miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Mon Oct 15, 2007 5:06 pm Post subject: UPDATED: OCT 15TH!!!! |
Got some long overdue updates for you guys who are following the story. EFI/Turbo on a budget rolls onwards at a slow pace, due to having to work overtime constantly, but despite this, I have managed to get the turbo manifold to the point where it's almost done. All it needs is some touch up work on some of the welds, and some high temp paint (maybe ceramic).
Also, I went ahead and started fabbing some of the fuel lines. -6AN lines and all the fittings to put it together cost almost $300 , so if you're on a budget, stay away! If you can't afford the nice stainless stuff, just get the rubber stuff, and make sure it's rated for fuel injection systems (~100psi range).
You can also see the intake; I fabbed it from a single 180*, 1-5/8" OD U-bend, a sheet of 22 guage mild steel, and a piece of 1/4" plate to mount the TB onto. Basically, I just cut the U-bend in half, sectioned it, and welded the 2 pieces together. Then, I measured the circumference of the intake, and the circumference of the TB, and cut a piece of the sheet steel that when wrapped into a tube, came out to the right size at both ends. After welding the tube to the intake, I cut a piece of the 1/4" stuff, and made the plate for the TB. This was the hardest part, as I only have a scroll saw (anyone got a cheap plasma cutter for sale? ).
Now all it needs is paint (possibly powder coating, if I have any money left over...)
Pretty soon, I'll be able to hack up the floor, and put the engine in, till then, I'm moving on to wiring, and getting a good harness made up.
Cheers till next update! _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
vwdmc16 Samba Member
Joined: January 12, 2006 Posts: 1734 Location: sacramento, CA
Filipe Samba Member
Posted: Mon Oct 15, 2007 7:09 pm Post subject: |
Only a question...
You will have to cut the "wall" behind the engine, right?!
The turbo header will be inside the car!!! Between the engine and the back seat...is it?!
And about the intercooler and oil cooler?! Any pic?!
Thanks,
Filipe Aguiar |
Dan10 Samba Member
Posted: Mon Oct 15, 2007 8:45 pm Post subject: |
I have a AJ SIMMS turbo kit and im looking into fuel injection. I was wondering if you have to be a blow thru system or can i just make it work with my draw thru. Just bolt a throttle body right on to the turbo and ad the CB's end castings and the megasquirt. |
Posted: Mon Oct 15, 2007 11:37 pm Post subject: |
Filipe wrote: |
Only a question...
Thanks,
Filipe Aguiar |
The header and turbo will 'pop' up from the floor behind where the seat normally would be. I will fab a new enclosure to house it all, basically just raise the entire area up a foot or two.
No pics of the oil cooler or intercooler yet, the engine is not yet in the car...patience! _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Posted: Mon Oct 15, 2007 11:45 pm Post subject: |
Dan10 wrote: |
It could be done either way, but I like multipoint better than the idea of a TBI draw thru style setup. If you go MPFI, you can mount the throttle before the turbo draw through style, or between the turbo and intake. I like having a BOV, so my throttle is between the turbo and intake. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
bpritchert87 The Idea Man
Joined: February 26, 2007 Posts: 1507 Location: Wisconsin
Posted: Tue Oct 16, 2007 6:12 am Post subject: |
might be a stupid question but can a person just use the end castings for the only Fuel injection point???? _________________ Knowledge is Power Read and Learn !!!
The Intelligence of a Man should not be measured by his age....
check out my sand rover t bug build! http://www.thesamba.com/vw/forum/viewtopic.php?t=287204 |
Posted: Tue Oct 16, 2007 7:21 am Post subject: |
bpritchert87 wrote: |
might be a stupid question but can a person just use the end castings for the only Fuel injection point???? |
Um, not sure what you mean??
If you mean just use the end castings I used for EFI as seen in the pics, than the answer is yes, that's the idea. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
66 Käfer Samba Member
Joined: November 24, 2003 Posts: 217 Location: Cooper City
Posted: Tue Oct 16, 2007 7:32 am Post subject: |
Just an observation/question, why don't you keep the intake on the front side of the shroud, like factory, that way you can still run a dog-house cooler.
Having it in the back of the shroud is neat because ll the clutter is out of the way but I'm just wondering what your reasons are.
Nice work! |
grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Tue Oct 16, 2007 7:45 am Post subject: |
miniman82 wrote: |
Next, a mockup of the engine. I decided to run the TB and turbo stuff behind the shroud, so I can close the decklid, and also so nobody can see what I have under there even if they looked.
The header and turbo will be hidden behind the firewall, the only visable parts will be the injectors and intakes.
his reasoning was in his first post _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. |
cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
Posted: Tue Oct 16, 2007 12:31 pm Post subject: |
Yeah, I forgot about that... |
Posted: Tue Oct 16, 2007 6:09 pm Post subject: |
miniman82 wrote: |
Dan10 wrote: |
It could be done either way, but I like multipoint better than the idea of a TBI draw thru style setup. If you go MPFI, you can mount the throttle before the turbo draw through style, or between the turbo and intake. I like having a BOV, so my throttle is between the turbo and intake. |
and the turbo wont need to be carbon sealed, saves some money and adds some throttle response _________________ "Fiberglass is for boats and race cars-Steel is real-fix it right the first time"-Wolff
'72 Ghia: http://i111.photobucket.com/albums/n146/vwdmc17/100_1964.jpg
'72 Honda Z600
'81 Delorean
www.EVILGENIUSRACING.com |
Posted: Wed Oct 17, 2007 12:34 am Post subject: |
vwdmc16 wrote: |
miniman82 wrote: |
Dan10 wrote: |
and the turbo wont need to be carbon sealed, saves some money and adds some throttle response |
Right! Saving money is always a good thing.
Kinda off topic, but it's my thread, so here goes!
I found a T-3 turbo in the junkyard that came from a Chrysler, and when I was removing it, I noticed that the throttle was mounted upstream of the turbo...hmmmm...I wonder if it's carbon sealed? I searched the web, but no one seems to know. It's strange they would do it that way, because it's a multipoint engine, not TBI. All the other Chrysler turbo cars I've seen were rigged up in the normal way, with the throttle downstream of the turbo. Anyone know??? _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Filipe Samba Member
Posted: Thu Oct 18, 2007 4:48 am Post subject: |
Listens, miniman...
Is it the type of combustion chamber that u will use?!
A.J. said to me that it's so nice for turbo aplications... for about 75cc
[]'s |
Migit Banned
Joined: July 09, 2004 Posts: 831 Location: Central Illinois
Posted: Thu Oct 18, 2007 5:13 am Post subject: |
Why don't you just cut out the package tray completely and reverse it? We had to do that for a 911 conversion a few years back. I'll look for some pics. _________________ Looking for a 58 euro hardtop! |
MSG Samba Member
Posted: Thu Oct 18, 2007 5:59 am Post subject: |
If that Chrysler turbo had the T/B in front of the turbo kinda a draw-thru set up and has a 3 bolt flange that bolts on to the compressor housing then it does have a carbon seal in it.
It came from the early turbo1 models I think. Same style I run on mine.
[url][/url] |
koolkarmakombi Samba Member
Posted: Thu Oct 18, 2007 6:41 pm Post subject: |
My God! That is a bathtub!
Who made those up?
Filipe wrote: |
Listens, miniman...
[]'s |
Posted: Thu Oct 18, 2007 8:52 pm Post subject: |
Filipe wrote: |
Listens, miniman...
[]'s |
Oi, Fillipe!
That is the biggest combustion chamber I've ever seen! Mine are CB 044 Magnum's, with 42X37.5 valves, and the chamber is 65cc. Combined with a .040" copperhead gasket, and flushed pistons, I get somewhere around 7.6:1 compression. It could be done like in the picture as well, just without the copperhead. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Posted: Fri Oct 19, 2007 12:13 am Post subject: |
MSG wrote: |
[url][/url] |
Sweet, I was hoping it did! I have the same one in your pic.
Can you point me to where you found this information? I'm sure it has the seal, I just need a referance so I can give advice to other people. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Filipe Samba Member
Posted: Fri Oct 19, 2007 7:47 am Post subject: |
miniman82 wrote: |
Filipe wrote: |
Listens, miniman...
[]'s |
Oi, Fillipe!
That is the biggest combustion chamber I've ever seen! Mine are CB 044 Magnum's, with 42X37.5 valves, and the chamber is 65cc. Combined with a .040" copperhead gasket, and flushed pistons, I get somewhere around 7.6:1 compression. It could be done like in the picture as well, just without the copperhead. |
Lol! You said "Oi"!!!
Are you brazilian?! hehehe
So...did you use the heads w/o modifications?! Or u made a new chamber, intake ports...did you so any work in your heads?! I guess you used it as "plug and play", right?!
I'm thinking about build a 2.1L or 2.3L T EFI engine and wanna know all about turbo heads!
Ty! |
