Herbst '71 Samba Member
Joined: April 14, 2004 Posts: 245 Location: Augusta, GA
Posted: Mon Dec 04, 2006 8:28 am Post subject: Adding Blower Motor in Engine Bay (Please expose all flaws) |
The temperature of the heated air in my 1971/1600 DP is acceptable. I still need to clean out the ducting. I am trying to increase air movement at idle with a blower motor from a 77. The goal is to tie the blower motor hoses into the current fresh air hose before they leave the engine bay or as close as possible to where the enter the heater boxes.
I am also looking at routing the ducting for the blower motor up the fresh air intake on the left side of the bus and pulling fresh air from the left side of the cargo bay.
Questions:
Will tying the second set of hoses into the current fresh air tubes completely destroy the air flow?
Does the booster fan push enough air to force warm air back into the fan shroud?
Will routing the ducting up the fresh air intake obstruct the air coming into the engine bay? (VW did not put it there and I would hate to discover the tolerances are so small that I cook my engine.)
Should the project be abandoned all together? (I could always inform the passengers that if they are uncomfortable with the temperature in the cabin, they can put on a jacket or walk)
Here is a diagram of what I am thinking about doing.
https://www.thesamba.com/vw/gallery/pix/319225.gif
Thanks for reading and tearing it apart _________________ Rik
'71 Deluxe/1600 DP
"Fortunately my mistakes are serving as a warning for others." |
Posted: Mon Dec 04, 2006 10:36 am Post subject: |
I would think your best bet on a Type 1 engine would be to install a 3" bilge blower in each of the flexible duct between the cooling shroud and the heat exchangers. This would boost pressure which will in turn increase flow at all engine RPM's. |
Posted: Mon Dec 04, 2006 10:43 am Post subject: |
I had not thought of that.
Rik _________________ Rik
'71 Deluxe/1600 DP
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Dec 04, 2006 11:05 am Post subject: |
A later blower might help with airflow at idle but it will never equal what your engine fan puts out at speed.
If you were to tee it into the cold air pipes you would probably need anti return flaps upstream from it like the later ones have.
I tried the bilge blower and it helped a little (more noise than air), mount it as far forward as you can to avoid melting it and make sure all the leaks in your heat system are sealed.
A steel squirrel cage blower from a 60's car (I used one from a Datsun roadster) makes ALOT of air and really makes the heater effective (quiet too). I mounted it near the front of the center heat tube with some 3" pvc sewer elbows, duct tape and plumbers strap. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jered Samba Member
Posted: Mon Dec 04, 2006 1:16 pm Post subject: |
I put a 4" bilge motor in my heater channel under my bus... blows 250cmf...
believe it or not, it blows as much as the engine fan does at abour 3500 RPM...
Now to find a good set of german heater boxes... I'd be smoking myself out...
I have posted pictures of it before... and I can tell you that the squirel fan on my 77 does nothing compaired to the 4" bilge fan...! which IMO is a much better option... _________________ No VW right now.... |
Duncwarw Samba Member
Posted: Mon Dec 04, 2006 2:28 pm Post subject: |
Bilge blowers don't push well.
Put them inline, as they're designed for, and they can really up the pressure. The problem is the low melt point and the noise.
I wouldn't even bother with the factory squirrel cage fan if I were in your shoes.
If you opt for something other than the factory hoses to push air, just block off the outlets on the shroud so your cooling air stays where it should be. _________________ “To find yourself, think for yourself”
Socrates, 470 BC - 399 BC |
Posted: Tue Dec 05, 2006 5:28 am Post subject: |
Dunc,
I had thought about blocking off the fresh air tubes at the fan and going with a bilge like you have on your website. It looks like it is in the housing of the factory blower. Did this set up push a more noticeable amount of air?
'71 Deluxe/1600 DP
Posted: Tue Dec 05, 2006 6:59 am Post subject: |
No.
Bilge blowers are designed to boost pressure inline.
I took it out of the engine room and put it inline again.
The factory squirrel cage fan is now feeding the left exhanger alone.
I updated the write-up within the last couple of days.
Refresh on your next visit, that might make a difference.
I'm getting a lot of heat now. Not SO hot up front but a huge amount of warm air. The real heat comes from the back vent, about 235F last time I checked. I'm waiting for a freezing day to test and post the results but it was 36 yesterday and I was driving around in a tee shirt.
If you click on "Audio" on my site, you can hear the blower in action.
Silly, right? _________________ “To find yourself, think for yourself”
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Tue Dec 05, 2006 8:01 am Post subject: Re: Adding Blower Motor in Engine Bay (Please expose all fla |
Herbst '71 wrote: |
Questions:
Thanks for reading and tearing it apart |
I implemented a similar project, on my British specification, 1973 VW 1600 Type 2 Westfalia, using some home-made, 55 mm to 50 mm & 60 mm to 50 mm, GRP Y-junction, air-duct-hose adapters and an engine-compartment, ceiling-mounted, electric booster fan, salvaged from a 1976~79 VW 2000 Type 2, in South Africa
To answer your questions:
No.
This could only occur at low engine revs, such as when idling and I doubt whether it would have an adverse effect on engine cooling.
It will to some extent, but remember that the VW factory did something similar, with regard to recirculated fresh air, supplied to the engine-compartment mounted, Eberspächer BN4 gasoline heater.
I would not necessarily abandon it, but be aware that volumetric air-flow rate, will not change noticeably at high engine revs, but it will give greater air flow when stationary or when crawling along in a traffic jam. The main advantage, is likely to be the recirculated warm air, from inside the passenger cabin.
Regards.
Nigel A. Skeet |
rcnotes Samba Member
Joined: July 09, 2005 Posts: 641 Location: Ann Arbor, MI
Posted: Tue Dec 05, 2006 12:36 pm Post subject: |
Does anyone use or have info on a bigger heating blower, one with more capacity to replace the stock squirrel cage??
I imagine someone has tried a larger blower in the stock position. The problem with that is that you're only moving more air, not heating it any more than would happen with the stock blower. In fact a larger fan with more velocity (and cfm) might not heat any better.
The big problem with blower heat is that the blower uses 100% untempered outdoor air (from the engine compartment). That system really needs a return air duct from the cabin to the blower inlet for the heat to work at temps below 20 degrees. Even a smaller duct that mixes with some OA would help. The problem with installing a return duct is getting it through the tin, either under or through the rear firewall on either side of the gas tank or perhaps through the spare tire pocket.
I sit and think about this situation. One of those blank stare kind of thinks. |
Posted: Tue Dec 05, 2006 12:45 pm Post subject: |
With the stock system as it was designed, all you need is more air flow as it gets plenty hot. When mine was as set-up by the factory, I always had 170-190F at the defrost vents.
The problem with the factory blower is that it simply can't produce enough pressure to give you that blast of heated air up front you experience in other (water cooled) vehicles.
Many people apparently add an inline bilge blower. The problem there is the high temperatures in the heating system exceed the capacity of the blower and it melts (not to mention the noise).
Bluebird in the UK sell a blower that is said to deal better with the temperatures. I was unable to find a similar product here so I took another approach. See my site for more. _________________ “To find yourself, think for yourself”
MrBreeze Samba Hitman
Joined: October 06, 2002 Posts: 5537 Location: Lawn Guyland, Noo Yawk
Posted: Tue Dec 05, 2006 2:04 pm Post subject: |
I've had the same 3" bilge fan in my bus for 5 years now and no hint of melting. I have it inline in the hose up front that feeds the front vents. A tad noisy, but it does a great job pushing the air.
Another thing I do when it's really cold is use a curtain rod behind the front seats and hang a blanket. Then I'm only heating the front cab. I lose the rear window, but no big deal. I may make a cab divider this year so I can put a plastic window in. _________________ -=Rob
WTB: Bay Shore or Queensboro VW Frames
HBB 1984-2009
RW 1943-2011
ER 1964-2023 |
Posted: Tue Dec 05, 2006 3:06 pm Post subject: |
Maybe it's a model year thing, but my heat WAS way too hot for a blower. Amskeptic has a '73 also and I recall hin reporting similar temps to mine.
Splitting my system allowqed me to use the blower.
It would e interesting to read temp reports for the various model years.
I keep reading the 73/4 exchangers were the best for heat... _________________ “To find yourself, think for yourself”
Brian 11 Samba Member
Joined: September 02, 2006 Posts: 158 Location: Jacksonville Florida
Posted: Tue Dec 05, 2006 5:45 pm Post subject: |
Here is a place for an in line : http://www.800luvbugg.com/shop?frame=5.54.6320 _________________ I CAN MAKE IT UP THIS HILL IN 4TH GEAR I CAN MAKE IT UP THIS HILL IN 4TH GEAR
My Fleet:
1972 BAY Flash Back
1963 Beetle Nana's Little Bug
1977 Ford F100
1972 Nova
No computers, No abs. Yea! GOTTA LOVE THE OLD STUFF!!!
If everything I tell you is a lie and I then tell you I'm lying, am I? |
Posted: Tue Dec 05, 2006 9:26 pm Post subject: |
We've gone full circle.
A hundred bucks for a twenty dollar bilge blower and a switch.
If you fix your heat, you can watch your $99 melt. _________________ “To find yourself, think for yourself”
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Tue Dec 05, 2006 10:21 pm Post subject: |
Best to add boosted air before the exchangers, downstream runs the risk of sucking in exhaust.
One way flaps in the fresh air outlets of your Type 1 engine would help prevent the blower from losing boost to the cooling fan housing. The blower should already have flaps.
I do not recommend taking inside return air. Each cycle of air can increase monoxide danger.
If you do not have flow-through vents in your doors (pre-71) the blower will not work as well until you crack a window.
The heat exchangers on a Type 1 bus engine will not give you very good heat with boosted airflow at idle, unless you have the 5*ATDC timing specification with a dual advance distributor. That retard at idle does an excellent job of heating up the exhaust pipes.
Colin _________________ www.itinerant-air-cooled.com |
Posted: Wed Dec 06, 2006 5:41 am Post subject: |
I am in luck. I have a dual advance distributor timed at 5*ATDC. I do not have the flow through vents in the doors, but my vent windows never close all the way so I am getting some air entering the bus.
The recirculating idea may be pushed aside. Thanks for everyone's advice. I think we should end this thread before we repost everything that has been posted.
For anyone who is still looking for heat ideas, searching the posts will provide a wealth of information. Also, check Dunc's website for some ideas.
Thanks,
'71 Deluxe/1600 DP
Posted: Wed Dec 06, 2006 7:51 am Post subject: Adding Blower Motor in Engine Bay (Please expose all flaws) |
Amskeptic wrote: |
Colin |
From what I've read in my text books on HVAC and dust extraction, it is preferable to have booster fans staggered through the duct system, so that there is a recovery in static pressure. It also reduces the overall cold-air ingress and/or hot-air leakage, through any remaining imperfections (after you've finished insulating & caulking the factory-finished system) in the ductwork.
British specification, 1968~79 VW 1600 Type 2s and 1972~79 VW 17/18/2000 Type 2s, do not have dual advance distributors, on any model year, as far as I'm aware!
If there is engine-exhaust leakage, from the exhaust system into the heating system, recylcing some air from the passenger cabin, is unlikely to increase the risk of carbon monoxide poisoning, but one might notice the effects slightly earlier.
Regards.
Nigel A. Skeet |
Posted: Wed Dec 06, 2006 9:44 am Post subject: |
ALWAYS remember to check the ratwell site
http://www.ratwell.com/technical/Heating.html _________________ -=Rob
HBB 1984-2009
RW 1943-2011
ER 1964-2023 |
Posted: Wed Dec 06, 2006 10:28 am Post subject: |
Amskeptic wrote: |
Colin |
I have wondered how much affect this would have. My system is in good original condition with extra insulation in places, but my temperatures are still limited. Only about 170F at the ducts on a 40° day. Placing my hands on the pipes running up to the heat flappers tells me that I am not getting very hot air out of the exchangers to begin with. Don't have a double vacuum dizzy that is any good lying around, but will keep my eyes open for one.
The double vacuum dizzy might make a big difference on decel as well as at idle. |
