tlaama Samba Member
Joined: March 05, 2004 Posts: 289 Location: Sarasota ,Florida
Posted: Sun Jan 14, 2007 11:21 am Post subject: Parcel tray changes |
I think it changed and the lip was fatter in 64 but anyone know pre 64 changes? Thanks.I am trying to figure out what year trays will be correct for a 63.Thanks Tom
Moderator notes:
Screws used, according to Parts book:
M6x10 phillips head screws
Lock washers
Count varies by year, either 3 or 5 screws - see thread below for more information
5 screw example
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Sun Jan 14, 2007 12:21 pm Post subject: |
I remember that when I was restoring my 1963 camper, its tray looked the same as the trays for my 1957 bus and my two 1958 buses. |
Sweet Rides Samba Member
Joined: September 08, 2005 Posts: 465 Location: Out in the sticks. U.K
Posted: Sun Jan 14, 2007 12:46 pm Post subject: |
Changed around the same time as the speedo pod, i.e 61. If Campys 63 was the same as his 58 then the 63 had the wrong tray.
Hope this helps |
Campy Samba Member
Posted: Sun Jan 14, 2007 12:55 pm Post subject: |
What would a 1963 tray look like? |
DanM Samba Member
Joined: June 07, 2002 Posts: 1326 Location: Falls Church, VA
Posted: Sun Jan 14, 2007 1:33 pm Post subject: |
thin lip to thick lip in mid '61. the speedo pod also had a bigger cutaway for the parcel tray, and eventually became more rounded around the speedo.
somebody with progressive refinements will be able to pinpoint these dates. _________________ drive it. break it. fix it. repeat. |
bikesnbuses Samba Member
Posted: Mon Oct 15, 2007 7:07 pm Post subject: |
I havent had many 67's,and Ive never needed a parcel tray so...Is that also 67 only item?I just want to make sure Im looking for the right thing(nice pearl white parcel tray)and dont want to buy something that wont work...Thanks |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2931 Location: Fresno, Ca.
Posted: Mon Oct 15, 2007 7:33 pm Post subject: |
What year did the backside drop down. I assume it was for wiper motor clearance. Was it 65? _________________ If you`re going to do something, do it right. |
Lind Samba Member
Joined: November 06, 2000 Posts: 9900 Location: idaho
Posted: Mon Oct 15, 2007 7:45 pm Post subject: |
Bryan67 wrote: |
What year did the backside drop down. I assume it was for wiper motor clearance. Was it 65? |
I know that '66 and '67 buses take the later tray. I think that '65 takes the earlier one. _________________ .
Wanted:
Posted: Mon Oct 15, 2007 7:49 pm Post subject: |
Cool, thats what I was thinking actually. I`ve never owned a Bus newer than 64 and my Panel came to unassembled (Wiper motor out). _________________ If you`re going to do something, do it right. |
Posted: Mon Oct 15, 2007 7:54 pm Post subject: |
Thank you Lind. |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3096 Location: Alberta
Posted: Tue Oct 16, 2007 7:33 am Post subject: |
I have a June 12 61 bus with a thick lipped parcel tray and pointy speedo pod.
The tray changed from thin lip to thick lip a couple months before my bus was built, but I can't nail it down any closer than that.
Clara has an April 61 bus and I think hers is thick lip as well. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Clara Samba Member
Posted: Tue Oct 16, 2007 8:04 am Post subject: |
According to VW the pod and tray changed on April 11,1961
however, the pointy pod tray was in use later. for a few months, perhaps.
The tray was changed somewhat earlier (not sure exactly when)
Everett's 61 (8/60) DC:
April 4, 1961:
April 18, 1961:
A 63 or 65 definately takes the later tray |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4554 Location: St Charles, MO
Posted: Fri Feb 05, 2016 3:27 pm Post subject: Re: Anybody know what year the parcel tray under dash change |
Is there a FAQ thread (I couldn't spot it!) about under dash trays or "shelves"? If not, there should be! The thread ought to discuss the various year modifications to the shelves, knicknames for trays/shelves, the vinyl liners on certain models, and correct fasteners. There are probably more minutia that also needs to go here, so everyone feel free to pile on!
I think that when they changed from the "thin" lip to the "fat" lip tray in 1961 the trays were no longer held to the front of the Bus by five (5) dome-headed Phillips head machine screws. The "fat" lip trays were now held on by only three of those screws plus bolt hardware and a bracket to the steering column. Also, around 1966 ? the top edge of the vertical wall of the tray dipped down in the center of the tray approximately 27mm or so to add clearance for the late 6 volt and 12 volt cannister style wiper motors.
Come on moderators! If this isn't already a FAQ sticky, please make it so!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69696 Location: Phoenix Metro
Gordont Samba Member
Posted: Sun Sep 09, 2018 5:55 am Post subject: Re: Parcel tray changes |
Okay so my August 1960 has the pointy corners on the speedo pod but looks like a fat lipped dash tray, question is whilst it looks original should it be thin lipped?
_________________ 59 SC Ute - project
60 deluxe
62 microbus - the wifes daily drive
63 SC Ute - the work truck
68 Country Buggy |
Xevin Samba Member
Posted: Fri Nov 02, 2018 1:39 pm Post subject: Re: Parcel tray changes |
Hey there. I bought this tray as a gift for my buddies 59 panel. Looking at these pictures I’m still not sure what I have, I know a 59 used the thin lip style.
Will the later fat lip trays mount up OK to a 59? Thank you. Sorry for the horrible pictures. I can take more photos if needed
_________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Bret Young Samba Member
Joined: August 26, 2006 Posts: 756 Location: Turlock, CA
Posted: Mon Mar 02, 2020 10:37 am Post subject: Re: Parcel tray changes |
Question since this thread doesn't exactly state it:
Where all fat-lip parcel trays the same until the end of split-window production?
I just purchased a '67 project that is missing a fair amount of parts and the parcel tray is one of them. It appears that fat-lip parcel trays are the same from late 61-67?
Were they are changes to the 66-67 parcel trays to clear the different style wiper assembly?
Just wanted to confirm.
Thanks! |
Clara Samba Member
Posted: Mon Mar 02, 2020 1:31 pm Post subject: Re: Parcel tray changes |
No, not all fat lipped parcel trays are the same.
Early fat lip trays had a flat top
April 61-65: from the gallery, ignore the red arrow
66-67 fat lipped trays had a dip in the top, possibly to allow the 66-67 wiper motor to fit. Hope this pics helps. It's my 66 kombi.
Thin lipped trays were used until ~March 1961
Fat lip trays were used from ~ April 61
The notch in the speedo pod fits the parcel tray.
Here is a fat lip tray in a bus that came with a thin lip tray:
