Ecasci01 Samba Member
Posted: Sun Oct 06, 2019 5:59 pm Post subject: Re: Fuel injection relief here! |
Have a 71 squareback FI WHEN I TAKE THE FUEL INJECTOR WIRES OFF THERE IS NO POWER there with a test light. Where does the power come from for the fuel injectors? |
Intrinsic Samba Member
Joined: November 16, 2011 Posts: 262 Location: Clearwater, FL
Posted: Mon Oct 07, 2019 8:40 am Post subject: Re: Fuel injection relief here! |
Power for the injectors comes from the ECU, the injectors on each side share a common ground. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Mon Oct 07, 2019 9:54 am Post subject: Re: Fuel injection relief here! |
Depending on the type of test light, the pulse, measures in a few dozen milliseconds, may be too short to light up the bulb filament. |
chaosisme Samba Member
Joined: August 29, 2005 Posts: 1256 Location: Orange County, Ca
Posted: Sat Oct 12, 2019 10:49 pm Post subject: Re: Fuel injection relief here! |
Stupid question but I had all my tin powder coated and Im putting it all back on my engine and Im having trouble getting those little tins that go under the intake manifolds/runners back on. Do they have to be on BEFORE the intakes go on? _________________ '65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's |
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Fri Oct 18, 2019 4:45 pm Post subject: Re: Fuel injection relief here! |
chaosisme wrote: |
Stupid question but I had all my tin powder coated and Im putting it all back on my engine and Im having trouble getting those little tins that go under the intake manifolds/runners back on. Do they have to be on BEFORE the intakes go on? |
If they are the ones that are under the runners I haven't tried they might if the injectors are not installed , I think even then they hit the are with the 2 studs that secure the injectors. I had mine off not long ago yet I put the injectors on first before the runners even so if I recall they won't clear the lower runner boss. I put them it first just loose then the runners . I know the ones with the plug holes can be removed after and before. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Sat Oct 19, 2019 11:43 am Post subject: Re: Fuel injection relief here! |
chaosisme wrote: |
I think so. Even if you just put them there and then do the intake runners.
Just so you know, they're a PIA on dual carb engines too. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Nov 16, 2019 6:54 pm Post subject: Re: Fuel injection relief here! |
Yeah, you're right. I ended up having to loosen the intakes to slip the tins in there. _________________ '65 1500 S [quareback]
'70 Westy
JoMoSqBk Samba Member
Posted: Mon Nov 25, 2019 7:41 am Post subject: Re: Fuel injection relief here! |
4 months, 4 mechanics, and countless hours of reading I finally figured out what was causing my car to lose power and want to die if I didn't hold the throttle down at idle. *Don't take these to a mechanic VW guys try to force carb swaps and regular guys are dumb founded.
I really appreciate all the help in this thread. What helped solve this was as many on here suggest start with ignition. I replaced the plug wires, distributor cap, and rotor. After that I was still having issues, the alternator (generator has been replaced) was weak so I had that rebuilt and the coil was also a little weak so I replaced it. This had me about 25% better but was really where I started to want to pull my hair out.
I pulled vacuum on the MPS and tested fuel pressure, both were good. I read everything I could here and went over to the bus side of the forums where the was a lot of discussion on temp sensors for similar problems. $32 and one cylinder head temp sensor later the squareback is back in business!
Thanks again for all your help here. |
Posted: Mon Nov 25, 2019 12:46 pm Post subject: Re: Fuel injection relief here! |
JoMoSqBk wrote: |
Glad to hear you fixed your problem. It's also why in this forum we don't suggest taking your car to a mechanic, but rather fix it yourself. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Clyde Maddox Samba Member
Joined: January 09, 2005 Posts: 31 Location: Athens, Ga.
Posted: Mon Jan 20, 2020 9:53 am Post subject: Re: Fuel injection relief here! |
I have a 70 automatic that was running fine a few days ago. Now it shoots fuel out the muffler. Fuel pressure is 28 psi, and holds when engine is off, which tells me the injectors are not leaking.
There was gas in the oil.
I have fresh oil in now.
Is there a way to bench test the pressure sensor? Am I looking in the right direction? |
Posted: Mon Jan 20, 2020 3:45 pm Post subject: Re: Fuel injection relief here! |
Clyde Maddox wrote: |
Yes, pull a vacuum on it where the hose attaches. See if it'll hold vacuum. If it doesn't, then you either have a leaking diaphragm, or a leaking "O" ring, or both. Using an ohm meter, check the reading on the outer pins of the plug, and then the inner pins on the plug. You should get 2 readings. The outer reading should be 300+, and the inner reading should be about 90 ohms.
Does the engine hold 28 psi fuel pressure when running? How long does it take to start dropping? In a half hour you should have 20 psi, do you?
As far as gas in the oil, it might have been a system bleed down after shut off. All it takes is 1 injector to do that.
As for the right direction, yes. But also check everything else related to the FI, like the cylinder head temp sensor (should be around 2200 ohms cold (can be more) and 150 hot), and the IAD temp sensor should be 100 ohms. You can also pull the ECU, and unplug the big connector from it and measure out the wires. I think Tram posted up the values and numbers of the wires to what they go to on the 1st page of this thread.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Jan 20, 2020 4:01 pm Post subject: Re: Fuel injection relief here! |
Thanks for your reply!
MPS vacuum goes from 20 down to 15 in 2 1/2 minutes.
It measures at 90 ohms and 345 ohms.
Cyl head temp reads 3.656 ohms cold?
IAD temp sensor is 400 ohms. |
Posted: Sat Jan 25, 2020 5:59 pm Post subject: Re: Fuel injection relief here! |
Update:
Wire harness checked out good. Voltage was low. I replaced the voltage regulator and the flooding stopped. Found one injector leaking at the plug. Replaced with a good used one. Thanks for this thread! |
Posted: Sat Jan 25, 2020 8:03 pm Post subject: Re: Fuel injection relief here! |
Congrats on fixing it. As we mentioned above, you're the best mechanic for it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1957 Location: Manitowoc, WI
Posted: Sat Mar 21, 2020 2:58 pm Post subject: Re: Fuel injection relief here! |
Ceckert64 wrote: |
I’m struggling to get my 70 Squareback running after 44 years of sitting. The pump relay I know is bad so I have been hooking it up to a battery. That works, I fixed the issue with spark and now I’m finally getting it, the engine turns over well, I put starting fluid in it and it sound like one cylinder might be firing ever few rotations, ideas? I will check firing order too. |
Check your build thread, as I replied to your questions there, and gave you a few things to check over. I missed ohming out the cylinder head temp sensor though, and you'll need to check. It has to be hooked up (plugged in), or the ECU won't give it any fuel. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
roman_dolan Samba Member
Posted: Tue May 19, 2020 1:53 pm Post subject: Re: Fuel injection relief here! |
Looking for help with this part and where it goes.
Bought with a bunch of FI parts and hoping to put in my car that has dual carbs but was originally FI.
Any one recognise it?
KTPhil Samba Member
Posted: Tue May 19, 2020 1:59 pm Post subject: Re: Fuel injection relief here! |
Never seen that part, and the connector pins look like no other VW connectors. Looks like some sort of relay. Maybe a PO replaced an OEM relay with this one at some point? Look under the back seat where several Type 3 relays live. |
Posted: Wed May 20, 2020 7:02 am Post subject: Re: Fuel injection relief here! |
Yes looks like a relay, funny thing is I got a box that had 2 type 3 FI systems in and also 2 of these, |
KTPhil Samba Member
Posted: Wed May 20, 2020 9:44 am Post subject: Re: Fuel injection relief here! |
I'll date myself, but that connector base looks like an old vacuum tube pinout! |
