Fuel injection relief here!
Page: Previous  1, 2, 3 ... 238, 239, 240 ... 250, 251, 252  Next
gheezerghia
gheezerghia is offline
PostPosted: Mon Mar 26, 2018 11:22 pm    Post subject: Re: Fuel injection relief here! Reply with quote
When i removed my FI manifold today there were no manifold gaskets just hard spacers. Does the manifold require paper gaskets? Thanks
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Mar 27, 2018 7:57 am    Post subject: Re: Fuel injection relief here! Reply with quote
Originally those spacers had a thin paper gasket bonded to them. You can coat them thinly or make a very thin (like newsprint) paper gasket for each side.
gheezerghia
PostPosted: Tue Mar 27, 2018 4:00 pm    Post subject: Re: Fuel injection relief here! Reply with quote
Hey Phil thanks for the reply. Can I use Gasgacinch? Would a gasket out of printer paper be too thick?
KTPhil is offline
PostPosted: Tue Mar 27, 2018 5:55 pm    Post subject: Re: Fuel injection relief here! Reply with quote
You don't want anything that acts as an adhesive, just as a sealant.
Check this thread and the embedded link for a how-to process (though for a different purpose).
https://www.thesamba.com/vw/forum/viewtopic.php?t=693251
gheezerghia
PostPosted: Sat Apr 14, 2018 7:39 pm    Post subject: Vacuum Hose Reply with quote
I don’t know what this part is called but I need to replace the vacuum hose on both sides of it and I’m wondering where to find the correct size hose? Anyone? Thanks, Gregg
Bobnotch
Bobnotch is offline
PostPosted: Sun Apr 15, 2018 9:26 am    Post subject: Re: Vacuum Hose Reply with quote
It's an electric AAR (Aux Air Regulator). I believe the hose size is 12mm ID or maybe 13mm ID I forget. One end goes from the AAR to the bottom of the plenum, while the other end goes from the AAR to the tube on the air cleaner.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
gheezerghia
PostPosted: Sun Apr 15, 2018 3:45 pm    Post subject: Re: Fuel injection relief here! Reply with quote
Bob, Thanks for the reply but that would put it at almost a 1/2”. That would be to big a hose. It’s closer to 5/16”. The problem is that I can get a 5/16” onto the manifold but not onto the AAR valve. Looking to buy the correct hose but not sure where to get it? Thank you
Bobnotch
Bobnotch is offline
PostPosted: Mon Apr 16, 2018 10:42 am    Post subject: Re: Fuel injection relief here! Reply with quote
OK, it's 3/8ths then. I wasn't sure on the AAR end to plenum size. The end to air cleaner is larger.
Tram wrote:
Tram wrote:
Sjvantrease
Sjvantrease is offline
PostPosted: Wed Jul 11, 2018 12:41 pm    Post subject: Re: Fuel injection relief here! Reply with quote
So, I'm new here and not sure how this works, so if I'm in the wrong spot or do something not right please just let me know.
Now. I have a 1970 type 3 fastback fuel injected with a fresh engine rebuild. It startes after a few cranks. And then floods and dies. Any ideas? Fuel pressure is 28, and the regulator is working.
KTPhil is offline
PostPosted: Wed Jul 11, 2018 1:42 pm    Post subject: Re: Fuel injection relief here! Reply with quote
Probably best to start a new thread here in the Type 3 forum for your car. It may or may not be FI related, and that way you con continue with whatever direction your repair goes, without clogging up the FI thread.
Flooding usually comes from vacuum leaks, bad FI wiring, or low voltage.
Tram
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Wed Jul 11, 2018 1:52 pm    Post subject: Re: Fuel injection relief here! Reply with quote
See what the fuel pressure does as it floods and dies.
Bryan67 wrote:
To best contact me, please use the EMAIL function in my profile
OB Customs
OB Customs is offline
PostPosted: Thu Jul 26, 2018 8:53 pm    Post subject: Re: Fuel injection relief here! Reply with quote
This car will be the death of me…So it has always had a cold start issue you have to cycle the key twice then start it holding the accelerator pedal down just a little for a min or two then it will idle on its own. Now that the temps are up here in Washington it has started giving me grief when its above the mid 80’s after a warm up and driving for about 30-40 min it starts to act like it wants to die so you have to feather the accelerator to keep it running and once it about say 1500-1800 it kinda clears out but it almost feels like I’m running out of fuel. It was sputtering and coughing then almost dies. I had my temp gun with me and the engine is barely 180*. Last week it was mid to upper 70’s I drove 2 hrs plus each way to a car show and no issue the weekend before that was 1 hr drive at 96* and it did it then. Any ideas?
fuhq64
fuhq64 is offline
PostPosted: Thu Jul 26, 2018 9:58 pm    Post subject: Re: Fuel injection relief here! Reply with quote
Mine had very similar symptoms last year that progressively got worse as the year went by. In fact, I haven't even got it to start and run on its own since i tried to start it this spring
69 Squareback
Still a n00b
www.instagram.com/fuhq64
Tram
Samba Socialist
Tram is offline
PostPosted: Thu Jul 26, 2018 10:26 pm    Post subject: Re: Fuel injection relief here! Reply with quote
Which injection system?
How do you know it's fuel and not ignition?
Tram
Samba Socialist
Tram is offline
PostPosted: Thu Jul 26, 2018 10:27 pm    Post subject: Re: Fuel injection relief here! Reply with quote
See above.
OB Customs
PostPosted: Thu Jul 26, 2018 10:32 pm    Post subject: Re: Fuel injection relief here! Reply with quote
Sorry 69 D jet, Funny I was thinking ignition tonight on the way home. I just can't seem to find it.
fuhq64
fuhq64 is offline
PostPosted: Thu Jul 26, 2018 10:45 pm    Post subject: Re: Fuel injection relief here! Reply with quote
It fires on starting fluid. Was gonna check fuel pressure once I acquire another gauge
69 Squareback
Still a n00b
Oval1
Oval1 is offline
PostPosted: Fri Jul 27, 2018 9:51 am    Post subject: Re: Fuel injection relief here! Reply with quote
Hey guys, I’m sure it’s in this thread somewhere Shocked Can anyone help me with where to get injectors for my 68 squareback? She’s not feeling so well... Thanks Cool
DLK
gheezerghia
PostPosted: Fri Jul 27, 2018 11:08 am    Post subject: Re: Fuel injection relief here! Reply with quote
No, but that is a sweet car!!!!
Bobnotch
Bobnotch is offline
PostPosted: Fri Jul 27, 2018 11:47 am    Post subject: Re: Fuel injection relief here! Reply with quote
Very sweet looking Square. Cool
Tram wrote:
Page 239 of 252
