PDXpaulie Samba Member
Joined: October 13, 2004 Posts: 63 Location: Lake Oswego, Oregon
Posted: Thu Dec 21, 2006 6:59 pm Post subject: windshield fogging bad. Ideas? Questions. |
First, its really wet here in the PacNW, though it was dry today. During the historic rains last Thursday, I was unable to control the fog on my windshield without constantly working a squeegee. I discovered along the way that the fog wasn't wiping off, even when I switched to cloth. Scary. Pulled off and freaked out a bit.
Anyway, I figure my windshield is separating (perma-fog around the edges), so there's a replacement need. Leads me to question 1... Anyone have a reliable source for a reasonably priced new windshield in the Portland OR area?
This all started when I kicked on the Atwood blower (yeah, I know its a patch, that's part of this point) and it blew steam onto my windshield forcing the squeegee into my hand. Obviously, the bilge-blower thing was supposed to improve the _dry_ air flow into my wind screen not quicken the fogging rate.
So, I got the last bits of what I believe I need to return-to-stock the rear end (FIF) of the heating system after the PO butchery. The last bits are the heat vent tubes that run between the heat exchangers and the flapper boxes. It is my hope that replacing the type4 tubes with type2 tubes will eliminate the leaks.
Please point out where my thinking has gone astray. I have read testimony from folks that say that the stock system, when sealed properly will actually produce sufficient force of air to defrost a windshield. Is this really true? I mean, I understand that if I get the heat working right, (capturing all the heat) it will melt my blower, but will it really clear my windshield? If not, I'll be needing something to boost the output. Hi-temp tolerant ideas welcome.
Semi-related, is there a diagram out there somewhere that illustrates the fresh air routing at the front of the bus? _________________ 1972 Westy (hapy):
engine: ALH TDI - in process
suspension: KONI shocks, upgraded front swaybar, new ball joints
other: '79 westy interior (orig front seats). |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9155 Location: Syracuse, NY
Posted: Thu Dec 21, 2006 7:30 pm Post subject: |
My '74 Riviera has a fairly leaky system, from the heat exchangers right up to the heat tube....and she isn't exactly air tight either, but t produces enough heat to not only keep the windsheild defrosted, but enough to actually warm the inside of the Bus on a longer trip. If I could get just the small leaks I have sealed up and insulate the heat tube, I bet I could almost double the temp of the outcoming air. The stock heat system works just fine. |
ChiTwnVW Samba Member
Joined: November 18, 2004 Posts: 1174 Location: Home. Sweat home.
Posted: Thu Dec 21, 2006 8:28 pm Post subject: |
I second that. I don't have an air tight system, but it heats the interior 20 to 30 degrees warmer than the outside and clears the windshield. |
IFBwax Samba Member
Joined: April 05, 2005 Posts: 1325 Location: Beaverton, Oregon
Posted: Thu Dec 21, 2006 8:38 pm Post subject: |
Hey Paulie.. yeah both my buses heat enough to keep the windshield fog free, though sometimes it takes a while. Sometimes I open up the windwing just a tad to blow the fog off the windshield.
Call Tom's autobody to ask him where you could get a new windshield installed. He's a good guy who redid my green bus.
503 774 1756. _________________ Owner of: "The Party Pickle" (a 1979 2 Liter FI "Raby Camper Special" Sage Green Westy Campmobile) & "Charlie Brown" (a 1979 2 Liter FI "Rob Grant Rebuild" Agate Brown/Dakota Beige Station Wagon)
www.partypickle.blogspot.com |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52725 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Dec 21, 2006 8:39 pm Post subject: |
The stock heater can keep up with most fogging situations.
It sounds like your bus has some major water leaks making the interior too moist and humid. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
barefootwestie Samba Member
Joined: September 19, 2005 Posts: 1551 Location: Johns Island, SC
Posted: Thu Dec 21, 2006 8:59 pm Post subject: |
Until you get the problem solved, you can purchase a product called AntiFog, I think, from your local discount or auto store. It is made by Rain-X and I have used it before. _________________ My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Thu Dec 21, 2006 9:31 pm Post subject: |
lstoudenmire wrote: |
Until you get the problem solved, you can purchase a product called AntiFog, I think, from your local discount or auto store. It is made by Rain-X and I have used it before. |
I will second that, I have used this sucessfully in several acvw's I've owned. Windex has a similar product available, designed to keep bathroom mirrors from fogging.  _________________ www.zwerks.ca |
Blaubus Samba Member
Posted: Fri Dec 22, 2006 10:37 am Post subject: |
anti fogs are made with silicone, so be sure you dont have plans to put your bus interior soon |
Posted: Fri Dec 22, 2006 10:44 am Post subject: |
thanks for all the replies.
Regarding the moisture, yeah, I need a new rear hatch seal, and the drivers door plastic was just replaced a couple of weeks ago. I may have botched that. The interior is dry except the carpet near the drivers door, so I'm going to refocus on that. The bad rear hatch seal is allowing water to wick up into the rear hatch door, so I've got a problem there I need to address.
On the stock heat, thanks for the testimonies. I'm going to get the heat tubes in, and seal up the connections at the front end under the cab floor to see if I can get that kind of air volume. I must have a leak, and a pretty bad one, somewhere.
new windshield... I originally just wanted the glass. My thinking was that if I'm going to pop the windshield out, I should probably address the surface rust at the seal so it doesn't become a bigger problem. Then again, if I can pop the old glass out and fix the rust, I could have a professional outfit get the new glass in (with a new seal, of course). Has anyone tried MSGlass or those other places? I'll call Tom regardless.
Thanks again. a little validation goes a long way. _________________ 1972 Westy (hapy):
Oil Phil-M Samba Member
Joined: October 08, 2005 Posts: 543 Location: Vancouver, BC
Posted: Fri Dec 22, 2006 11:17 am Post subject: |
I've tried the anti-fog stuff before and although it kept the glass fog free it gave it a wierd distored film that was difficult to see out of especially at night in the rain so i never used it again. Pick up a squeegee (sp?) kid at the first intersection and put them to work till the hot air is flowing.
Rain-X on the outside of all of the glass OTOH is magic. Reapply at least once a month or before a road trip you can almost get by without using the wipers. |
Randy in Maine Samba Member
Posted: Fri Dec 22, 2006 12:47 pm Post subject: |
If you have the sliding slots in the front doors, having them open will improve the effiency of the defroster also. Allowing unheated air in via the blue dash levers can also help with defogging. |
Liveonjg Samba Member
Joined: March 14, 2006 Posts: 430 Location: Eugene, Oregon
Posted: Fri Dec 22, 2006 4:08 pm Post subject: |
PDXpaulie wrote: |
Regarding the moisture, yeah, I need a new rear hatch seal |
Get that one replaced right away. Get the best seal you can afford. When the rear hatch's leaky you can end up with exaust fumes in the cabin. Not very fun for anyone in the back.
Stock heat system will work great once you bring it up to speed.
-John _________________ Keep it acoustic.
77 FI 2L Westfalia - Ripple
77 FI 2L Westfalia - Althea
62 Dual Carb Single Cab - Lou |
westy78 Samba Member
Joined: August 20, 2002 Posts: 2005 Location: Portland OR
Posted: Fri Dec 22, 2006 6:21 pm Post subject: |
Paulie, give Ashley at Always V-Dub a call. He use to have a whole crate of OEM VW windshields, PPG. I got mine there about three years ago so he may not have any left by now. If I remember correctly it was about $170 for R&R of the glass including the windshield. They can also address the rust while they are there but be prepared for some sticker shock. Ashley aint exactly cheap but sometimes he has the part you need when no one else does.
http://www.always-v-dub.com/ _________________ Jasan C.
'78 Westy
VW Campmobile, it goes on vacation with you. |
Phyllis Samba Member
Joined: October 31, 2005 Posts: 773 Location: McMinnville, OR
Posted: Fri Dec 22, 2006 6:33 pm Post subject: |
The wing windows work great, and if that is not enough open up the vent located near the floor. Hey... you can always put on a coat and roll all of the windows down. That also seems to the trick. _________________ 1971 Deluxe Transporter "Winston"
1970 Westy Weekender "Cornelius"
Andrew |
Posted: Fri Dec 22, 2006 10:16 pm Post subject: |
westy78 wrote: |
Paulie, give Ashley at Always V-Dub a call. He use to have a whole crate of OEM VW windshields, PPG. I got mine there about three years ago... it was about $170 for R&R of the glass including the windshield. They can also address the rust while they are there but be prepared for some sticker shock... |
Thanks. Sent an email (after hours now). I also got a quote from Speedy Autoglass for $200 to install in my driveway with seals, 2 yr roadside guarantee, etc. Unless Always can give a really good price on the rust repair, I'll pull my glass after xmas, grind out the rust, etc and have Speedy put the new glass in next week. I just don't know what kind of glass they use, nor what kind of seals they use. If BD can get my seals out to me fast enough, I'll have that German seal at install time. So far as a glass maker goes... we'll see.
Meanwhile, I'll be searching for leaks in the heat system. Not exactly a nice simple Christmas, but it'll be worth it. Besides, my folks make me kinda nuts this time of year, so having a "bus emergency" to make some space is just fine with me  _________________ 1972 Westy (hapy):
Posted: Sat Dec 23, 2006 12:52 am Post subject: |
Your glass man should have a special primer to treat the rusted metal of the windshield frame. You might scrape off the loose rust and then let them treat the remaining rust and metal with their stuff. It will probably work as well or better than anything you can put on, especially at this time of year. |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 3185 Location: South Benfleet, Essex, UK
Posted: Sat Dec 23, 2006 6:38 am Post subject: windshield fogging bad. Ideas? Questions. |
PDXpaulie wrote: |
westy78 wrote: |
Meanwhile, I'll be searching for leaks in the heat system. Not exactly a nice simple Christmas, but it'll be worth it. Besides, my folks make me kinda nuts this time of year, so having a "bus emergency" to make some space is just fine with me  |
If you're going to replace the front windshield anyway, why not substitute an electrically-heated, front windshield (fine wire mesh, sandwiched between the two layers of glass), which I know are available for the 1968~79 VW Type 2s. There is one company in Great Britain, which advertised them recently, for as little as £150 (circa US$300), including shipping within the UK.
I shall probably retro-fit one of these electrically-heated, front windshields, to my 1973 VW "1600" Type 2 Westfalia Continental campervan, before installing my OEDES Raintracker RT-50, rain-sensing, automatic, windshield-wiper speed controller.
Regards.
Nigel A. Skeet |
Posted: Sat Dec 23, 2006 10:08 am Post subject: Re: windshield fogging bad. Ideas? Questions. |
NASkeet wrote: |
Nigel A. Skeet |
If you find any other information on these, I'm sure the forum would love to hear more. Sounds really neat, and very useful. I think of the cold mornings when the screen is all fog waiting for the warm up. Flipping a switch to get the glass clear works for me. If its a UK product, shipping would probably make them prohibitive in the states.
If I had more time, access to a media blaster and more skills, I'd really blast the rust. Since I don't have skills nor a blaster, I'll grind out what I can, Naval jelly some, and use the Eastwood Rust Encapsulator on the remaining. There's some website I saw a while back where someone documented their many attempts at perfecting their bodywork around the windshield. Looked like the only for-sure ways are welding in new steel and complete blasting to a gray color. Maybe I'll have the skills and tool access by the next time I have to do it  _________________ 1972 Westy (hapy):
nodrenim Samba Member
Joined: October 06, 2006 Posts: 843 Location: Dobson, North Carolina
Posted: Tue Dec 26, 2006 7:35 am Post subject: |
When you get the old windshield out scrape the loose rust away and paint with POR 15, great product, stops rust in it's tracks. I use a small 12 volt clamp on fan, clamped to my rear view mirror, aimed at the windshield to clear away the fog. Helps a bunch. In the summer just point fan in your direction and cool yourself! They are available at Wally World, Auto Zone, Advance Auto etc. Hope this helps! |
Posted: Fri Dec 29, 2006 7:41 am Post subject: Re: windshield fogging bad. Ideas? Questions. |
PDXpaulie wrote: |
NASkeet wrote: |
Nigel A. Skeet |
If you find any other information on these, I'm sure the forum would love to hear more. Sounds really neat, and very useful. I think of the cold mornings when the screen is all fog waiting for the warm up. Flipping a switch to get the glass clear works for me. If its a UK product, shipping would probably make them prohibitive in the states. |
For those of you, who are interested in electrically-heated, laminated windshields, here are some interesting Internet links for the 1968~79 VW Type 2 and VW Type 1 Beetle.
1968~79 VW Type 2
http://www.uroglas.com/trolleyed/100/109/112/index.htm
VW Type 1 Beetle (excluding 1303)
http://www.uroglas.com/trolleyed/100/107/110/index.htm
Uroglas - Specialist Automotive Glass Distributors
Bromsgrove Worcestershire England
Tel: 01527 577 477 Fax: 01527 576 577
Enquiries: Martin McCreedy <[email protected]>
For all export enquiries outside the UK, please telephone 00 44 1527 577477 or email [email protected] for further details.
There are other suppliers, including Beetles (UK) Ltd., but Uroglas seem to be the cheapest supplier, of electrically heated front windshields.
Regards.
Nigel A. Skeet |
