BillyRx wrote: |
Thanks Mark they came right out. Will be putting in 37mm studs so I can torque the nuts down to spec. |
37mm? |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Sun Dec 03, 2006 4:18 pm Post subject: |
he probably put in a HD pump that's thicker, and needed longer studs so he could get the nuts on all the way. |
65BAJA Samba Member
Joined: October 07, 2003 Posts: 660 Location: SHINGLE SPRINGS,CA
Posted: Sun Dec 03, 2006 9:13 pm Post subject: |
Where did you get those studs? I have an H case with the small short studs and they don't fully stick through the HD punp on the motor. _________________ All the good deals in the world will still make you poor.
I'll finish it!... Some day....
Edit, I started in 2003 and still haven't built a driving Baja. lol |
Posted: Mon Dec 04, 2006 6:13 am Post subject: |
Napa has the 37mm studs or they can order them for you _________________ 63 Ragtop Beetle
Posted: Mon Dec 04, 2006 8:20 am Post subject: |
the last time I needed some longer M6 oil pump studs, I just bought some long fully threaded grade 8.8 bolts at the hardware store and cut the heads off, and cleaned then up with a tap. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Tue Apr 16, 2019 11:30 am Post subject: Re: Oil Pump studs |
How are the oil pump studs supposed to be. Are the stud holes blind such that the stud will bottom out?
I got my long block back from a rebuild and noticed the studs were at different protruding lengths.
I contacted the builder and he said the case was already like that and it was fine.
Should I double nut them and try to turn them in like the closest one? The picture doesn't really show that good but one is really far out, one next far out, one medium, and one close.
I don't recollect seeing them ever stick out this far on other engines. |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Tue Apr 16, 2019 3:37 pm Post subject: Re: Oil Pump studs |
No, you were already told they are not blind hole, and you risk running the stud past the opening and into the cam. You only need like 3 threads for full strength. _________________ foam cowboy hats aren't good helmets. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Tue Apr 16, 2019 3:39 pm Post subject: Re: Oil Pump studs |
Wait till you put the tin on and then the pulley. From the length of these I suspect the pulley will rub. _________________ Glenn
Member #1009
#BlueSquare |
BarryL Samba Member
Posted: Tue Apr 16, 2019 6:35 pm Post subject: Re: Oil Pump studs |
tripicana wrote: |
No, you were already told they are not blind hole, and you risk running the stud past the opening and into the cam. You only need like 3 threads for full strength. |
I know, I'm sorry. I just cut and pasted my original question here. Just trying all sources of experience regarding if the threads came out during disassembly so I can fix it now. I wouldn't just screw them in without taking them out and measuring with a probe first anyway now that I know they aren't blind. They are the original studs so I just didn't think VW would leave them sticking out that far nor that random. |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Apr 17, 2019 9:57 am Post subject: Re: Oil Pump studs |
What size pump? A 30mm pump on a 40 horse case is not a good idea IMO. Probably 26mm max. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed Apr 17, 2019 2:20 pm Post subject: Re: Oil Pump studs |
I recommend a combination pump/oil filter unit. I have them on both my 1600cc and 1835cc engines in my VWs (almost 40 years on the 1835cc engine). They will fit 40hp engines too. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
BarryL Samba Member
Posted: Wed Apr 17, 2019 6:34 pm Post subject: Re: Oil Pump studs |
Pruneman99 wrote: |
Don't know the mm number of the pump but he said stock. It is an H case 1500 with 1600 barrels and stock all else. The studs are the larger later diameter ones and were not added. |
BarryL Samba Member
Posted: Thu Apr 18, 2019 9:24 am Post subject: Re: Oil Pump studs |
Since the case is not blind holed and oil is sitting inside there what keeps oil from coming out the studs' threads as all there is is a wavy washer and nut unlike the oil screen cover that has copper washer and cap nut? I know thread locker or sealant but that stuff is not a perfect seal. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Fri Apr 19, 2019 11:00 am Post subject: Re: Oil Pump studs |
The oil is not under pressure behind the studs so it seeps down to join the river from the crank seal blowng back under the engine. Just stops rust.
My OG AS41 and AS21 cases both were drilled through.
My 2018 vintage Autolinea AS21 has blind holes .. which confused me when the bolts stopped going in on a CB Maxi 3 when the cover was about 0.05 inch short of being on the pump.
Lots of oil on the ground and no pressure...
Then had to hack the ends off the bolts in the field where I fitted the pump..at a Techenders VW T2 aircooled technical, camping and drinking weekend in the UK. _________________ Ancient vehicles and vessels
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Fri Apr 19, 2019 1:59 pm Post subject: Re: Oil Pump studs |
BarryL wrote: |
I used the nuts from ACN.net that has the little rubber seal at the bottom and pulled the studs and put Teflon sealant on them (loctite 567 iirc) . Just Incase. |
BarryL Samba Member
Posted: Sat Apr 20, 2019 10:12 am Post subject: Re: Oil Pump studs |
Thank you all for the knowledgeable answers. |
