Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Fri Jan 05, 2007 3:01 pm Post subject: Stupid cab door handle hits stupid cargo door when open! |
Alright WTF am I doing wrong?
67 westy with pushbutton door locks. New door bumpers. The right cargo door when fully open and resting on the door bumpers contacts the cab door pushbutton and actually depresses it by about 1/8". In other words the recess on the cargo doors (intended to clear the door handle on the cab door) is not deep enough.
All the doors are aligned perfectly, the door handles are rebuilt and the door stop bumper thingies are brand new from WW and are the exact same size as the original ones removed from the bus before paint.
Is this just something VW did not think about when they went from the icepick cab door handles to the pushbutton ones?
On a Westy you really need to have the cargo door checkstrap off in order to use both of the flip-up tables.
Is this just something I am going to have to live with? |
Kombi Samba Member
Joined: August 02, 2002 Posts: 562 Location: Edmonton, AB, Canada
Posted: Fri Jan 05, 2007 3:17 pm Post subject: Re: Stupid cab door handle hits stupid cargo door when open! |
Major Woody wrote: |
Did they rub before? or you just notice now because of the fresh paint?
I ordered new bumpstops from WW and they were not the same size. They were skinnier than the ones on my bus (early 67 kombi)...
Edit: upon looking at the packaging< bumpstops look like they are from CIP and not WW...
Original bump stop vs repro
_________________ Air and Water are needed to survive,
you just can't live as long without air!
Air Riders, VW Club
Posted: Fri Jan 05, 2007 3:29 pm Post subject: |
Hi DaveM,
When we first noticed that the handle was contacting the door, we immediately thought of the wiper motor, and then the flexible brake lines. But we had just done the wiper conversion so we knew it could not be that. Then we pulled the engine to check the brake lines and found that the brake lines were covered with a sort of a "non-lubricating puddy" making it necessary to yell in order to be heard. So we packed the RGB's with tar to seal the grease in and so far no leaks! Good idea to fill the headlight switch with white lithium grease at the same time, just in case. Did you know we are totally shaved?
We think that the door may have been touching the handle before, but the old paint was so effed up that we paid no mind to it. In order for the door button not to contact the cargo door, each bumper would need to be nearly 3/4" longer. You have to hold them about an inch and a half apart in order for the parts not to contact one another.
You know how it is with shiny new paint. I am just hoping we don't have to leave the checkstrap on all the time. |
DaveM Mad Samba Scientist
Joined: June 11, 2002 Posts: 3010 Location: Dry side of Oregon
Posted: Fri Jan 05, 2007 3:37 pm Post subject: |
Cound you be missing a second bumper... such that the two bumpers touch each other? That would make up the 3/4 inch. Maybe a hole got filled? _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51131 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jan 05, 2007 4:13 pm Post subject: |
Is it a late cargo door with the recess for the handle or could it have been replaced with an early one? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Kombi Samba Member
Posted: Fri Jan 05, 2007 4:20 pm Post subject: |
EverettB wrote: |
I looked at my '67 Kombi and it does the same thing.
The paint is chipped there. |
Mine is also chipped, but I'm missing a bump stop _________________ Air and Water are needed to survive,
Air Riders, VW Club |
transportertalkman Samba Member
Posted: Fri Jan 05, 2007 4:23 pm Post subject: |
I have a customers 67 that does the same thing. I have been round and round with the problem, thinking that I could spacer the front passenger door lock so that it didn't allow the button to come out so far. It is a mystery to me as everything is original on the car. _________________ 1951 Belgium Standard
1957 Ghia coupe
1960 Double Cab
1963 Ghia convertible
1964 Westfalia SO34
1967 Riviera Camper |
Jerry J Samba Member
Joined: June 12, 2004 Posts: 1257 Location: Portland, OR
Posted: Fri Jan 05, 2007 4:32 pm Post subject: |
I'll have to check mine and get back to you. So you are totally shaved? _________________ Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab |
arthurnugen Samba Member
Joined: January 11, 2005 Posts: 3081 Location: The PNW, where "going green" means rolling with moss.
Posted: Fri Jan 05, 2007 4:49 pm Post subject: |
I just went out and checked mine on my '65. The rubber bump on the passenger door and the right cargo door hit before the handle can touch. Are the stops hitting squarely?
I won't say it, but I bet there is something you can put there to keep it from rubbing! _________________
cdennisg wrote: |
Lawyers don't deserve buses. |
zozo wrote: |
Don't worry too much. You can always trust a lawyer. |
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke! |
beetleboy58 Samba Conquestador
Posted: Fri Jan 05, 2007 4:55 pm Post subject: |
Hi DaveM,
that is hilarious!!! people wonder why i spend so much time on here...... |
Posted: Fri Jan 05, 2007 11:48 pm Post subject: |
Man the door does hit on mine. Right there in the indention for the handle. For me it's further justification to keep my old OG paint.
I can just hear those German engineers now....Scheiße Ernst! ze button es bumping ze door. Maybe if we put za strapen on zere nobody vill notice.. _________________ Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Fri Jan 05, 2007 11:51 pm Post subject: |
Jerry J wrote: |
Ditto - my original paint '66 has a mark in the paint in the indentation where the door button has hit for 40 years. Mine still has the OG bumpers on both doors, too (though the cab door mounting area is slightly dimpled). |
3 type2's Samba Member
Joined: January 01, 2004 Posts: 100 Location: Yakima WA
Posted: Sat Jan 06, 2007 12:05 am Post subject: |
When I dis-assembled my '67 door handles to clean and lubricate them years ago, there was an old very deteriorated o-ring that surrounded the lock cylinder,and prevented it from extending out so far. It met the inside of the pot-metal and also seemed to seal out water. I replaced it with a generic one and within months it had crumbled -- handle works fine, but it now contacts the cargo door before the bumpers hit. Good Luck, Jeff |
Craig Samba Member
Joined: August 09, 2004 Posts: 766 Location: Chapel Hill, NC
Posted: Sat Jan 06, 2007 6:25 am Post subject: |
The bumpers, which appear to be original, prevent mine from hitting the door indentation. However, there is a chip in the paint there where the pushbutton must have hit because of a forceful swing forward.
Craig |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Sat Jan 06, 2007 9:38 am Post subject: |
I agree, the door handle has a tar/felt o-ring to prevent dirt and water from getting inside the tumbler. If yours is missing the button will push out further. Isn't the cab door adjustable as well? Maybe the WW cab door handle seals are too thick? Maybe the cab door is tweaked from someone pulling on a locked door? The really nice '67 I had last year didn't touch, and didn't have a chip there either. |
Clara Samba Member
Posted: Sat Jan 06, 2007 12:57 pm Post subject: |
beetleboy58 wrote: |
Hi DaveM,
actually, that's just really stupid.
what a moron.
who cares if his door handle scratches his paint _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sat Jan 06, 2007 2:08 pm Post subject: |
I care, Clara. When you see the paint and bodywork that I have invested three years and more $ than I care to think about, I hope you will understand. If you are uninterested, I invite you to skip the thread. It's a good thing that not everyone finds humor in the same things, isn't it. Life would be pretty boring if that were not the case.
Thanks to the others of you who took the time to post. My door handles do have the internal o-rings; I just rebuilt them. The doors are aligned perfectly yet they still hit.
It appears this was a design thing; I will live with it. |
