VWinie Prime Samba Member
Joined: December 10, 2006 Posts: 14 Location: NE North Carolina, USA
Posted: Sun Jan 07, 2007 7:48 am Post subject: Trikes For Off-Road? |
I tried posting this a couple of days ago, but it seems to have disappeared. Probably operator error on my part....
Can street-legal VW trikes be used "off-road"? I DON'T mean hard-core stump-jumping, but some off-the-beaten-path kind of stuff?
URAL Motorcycles makes two sidecar motorcycle rigs which can engage and power the third wheel for going offroad. I was wondering if you could use a trike instead.
BTW I've also posted a similar question about dune buggies on another forum here on Samba. In the future I'd like to have SOMETHING that I could take into the boonies without buying a 20 mpg Jeep Wrangler.
Thanks in advance.
-Allan, aka VWinie Prime
N.E. North Carolina, USA
_________________ VWinie Prime: “In the environment on the planet Venus, you’d be crushed, corroded, and burned all at the same time.”
Mrs. VWinie Prime: “That sounds like a night of hot sex.”
{FWIW: She and I are divorced now, but STILL very close.} |
Ozz Samba Member
Joined: December 11, 2004 Posts: 5 Location: way over yonder
Posted: Wed Jan 17, 2007 3:57 pm Post subject: Off Road Trike |
My trike does fine off road.The wheel base is too long for aggressive off roading. it's only 840 lbs.It's alot of fun getting it airborn. _________________ Pull my finger !
dirtybug Samba Member
Joined: November 27, 2006 Posts: 247 Location: Chester County PA
Posted: Tue Jan 23, 2007 4:42 pm Post subject: |
I had a Trike a year ago and it did just fine off-road, they're wider than an atv so you cant use all the trails youd find and you gotta watch the way its built if there is too little weight on the front end it will be very difficult to steer on uneven ground. I solved that with some of the plates from a weight bench |
