Bay Window Steve Samba Member
Joined: July 13, 2006 Posts: 280 Location: Van Alstyne, Texas
Posted: Sun Dec 10, 2006 9:12 pm Post subject: Heater box question. |
I searched, and could not find the answer. I apologize if this question is redundant.
I need to replace the heater boxes on my '69. How different are they from the Beetle's as far as size wise? Also, does anyone know who sells the highest quality ones? I don't want to have to replace them again.
Thanks for the info. _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
Original Air Cooler Member |
ronan.b Samba Member
Posted: Sun Dec 10, 2006 9:51 pm Post subject: |
beetle and bus. type 1 1200 to 1600 engine the heater boxes are the same. you'd be best off trying to source some really good original ones if you can. the latest aftermarket/ brazilian/mexican ones have less aluminium fins inside and therefore produce less heat. _________________ my bus came with the optional ferrous oxide performance pack (gets lighter as more rots away, and therefore faster)......
78 nine seater |
VWMIKE76 Samba Member
Joined: February 21, 2006 Posts: 669 Location: lynnwood, washington
Posted: Sun Dec 10, 2006 9:53 pm Post subject: |
the difference between bus and bug heater boxes are where the heater control cables attach, all else fails use bailing wire and just wire the bug boxes wide open. the bug boxes have the attachment at the bottom and the bus boxes are at the top since the cables come oput of the bus much higher. |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Sun Dec 10, 2006 10:00 pm Post subject: |
they make a universal style box with both bug and bus attachments, so you just adapt the correct linkage for your application. _________________ 1972 Standard Beetle
1969 Baja Beetle |
Randy in Maine Samba Member
