BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Sun May 29, 2016 9:19 pm Post subject: Re: Front sidemarker - turn signal modification |
obnoxiousblue wrote: |
Got my hole saw!
Going at the bus tomorrow!
Does anyone know what color the two wires are I need to tie into to make the side markers flash with the turn signal? |
I believe it's Black & White and Black & Green. There should be a connector dangling behind your kick panels where you can tie into them. _________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2943 Location: East Northport, NY
Posted: Thu Jun 02, 2016 8:30 pm Post subject: Re: Front sidemarker - turn signal modification |
Finally got this done! Thanks for all the help!
Video of the markers
_________________ Mike
1964 Beetle
2001 Eurovan Camper |
chabanais Samba Member
Posted: Thu Jun 02, 2016 8:43 pm Post subject: Re: Front sidemarker - turn signal modification |
Well done, son.
I may have to do this mod... and get them to blink alternatively. _________________ "I spud therefore I yam." |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Thu Jun 02, 2016 8:58 pm Post subject: Re: Front sidemarker - turn signal modification |
Same here, i think i will also do this as i am Not a purist and totally
enjoy my 3rd brake light from gowesty as well.
way too many asswipes out there texting 24/7 _________________ V.W.owner since 1967 |
BusLightyear Samba Member
Joined: July 25, 2016 Posts: 2 Location: Copenhagen, Denmark
Posted: Mon Jul 25, 2016 4:46 am Post subject: Re: Front sidemarker - turn signal modification |
So, I know this is an old thread, but I hope some of you can help me out with some directions.
I've just imported a '77 US spec westy to Europe (Denmark). It comes equipped with side markers and US spec front lights. In order to get the bus registered in Denmark, I need to both replace the front lights to H4 and add turn signals on the side of the bus.
I thought I'd use the redundant (in Europe at least) front side markers for adding/converting into turn signals as described in this thread.
The only problem is that in Denmark we're required to:
a) drive with the front lights on all the time
b) have turn signals that are turned off when not flashing
c) have turn signals that are all in sync.
Is there any way to modify the described procedure/wirering so I'm able to reuse the frontside side markers as turn signals and at the same time fulfill the requirements as stated above?
I guess what I need is the crossfeed mod, but with the side markers being off when the front lights are on. This would mean turn signals flashing in unison and side markers being off when turn signals are not flashing. All with the front lights being on.
I'm thinking that european born vans which came with on the side turn signals must have somehow been wired up to flash in sync and stay off when not flashing, but I can't find any information about wirering anywhere.
Any help is greatly appreciated! |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Mon Jul 25, 2016 6:00 am Post subject: Re: Front sidemarker - turn signal modification |
BusLightyear wrote: |
You will need to fit EU compliant headlamps (preferably H4 or LED), with integral 4W or 5W side-light or parking-light, using the grey or grey/black or grey/red wires from the twin-filament 21/5W bulbs in the USA specification turn-signal lamps.
The turn-signal lamp with orange lens may only be used as a turn-signal lamp, but you might be able to use it as a combined front-facing turn-signal and side-facing turn-signal (i.e. side-repeater) lamp. The legality of this, will depend upon the required angular zone of visibility of the side-facing turn-signals.
There are Hella turn-signal lamps available which can be mounted on the B-pillar behind the cab doors, as fitted to Italian and Norwegian (and possibly Danish) specification 1968~79 VW Type 2s.
You might also wish to read this topic thread:
Forum Index > Bay Window Bus > 1968~79 VW Type 2, supplementary turn-signal facilitation
http://www.thesamba.com/vw/forum/viewtopic.php?t=268164
If you don't wish to drive with H4 headlamps on during daylight, you can retro-fit some accessory daytime running lights. I have some ideas for creating a factory-fitted appearance by adapting 1968~72 VW Type 2 turn-signal lamps, which is what I would like to do with my British specification, 1973 VW "1600" Type 2 Westfalia Continental campervan, so that I can drive in Europe without using headlamps during the day. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Mon Jul 25, 2016 8:30 am Post subject: Re: Front sidemarker - turn signal modification |
Since you bring it up, I would like to take the opportunity to point out that this is my photograph, and I am offering these to the community at cost:
http://www.thesamba.com/vw/classifieds/detail.php?id=1902174
I hope that it is OK to say that here.
Edit: These come with amber LED (low power) festoon bulbs, too! _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Mon Jul 25, 2016 10:24 am Post subject: Re: Front sidemarker - turn signal modification |
Thanks for clearing it up a bit!
If I were to fit new Hella turn signals on the b-post of my bus, where would I wire up the two wires? I guess one of them would be spliced to the green turn signal wire on the front turn signal but where would the other one go if I want turn signals that are off when not flashing and I have the front lights on?
And wouldn't fitting an extra set of turn signals on the side of the bus require another kind of relay for the turn signal as i guess the stock one is meant for only two in the front and two in the rear? Or is the extra two (4w?) bulbs not a problem in the circuit?
Sorry for all the questions but I have a lack of knowledge when it comes the electrics.
/ Simon |
Posted: Tue Jul 26, 2016 8:06 am Post subject: Re: Front sidemarker - turn signal modification |
/ Simon |
If I recall correctly, there is a unit with logic circuits available from Daniel Stern, which causes the side-marker lights to flash in phase with the normal turn-signals, irrespective of whether the side-lights and side-marker-lights are switched off or on.
http://danielsternlighting.com/tech/markerflash/markerflash.html
http://dastern.torque.net/Mods/DRL/DRL1.html
Live connections to the normal turn-signal lamps are green/red on one side and green/white on the other side. I cannot recall which way around they should be, so consult the VW Type 2 electrical wiring diagram.
I suspect that some of the modern electronic turn-signal flasher units are insensitive to the total wattage of flashing bulbs.
By all means mention it.
I searched for this advertisement that I had seen recently, but couldn't find it!
I had also noted the reference to the substitution of LED bulbs. _________________ Regards.
Nigel A. Skeet
Posted: Wed Jul 27, 2016 8:06 am Post subject: Re: Front sidemarker - turn signal modification |
These are the instructions in German which come with the B-pillar mounted, turn-signal lamps (Hella part No. 2BA 001 227-211:
Nigel A. Skeet
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Tue Aug 02, 2016 1:18 pm Post subject: Re: Front sidemarker - turn signal modification |
Do you already have actual lights attached to your front doors or are they just reflectors? If just reflectors then you will have to add lights as described earlier in this thread. The bulb pushes into the socket and has two wire terminals to connect wires to. The crossfeed method described in the link http://www.danielsternlighting.com/tech/markerflash/markerflash.html shows how to get side marker lights or driving lights with turn signals. If you look at the diagram for side marker lights you see that one side of the bulb is ground (or earth) and the other side is fed by the green wire of the parking lamp circuit.:
If you connect instead to the red and purple wires for the turn signals then you will have lights that are off unless the turn signal for that side is actuated, then they will flash in unison. Hope this helps. _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
Posted: Wed Aug 03, 2016 8:23 am Post subject: Re: Front sidemarker - turn signal modification |
Keep in mind Shawn, that the factory-stock, North American specification, 1973~79 VW Type 2, front side-marker lights, were incorporated into the front-panel mounted turn-signal lamps, on either side of the ventilation grille, rather than the cab-door mounted amber side-marker reflectors.
I acknowledge that it is practical to substitute rear engine-compartment, side-panel mounted, side-marker lamp bulb-holder base plates, in place of the cab-door mounted side-marker reflector base plates, in order to convert them into front side-marker lamps. _________________ Regards.
Nigel A. Skeet
Spud72 Samba Member
Posted: Fri Jul 03, 2020 2:04 pm Post subject: Re: Front sidemarker - turn signal modification |
Sorry I know that this is an old thread but it looks like the best one.
I want to make my UK late bay more visible ( also I like them ) so want to have USA front indicators on it so that they glow orange as driving lights in addition to the side lights.
Does anyone have a picture of inside the unit - is it a twin filament bulb or is the housing different with 2 bulbs, I cant find out much about 73 and later over here. If it is twin filament if anyone has a picture of the bulb holder it would be brilliant.
thanks |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Fri Jul 03, 2020 4:32 pm Post subject: Re: Front sidemarker - turn signal modification |
Ok but does the wide edge face of the lenses forward or towards the rear _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1396 Location: Dartmouth, Nova Scotia
Posted: Mon Jul 06, 2020 3:57 pm Post subject: Re: Front sidemarker - turn signal modification |
Spud72 wrote: |
Does anyone have a picture of inside the unit - is it a twin filament bulb or is the housing different with 2 bulbs, I cant find out much about 73 and later over here. |
The very first post on page one of this thread has pictures of the unit. It is a single filament bulb. It is just a rear sidemarker light which uses the orange front reflector as the cover.
14 years later, and the bulbs still work fine. _________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
Meyer wrote: |
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent? |
daves_ale Samba Member
Joined: May 15, 2004 Posts: 1044 Location: Home of Happiness, Texas
Posted: Tue Jul 07, 2020 5:49 pm Post subject: Re: Front sidemarker - turn signal modification |
I'm digging this. Booked marked and added to the list for the '78 and '71. _________________ "Beer is proof that God loves us and wishes us to be happy"- Ben
'66 Euro Beetle 1200A
'71 Single Cab
'78 Westy
'02 Jaguar XK8 convertible |
Posted: Mon Jul 13, 2020 9:40 am Post subject: Re: Front sidemarker - turn signal modification |
Spud72 wrote: |
thanks |
The only front-facing orange lights on the front of the vehicle that one may have in the UK, are flashing direction indicators. North American specification, front-indicator units with either of the two non-direction-indicator bulb filaments constantly iluminated would be illegal on a UK-registered vehicle! _________________ Regards.
Nigel A. Skeet
gbrumage Samba Member
Posted: Sun Aug 30, 2020 7:01 pm Post subject: Re: Front sidemarker - turn signal modification |
Sometimes old threads are the best threads.
I decided to follow suit as well as upgrade to LEDs.
Found some awesome waterproof red and amber that snugly fit an 11/32 hole. The center hole, without the socket is too big, so i gutted the socket and used it as a spacer. I gave each a touch of super glue.
They're built and tested but I haven't fitted them yet. The center is running the two outside are turn indicators.
