Rome Samba Member
Joined: June 02, 2004 Posts: 9638 Location: Pearl River, NY
Posted: Thu Jan 04, 2007 11:17 am Post subject: |
Thank you for the clear, sharp photos! |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Thu Jan 04, 2007 11:25 am Post subject: |
I bought the KGPR set and a set of the KGPR clips . I tossed out the original clips that were on the car - so no mixing and matching (even though they looked identical). The trim went on nicely and there are no bulges.
In area where there was the added thickness of filler, I used a 3M adhesive to glue the clip into the hole.
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Thu Jan 04, 2007 3:09 pm Post subject: |
I think I'm going to go with the KGPR pieces.
Here's a couple more shots:
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
pkane Samba Member
Joined: June 24, 2005 Posts: 284 Location: Loganville, GA
Posted: Mon Dec 31, 2007 3:19 pm Post subject: Installation |
What is the installation procedure:
1. Install the clips into the body, then slide the moulding over it
2. Insert clips into moulding and position to snap in.
It seems you would have to install clips into body, then carefully slide moulding on. Can someone please confirm for me.
Thanks, _________________ Pat Kane
71 Ghia Vert |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Mon Dec 31, 2007 3:49 pm Post subject: |
#2 is the correct way, clips in the moulding then snap onto body. _________________ It's not about the window, it's about the people.
German Folks |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Mon Dec 31, 2007 3:59 pm Post subject: |
lonotch wrote: |
#2 is the correct way, clips in the moulding then snap onto body. |
The only exception would be the original trim with metal clips - with those, you have to install the clips into the trim first, then the trim onto the car. |
Posted: Mon Dec 31, 2007 4:56 pm Post subject: |
Oops, I was thinking of another style. If they are the plastic clips, then they go on the body first, then the trim snaps on.
If using the plastic clips with the thin aluminum trim try to sand or file down the clips some or they will leave dents in the trim. _________________ It's not about the window, it's about the people.
German Folks |
pkane Samba Member
Posted: Mon Dec 31, 2007 6:38 pm Post subject: |
///Mink wrote: |
lonotch wrote: |
I am confused that is the same way lonotch suggested. BTW, I have aftermarket trim and plastic clips. The only way I can insert the plastic clips into the trim is to push the pins in about 1/2 way then slide them on. Then they seem to be expanded too much to insert into the holes in the body. Sorry to be a pest, but I already put a small scratch in my new paint. _________________ Pat Kane
71 Ghia Vert |
pkane Samba Member
Posted: Mon Dec 31, 2007 6:42 pm Post subject: |
lonotch wrote: |
If using the plastic clips with the thin aluminum trim try to sand or file down the clips some or they will leave dents in the trim. |
Thanks for the clarification. _________________ Pat Kane
71 Ghia Vert |
Posted: Mon Dec 31, 2007 6:44 pm Post subject: |
When the bodwork was done on your car primer and paint has made the hole smaller, you might need to get a file and open the holes up some to install the clips as not to put a dent in the body, but before you press the plastic clip in you should repaint the hole so the metal doesn't rust. Clip first, then press on trim, but like I said, try to file the ends some first or they will put dents in the trim. _________________ It's not about the window, it's about the people.
German Folks |
dr. no Samba Member
Joined: August 06, 2004 Posts: 578 Location: Santa Fe
Posted: Tue Jan 01, 2008 8:24 pm Post subject: |
How robust are the ISP pieces? I have the KGPR set, and they look good, but are very easy to ding. _________________ Scott
http://lungehphoto.com
'83.5 Westy s/p 1.6td JX and 4sp DK transplant--wonderful!
'86 MB 300GD
'06 MB Sprinter
'17 BMW X1
'89 Isuzu Trooper
PAST VWs:
'82 NA diesel Vanagon
'86 7-passenger Vanagon
'77 Bay
'71 Bay
'74 Things (2)
'69 Karmann Ghia (the only one I miss--in nice weather, anyway...)
'91 Fox |
51577 Samba Member
Posted: Tue Jan 01, 2008 10:05 pm Post subject: |
Ghiaddict: You make your living with Ghias. What do you use, and how close to factory does it ultimately look? |
tondemonai Samba Member
Joined: January 08, 2008 Posts: 364 Location: Memphis, TN
Posted: Fri Dec 05, 2008 5:25 pm Post subject: |
Anyone know where you can get JUST the front fender pieces for a lowlight? i have all the trim from the doors back, but it's a KGP&R kit, but it's from the wrong set. sooo I have the clips in teh fender, but no metal to go over them.
Suggestions? |
50Split Samba Member
Posted: Thu Feb 11, 2010 12:46 am Post subject: |
*Bump*
Since this is the official thread that gets recommended when searching for side trim, I would like to see more photos of said trim mounted on cars. Seems that people still ask a lot of questions regarding what to buy, stainless or aluminum? Which is better? People are buying it right? Let's see it...
Nice angles that clearly show off your trim and a description of what brand you have would help.
I have not made my purchase yet since I'm a ways off from that point, but I still haven't made my decision on which set to buy. The KGPR stuff looks a lot more original, but not as durable. The ISP stuff has a very nice shine, but the width looks to be a little too much. Seems the ISP trim would compliment a ghia with chromed wheels better? |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Posted: Thu Feb 11, 2010 1:17 am Post subject: |
Well from Thom's investigations as you say, the KGPR trim looks more like the original. As for more durable I'm not sure, once it's fitted how much wear and tear do you expect it to take in a Californian climate?
My '58 runs the og trim...never been changed so apart from the chances of a side impact they don't get knocked about a lot.
If Thom went along with the results of his investigations I think the KGPR trim looks pretty good vvvvv
_________________ John.
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Airhead Samba Member
Joined: July 14, 2004 Posts: 393 Location: Sheffield, United Kingdom
Posted: Thu Feb 11, 2010 1:49 pm Post subject: |
I also used the KGPR ones on mine
Airhead |
Posted: Thu Feb 11, 2010 3:16 pm Post subject: |
^^^^Nice^^^^ Thanks! |
51577 Samba Member
Posted: Thu Feb 11, 2010 8:00 pm Post subject: |
Am I going colour blind or does the trim look pink? |
72Ghia Samba Member
Joined: November 11, 2007 Posts: 1253 Location: Baltimore Maryland
