mcsyncro Samba Member
Joined: September 23, 2005 Posts: 193 Location: wherever subarus aren't
Posted: Fri Dec 22, 2006 4:57 pm Post subject: 3b |
i'm pulling the 10 valve mc code turbo engine out of my syncro and
installing a 20 valve 3b code engine out of a 91 audi 200 quattro .
way more HP, modern fuel injection, and hopfully gain a few mpg.
i guess i'll hafta be 3bsyncro now! har har . i'll keep you posted...... |
skaaudivw Samba Member
Joined: April 12, 2006 Posts: 316 Location: wesT hartford, ct
Posted: Sat Dec 23, 2006 8:38 am Post subject: |
Sweet have the 3b in my 91 200 20v. 255k miles and still purrs. Good luck with the install |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3341 Location: Talos IV, Piedmont Arizona
Posted: Sat Dec 23, 2006 9:16 am Post subject: |
who made the adapter plate and mounting bars? _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
Posted: Sat Dec 23, 2006 10:03 am Post subject: |
Bill W wrote:who made the adapter plate and mounting bars?
I built the adaptor and mounting bar myself, I'll post some photos
I wanted to make my own adaptor plate myself so I could lay the
engine over at the angle I needed to clear the engine lid. the hardest
part of the mc install was the flywheel. the stock 5 cylinder flywheel
is to big in diameter to fit in the vanagon bell housing, and the vanagon
flywheel won't bolt up to the 5 cylinder crankshaft. I got an audi 4000q
flywheel and had it machined to spec. I used the 4000q pressure plate,
and a vanagon clutch disc to match up with the vanagon input shaft.
also I used the stock syncro starter instead of the audi starter, I had
to machine the flywheel so I could put the starter ring gear, off the
vanagon flywheel, on the other side of it, because the audi starter
is on the engine side, not the tranny side. |
Posted: Sat Dec 23, 2006 10:09 am Post subject: |
I have a quantum engine thats a match for this app. Can you fill me in on the specs of your plate and bars? _________________ LEARN TO SELF RESCUE
Posted: Sun Jan 21, 2007 1:57 pm Post subject: |
3B is in! it actually fits better than the old MC engine, way more room in
the engine compartment without the CIS fuel distributor and fuel lines.
Also, I was able to move the intercooler to a more efficient location.
I'm so excited at the thought of 250 Lbs of torque,(with stock boost
levels), I'm almost giddy. I'll post some pics soon. |
Posted: Sun Jan 21, 2007 7:35 pm Post subject: |
it's in there! |
Posted: Sun Jan 21, 2007 7:45 pm Post subject: |
Shock and awe:please enthrall me. We must have this knowledge. Exactly how did you do ALL of it? Plate adapter,mounts...? _________________ LEARN TO SELF RESCUE
Posted: Sun Jan 21, 2007 7:46 pm Post subject: |
[img]https://www.thesamba.com/vw/gallery/pix/328593.jpg[img]
more later......................[/img] |
Posted: Sun Jan 21, 2007 7:49 pm Post subject: |
danfromsyr Samba Member
Posted: Mon Jan 22, 2007 8:34 am Post subject: |
VERRY nice engine there MC syncro..
soo why was the 167~hp 5cyl turbo too little HP?
and yes, not just to quench BillW's thirst to get his quantum 5cyl off his garage floor, but to ease my own curiosity, when you have the engine back out to fit..
please provide us some images of the adapter, as I'm still planning on DIY my own and putting this 5000 turbo engine into my own syncro project.
actually a nicely traced (posterboard) outline and bolt holes would be quite helpful.
keep us (me) updated on this 3b upgrade, I have a few 5000CS in the family, but searching for some 3b's wouldn't be unreasonable.
Dan in NY |
Posted: Mon Jan 22, 2007 9:50 am Post subject: |
Man, that's cool. Good job!!!!!
So is the engine attached to the original engine cradle along with the new cradle or is the original cradle simply in place to hold the skid plate? _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
mellow cat Samba Member
Posted: Mon Jan 22, 2007 7:41 pm Post subject: nice |
mcsyncro, I'm very curious about what your doing. I have installed every form of 5 cylinder in Vanagons except the one you doing right now. For obvious reasons I just have to know how you end up running the charged air to the intake side.??
At the moment I have a nomally aspirated 20v 5cyl in a syncro which I have been happily driving for about three years now. No issues and I love it ,short of the "no power under about 3000 rpm" issue. At any rate I am currently looking for a 3B. Becoming a hard bird to find these days as you probably know.
anyway CHEERS! for your effort and to be quite frank, I am supprised you pulled the 10v turbo out. It was such a clean install!! it looked so pretty with the red paint.
Good luck and thanks for all the photos!!
CHeers
Mellow Cat |
Posted: Sun Feb 25, 2007 9:21 pm Post subject: |
almost there, here are some photos of the progress so far. that's
a 7a intake manifold from a 91 audi coupe that i cut at the ports
and flipped around the other way. |
Posted: Sun Feb 25, 2007 9:31 pm Post subject: |
Posted: Sun Feb 25, 2007 9:49 pm Post subject: |
Posted: Sun Feb 25, 2007 10:47 pm Post subject: I gotta know |
Why the 7A manifold? I suppose the longer runners are a cool idea +hp, but it moves the throttle body way over?
Oh man I am stoked at what your doing.
More......please
MC |
Posted: Sun Feb 25, 2007 10:48 pm Post subject: I gotta know |
More......please
MC |
Benjamin Schott Samba Member
Joined: August 15, 2005 Posts: 84 Location: Jackson NH
Posted: Mon Feb 26, 2007 12:01 pm Post subject: |
I just wish I had the knowledge, I mean really. |
Posted: Mon Feb 26, 2007 5:47 pm Post subject: |
"Why the 7A manifold? I suppose the longer runners are a cool idea +hp, but it moves the throttle body way over?"
The stock 3b intake manifold was no way fitting under the engine lid.
it is way too tall, and about 3" too long, the 7a should give me some
more torque (maybe), but the good thing is, the throttle body lines
up perfectly with the stock throttle cable and the innercooler outlet.
what a bitch it was to get it at the correct angle and height though.
plus, I had to cut and reweld the water manifold so the intake
wouldn't hit it. should at least hear it run this weekend I hope! |
