Lowering the rear
srj1200
srj1200 is offline
PostPosted: Sun Sep 30, 2007 5:07 pm    Post subject: Reply with quote
Well, I made the mistake of pulling everything out and not marking anything, and I just got the pan back completely powdercoated and ready to reinstall these but not sure where to start. Shocked Any help?
gabyzvw
gabyzvw is offline
PostPosted: Wed Nov 14, 2007 9:26 pm    Post subject: Reply with quote
finally got back to this thread this is what mine looks like after two splines i marked both sides before removing and fortunatly everything went smoothly and love the stance in the rear
tumtum
tumtum is offline
PostPosted: Wed Dec 05, 2007 10:23 am    Post subject: Reply with quote
junk4cash wrote:
Will this work on a 66 Type 1 ? Seems fairly straight foward. All four parts are there to watch start to finish. I'm sure it was easier since it had already been lowered a few times but still gives you a good idea how to do it correctly.
http://www.youtube.com/watch?v=WA5jYrkwewg
hey so i just watched this video. now how similar is it for a swingaxle? is one outer spline still about two inches? and once it is already lowered, i dont have to worry about the spring plate breaking my arm right? a guy came and delivered a pizza to my house and i guess his finger got taken off by a spring plate shooting down. i dont want to do both sides and lower the car and have the back end be lower than the front. i only got adjustable beam on my ride, no drop spindles.
you know what they say about us welders, we do it in all positions, and we have deep penetration!
BYeaton
BYeaton is offline
PostPosted: Mon Dec 24, 2007 3:47 pm    Post subject: Reply with quote
So I finally got the courage and lowered the rear. i just went down one outer notch because i'm running 205/60's and I like the big/little look. It was super easy, this thread helped alot. Gras!
volkswagenut
Samba's Big Jerk
volkswagenut is offline
PostPosted: Mon Dec 24, 2007 5:44 pm    Post subject: Reply with quote
Looks good man Cool , Nice looking car you got pics of the whole thing?
We are a Republic, NOT a Democracy
BYeaton
BYeaton is offline
PostPosted: Tue Dec 25, 2007 1:09 pm    Post subject: Reply with quote
Yah man thanks, heres some I just posted towards the bottom 4th page here http://www.thesamba.com/vw/forum/viewtopic.php?t=247735&start=60
kostya.lyt
kostya.lyt is offline
PostPosted: Fri Dec 28, 2007 1:07 am    Post subject: Reply with quote
Thanks a lot for all of the helpful links! It was pretty much straight forward and I would highly recommend getting an angle finder for $10 at Home Depot, makes the jobs a whole lot easier, especially if adjusting both outer and inner splines.
kingodirtp3
kingodirtp3 is offline
PostPosted: Sat Dec 29, 2007 4:13 am    Post subject: backyard garage way Reply with quote
when i lowered mine i used a flat tip screw driver and scratched where the springplate hung with the tires off the ground, then pulled the plate off. when i put it back on i watched the scratch i made while i slowly put it on. i only went until i felt the torsion bar barely into the splines. when's it's barely in you can turn the spring plate and feel the torsion bar catching on the teeth. start where it was originally and feel the teeth as you turn it. greasing the splines helps it move alot better. 2 inside notches with the stiff KYB shocks was very nice.
fastphil
fastphil is offline
PostPosted: Wed Mar 19, 2008 4:34 pm    Post subject: extended spring plate pics Reply with quote
can someone please post pics of the extended sections for the spring plates ? Thanks
Germanpride
(O\U|U/O)
Germanpride is offline
PostPosted: Thu Mar 20, 2008 10:07 pm    Post subject: Re: extended spring plate pics Reply with quote
(O\U|U/O) Top Vw (o\UU/o)
64 W/T Standard-Rustbucket driver
vintagevolks55
vintagevolks55 is offline
PostPosted: Sun Mar 23, 2008 1:57 am    Post subject: Re: extended spring plate pics Reply with quote
Germanpride wrote:
for 2 notches, wopuld anyone of you guys recommend doing this with the spring plate extenders, or is it better to leave it, just want to see before i lower it so i can do it right, before f***ing it up you know
kennymo
kennymo is offline
PostPosted: Mon Apr 07, 2008 11:56 pm    Post subject: Reply with quote
what is the point of the extenders?
aircooledmark
aircooledmark is offline
PostPosted: Tue Apr 08, 2008 6:08 am    Post subject: Reply with quote
The lower you go, the more toe-in you will see at the rear. Extenders will reduce the toe.
kennymo
kennymo is offline
PostPosted: Tue Apr 08, 2008 11:26 am    Post subject: Reply with quote
oh ok cool thank you. do these extenders have to be made or can you buy them? also if they have to be made is there a basic way of figureing out how long you should make them?
ferfer6
ferfer6 is offline
PostPosted: Mon Apr 28, 2008 6:08 pm    Post subject: Reply with quote
I will be raising the rear of my bug soon and I was wondering if anyone had more/better luck with using the torsion bar adjusting tool? I have seen them on the Cip1.com website and other sites and mags. I don't want to take my hand off but I don't want to waste money on a useless tool. Any thoughts on the matter?
Serenity now!
dirtydeedss
dirtydeedss is offline
PostPosted: Mon Apr 28, 2008 11:31 pm    Post subject: Reply with quote
dont waste youre money, use a floor jack and a chain, or a prybar, or both Laughing
View user's profile Send private message MSN Messenger Classifieds Feedback
neonrick
neonrick is offline
PostPosted: Thu Jun 19, 2008 7:06 pm    Post subject: Reply with quote
Heres another option instead of adjusting the spring plate on the torsion bar. NOK's drop extentions. Easy install and a great stance, about 2.75 inch drop.
BYeaton
BYeaton is offline
PostPosted: Sat Jun 21, 2008 3:04 pm    Post subject: Reply with quote
Damn that's wild. Never even thought of that working. I wonder if it changes the geometry of it at all, or the ride quality? Gotta get some feedback on these things.
Mr. X
Mr. X is offline
PostPosted: Sun Jun 22, 2008 1:54 am    Post subject: Reply with quote
look here! http://www.thesamba.com/vw/forum/viewtopic.php?t=294170
Dancing
"The greatest lovers were murderers first" -ETID
'66 Bug - '03 GTI 1.8T
BoostedMini
BoostedMini is offline
PostPosted: Thu Jul 24, 2008 7:18 am    Post subject: Reply with quote
i need your opinions on this.. I have read through this post allot now and have searched some on this site for information.. But I still have aome questions..
I was thinking of buying the 1" rasie kit for th etransaxle and then setting the car down 2 clicks..
Do you think the 1" raise will help fix some of the negative camber? I for one do not care for the sqaushed look and would like to get the car back to a pretty normal tire angle...
The car is apart right now so this is the time to do the tranny raise if it would help a good bit to get it straighten out..
Opinions please..
Steve
58 Euro Beetle
Page 2 of 9
