Problems during oil change
Godsbug
Godsbug is offline
PostPosted: Sat Dec 09, 2006 1:46 pm    Post subject: Problems during oil change Reply with quote
I'm changing my oil in Anne the notch and I found this in the filter. The oil in the bottom was a silvery black, but the engine has about 3k miles on it, is that a problem, or expected? What do you think, do the pieces in the oil mean problems? What is this stuff from?
Other side of black thing
It's kind of hard to tell in the pictures, but the bottom pic of the black thing is concave.
2017 Golf Alltrack
2011 Fit
1968 Fastback
Matt Wilson
Matt Wilson is offline
PostPosted: Sat Dec 09, 2006 2:00 pm    Post subject: Reply with quote
the washer looks like a pice off of the rockers, happened to me before, look in the valve covers, and you might fins the other half of it. You will probably need to find another washer.
1972 Standard Beetle
1969 Baja Beetle
Godsbug
Godsbug is offline
PostPosted: Sat Dec 09, 2006 2:03 pm    Post subject: Reply with quote
The white thing is rubber and has a round cross section. It used to be white.
2017 Golf Alltrack
2011 Fit
1968 Fastback
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sat Dec 09, 2006 2:36 pm    Post subject: Reply with quote
The white thing is an oring that is under the rocker arm on later model heads. No big deal if missing. Maybe a minor oil leak. The black piece may be a piece of what some people consider a valve stem oil seal. Really just an oil wiper. No big loss.
Gary: OK. Ima poop.
Godsbug
Godsbug is offline
PostPosted: Sat Dec 09, 2006 2:38 pm    Post subject: Reply with quote
Cool, thanks. I was concerned.
To hijack my own thread, the starter is crapping out on me. It will turn once or twice and then click a bunch and that's it. I cleaned ALL the connections with a dremel tool with the wire brush end and cleaned the posts on the battery as well. What am I missing or is the starter fried?
2017 Golf Alltrack
2011 Fit
1968 Fastback
Russ Wolfe
PostPosted: Sat Dec 09, 2006 2:46 pm    Post subject: Reply with quote
See what the voltage is at the battery when the clickity is going on. What you discribe sounds like a dead battery.
Gary: OK. Ima poop.
Godsbug
Godsbug is offline
PostPosted: Sat Dec 09, 2006 2:53 pm    Post subject: Reply with quote
To satisfy my curiosity, what make it click when the battery is dying or dead?
2017 Golf Alltrack
2011 Fit
1968 Fastback
nodrenim
nodrenim is offline
PostPosted: Sat Dec 09, 2006 3:17 pm    Post subject: Reply with quote
You may have insufficient voltage to the starter which will cause the clicking sound, because the starter bendix or starter drive as it is sometimes called will not engage. Hope this helps! Good Luck!
Douglife
Douglife is offline
PostPosted: Sat Dec 09, 2006 5:00 pm    Post subject: Reply with quote
the solenoid. A starter solenoid usually takes very little to open(click) but if there isn't enough juice to turn the engine.... click, click, click
Also look at the bendix, the gear on top of the starter, if the edges look warn or hashed it could be the starter is outta allignment and catching on the flywheel. never really seen this in any VWs but it is very common in older chevys.
Godsbug
Godsbug is offline
PostPosted: Sat Dec 09, 2006 5:24 pm    Post subject: Reply with quote
Son of a gun! You guys were right. I charged the battery and she started right up! Thanks!
2017 Golf Alltrack
2011 Fit
1968 Fastback
Dfasty
Dfasty is offline
PostPosted: Sat Dec 09, 2006 5:48 pm    Post subject: Reply with quote
now it`s time to check the charging system
70 fastback automatic 06 invader
Godsbug
Godsbug is offline
PostPosted: Sat Dec 09, 2006 6:29 pm    Post subject: Reply with quote
I haven't driven her in a month or so, so that may be the problem. I've been trying to put some miles on the RSX to get the free oil change at the dealership and I have until next week to do it. I figured I'd drive the Notch before the battery drained but I was wrong. There's a light on the MPH gauge that is always barely on and I haven't gotten around to figuring out why yet so it drains the battery.
2017 Golf Alltrack
2011 Fit
1968 Fastback
Hornman
Samba Soul Surfer
Hornman is offline
PostPosted: Sun Dec 10, 2006 12:23 am    Post subject: Reply with quote
Getting 'er ready for the trip tomorrow? Have fun, drive carefully.
Michael
1969 Fastback
