volksaddict Samba Member
Posted: Thu Nov 30, 2006 8:12 pm Post subject: grinding this bondo out smells like ass |
No it don't. It's worse. I know stink, killed half a dozen skunks this year, damn varmits trying to get my chickens, but this is worse. Don't last as long as skunk but dammit, bondo shouldn't smell like this. It's kind of femmy, a little sweet, but mixed with gym sock. Like your grandma's orthopedic sock a month after she broke her hip. Like the old lady's room at the old folks home. It's a smell that says you shouldn't be here; about to see something that will scar you for life. It's a really scary smell. And the high temp was 26 degrees today, no heater in the shop 'cept a little space one. Do I open the doors and freeze or brave the stink? Help! Make it go away! |
inthecurl Samba Member
Posted: Thu Nov 30, 2006 8:27 pm Post subject: |
If your not using a filtered (cartridge) mask, be warned!! Bondo dust can cause SERIOUS (lung) health problems. Also using a mask blocks out some of the smell, and yeah, it stinks!! |
Obsessed Samba Member
Joined: January 16, 2003 Posts: 217 Location: Wyoming
Posted: Thu Nov 30, 2006 8:37 pm Post subject: |
If you are using a grinder, you are actually melting it, that could explain the stench. use a heavy grit paper, 36 or 40 on a DA or a 8" mud hog if you have access to one. it will heat up, so be careful about panel warpage. _________________ Volkswagens are life, everything else is just details. |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Thu Nov 30, 2006 10:43 pm Post subject: |
Feh, you don't know what a horrid stench is unless you've ground bone. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Fri Dec 01, 2006 12:38 am Post subject: |
I've used a sanding disc on my angle grinder to remove filler but most often I used an angle grinder with a twisted wire wheel on it and it works great. Just don't breathe the crap. |
Posted: Fri Dec 01, 2006 5:37 am Post subject: |
Using the usual 8" angle grinder w/ a 36 disc, just a particle mask. It's not like throw up putrid, not like the bone meal plant in a small town in Iowa, just not right. All the bondo I've ground, and that would be a lot over most of 30 years, smells like , well bondo. A paint or primer like smell, resin, a body shop smell. This stuff makes my shop smell all fufu, as mentioned before. It's not burning, panels aren't warping, the 1/2" layer over crappy rust patches is comming off in piles of 36 grit dust on the floor. I will be burning some of it when I cut out the really bad parts. Maybe I should dump the old gear oil out of the tranny laying next to the project to combat the smell. |
Matt K. Paint and Body Nutcase
Joined: January 14, 2005 Posts: 2598 Location: Hemet, So Cal.
Posted: Fri Dec 01, 2006 7:17 am Post subject: |
Check my "Sticky" for a way to remove filler.............if the stink is really bad buy some ground cinnamon and smear it on the filler beforeyou grind on it and it will smell like grandma's hot apple cider.............. _________________ This is my 23rd year in the Auto Body/Paint Game!
*Take a look at some of my custom paint: http://s110.photobucket.com/albums/n119/mrpaint_2006/ .( NOTE: these are some older jobs but still neat.) |
Tim10 Samba Member
Joined: April 06, 2004 Posts: 1433 Location: Minneapolis
Posted: Fri Dec 01, 2006 5:40 pm Post subject: |
Cross your old ladys legs _________________ Dub Infested- PART WI$H LI$T-CLICK |
diy570 Samba Member
Joined: September 19, 2003 Posts: 1062 Location: Maggie Valley, NC
Posted: Fri Dec 01, 2006 6:32 pm Post subject: |
yeah dustbusting is great fun, and it only stinks for a little while. after you do it everyday for a few years, you won't really smell much of anything anymore.
itchy eyes, dried up hands, blue, green, or pink boogers coming from your nose, bloody noses, constant sniffing, accusations of being a coke head. it's all in good fun, right......... |
