'63 body swap to '72 pan - (lots of pics)
atye
atye is offline
PostPosted: Fri Dec 01, 2006 11:57 am    Post subject: '63 body swap to '72 pan - (lots of pics) Reply with quote
Here's some pics of the process as i did it...
10-20-05
Day #1
$2500
1963 VW Beetle - 40hp
an average "driver"
This is not a show car, nor will it ever be one. I wanted to build a reliable daily driver that I won't be scared to take anywhere. I could have spent a ton of money and time on this stuff, but I did a solid job that should last a long time.
This is the '72 IRS pan I had to work with (meaning FREE)
Wink
cutting the rusty half off
done with the hard part
welding the new half in
(using the ever-popular "point and squint" method)
and the early model seat rails
(1971-72 rails will not work with early lowback seats)
Rolling Eyes
new seat rails welded, seam-sealed, and painted
coating the pans with Duplicolor truck bedliner coating
I used some cheap paint brushes, but now I've found they make a spray gun kit just for this stuff Rolling Eyes
done
finally together
this was an early "test fit"
you can see how much difference there is in height on the rear
this is the rear body mount on the IRS shock tower
it is 1-2" too tall for the early body, but dead on as far as alignment goes
as my car was a little rusty and will need bodywork in the future, I removed the body mounts for now and will re-install them ASAP.
and with the rear mounts removed for now
now it's mainly the engine I'm concentrating on...
Sorry for the long post, but I wanted to show an idea of what all is involved in this. It's not hard, it's just time-consuming. I had to do most of the work at a friend's house on weekends and that in itself slowed me greatly.
If anyone has any specific questions, let me know. This was the second pan swap I've done. I did a '63 convertible on a '64 hardtop pan about 15 years ago.
Alex
Alex
1968 VW Beetle (Class 11 look-alike project)
2004 Kawasaki ZG1000 Concours
2005 BMW 330ci convertible
sammyphsyco
sammyphsyco is offline
PostPosted: Fri Dec 01, 2006 12:13 pm    Post subject: Reply with quote
Just curious what was wrong with the O.G. swing pan? I would have thought it easier to convert swing pan to I.R.S. rather than swap pans. What did you do about vin#'s and title?
sammyphsyco wrote:
Your just jealous the voices are talking to me
makinbakin
makinbakin is offline
PostPosted: Fri Dec 01, 2006 12:14 pm    Post subject: Reply with quote
say it aint so.....
OST KÜSTE
atye
atye is offline
PostPosted: Fri Dec 01, 2006 12:19 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?p=1907768
(from my previous thread)
Well, the pan on the '63 was HAMMERED. I mean it was in sad shape. The frame head was welded on after what seemed to be a hard front hit. It was done so poorly that:
A) the front beam had some sort of reinforcement bars, almost like subframe connectors running from the torsion bars to the pan
B) the whole beam was actually re-welded about 2"-3" towards the rear from the original spot. You could tell by the paint overspray where the shock tower USED to be.
C) the front left king/link pins were way beyond shot.
D) The PO had installed rubber 3/8 fuel line OUTSIDE the pan, along the running boards, held up with cable ties. This was not done recently, either, looked like maybe 5-10 yrs ago.
I will say, however that as bad as the pan looked, the body is not bad at all. Someone must have welded a whole front clip on or something, but there is only a light crinkle in the front spare tire well, maybe even from a later bump?
I had a 1972 body with a halfway decent pan sitting w/o a motor.
Also, for a daily driver, I prefer the IRS and BJ combo. I've got adapters so that I can run my American Eagle Fuchs wide-5 replicas, so after it's all said and done, it should still look like it did before.
Alex
makinbakin
PostPosted: Fri Dec 01, 2006 12:24 pm    Post subject: Reply with quote
why not just find another linkpin pan? IMO i would rather have it on the same type pan it came with.
OST KÜSTE
atye
atye is offline
PostPosted: Fri Dec 01, 2006 12:30 pm    Post subject: Reply with quote
and as for the VIN and title...
Doesn't GA have a "don't ask, don't tell" policy??
Wink
I'm just gonna take my chances. I don't have a title, just a bill of sale (perfectly legal on older vehicles here) and I can't think of a reason why it would ever be a problem. The body number is still legible and I'll just leave it on the books as a '63.
Alex
makinbakin
PostPosted: Fri Dec 01, 2006 12:38 pm    Post subject: Reply with quote
Wink
if you ever want to sell, it may be hard to find a buyer with mismatched numbers. Wink
OST KÜSTE
atye
atye is offline
PostPosted: Fri Dec 01, 2006 12:43 pm    Post subject: Reply with quote
IF... I ever decide to sell, I'd advertise the car as a '63 on a late model IRS pan. I'm not breaking new ground here. I think it's been done once or twice.
Wink
Alex
Rome
Rome is offline
PostPosted: Fri Dec 01, 2006 12:54 pm    Post subject: Reply with quote
You work dang fast! BUT you might kick yourself in not replacing the front-to-rear brake line (left side of tunnel) and the short cross-piece at rear (goes over front of tranny) while you had the body off, expecially considering how rusty the pan half was. You'll never have such easy access, and it would've been a prudent preventative measure that would';ve only take you a few hours at most.
I hope brake line rust does not happen for your sake!
"a little rusty"?! WHERE? Your cars in the south are so much more solid than up here in the north, though I have been in junkyards in coastal Florida where there was alot of rust on VWs.
Wishing you lots of fun driving the Beetle! Are you considering going to front disc brakes (Ghia parts) now, even if you keep 4-bolt wheels?
atye
atye is offline
PostPosted: Fri Dec 01, 2006 1:18 pm    Post subject: Reply with quote
One of the first investments after I get the motor squared away is DISC BRAKES. I had them on my last beetle, a 1969, and it was the best money I ever spent on that car. I think with the larger engine, I will need all of the help I can get in stopping the car anyways. I plan on keeping the wide-5 wheels I have, too. The ones that were on the '72 are some sort of 13" wheels off of a Honda or Golf with adapters. They are only temporary.
As for working fast, that was a "weekend job" that turned into 6 months.
Rolling Eyes
I have new rubber lines for the front AND rear now, just haven't gotten to the brakes yet. Working in a parts house as I do, I try my best to have everything in good working order.
By the way... NAPA has a new line of steel brake lines that are incredible! They are coated in such a way that you can bend the steel lines by hand w/o kinking, bend them back flat, and do it all over again. The coating is also a rust barrier. I have had a sample in my store and it's amazing. I plan one day down the road to replace all of the lines, but that's way down the road.
Alex
jaxvert
jaxvert is offline
PostPosted: Tue Dec 22, 2009 7:25 am    Post subject: Reply with quote
Great post Alex. the pictures help.
1963 Original Anthracite L469 vert.
1963 Ragtop (stolen years ago) low life fuckers !
Jason C
Jason C is offline
PostPosted: Wed Dec 23, 2009 6:49 am    Post subject: Reply with quote
Wink
Here, the title goes with the pan. DMV doesn't even check the body #'s. It would actually be listed as a 72 with a 63 body.
Throw me a bone here. All I wanted were
sharks with friggen laser beams attached to their heads.
64 Bug
atye
atye is offline
PostPosted: Wed Dec 23, 2009 7:19 am    Post subject: Reply with quote
In my 25+ year experience driving here in GA, I have never had the DMV (or the local county tag office) ever physically look at anything I have ever registered. They have made a question here or there, but as long as the paperwork seems to be "OK" they have always put it through.
Smile
Alex
