Who sells a crank & flywheel that match?
Clyde Maddox
Clyde Maddox is offline
PostPosted: Sun Jan 14, 2007 12:03 pm    Post subject: Who sells a crank & flywheel that match? Reply with quote
I've got a pair bought from the same company which will not go together. I taper filed the holes which do not match, so they start, but it will not still mate completely. I'm now working on pulling 4 of the dowels, and leaving the ones that match the original flywheel pattern (hopefully).
Can someone please tell me of a company that will sell a set that is reamed so they match.
Ann Mezger
Ann Mezger is offline
PostPosted: Sun Jan 14, 2007 12:12 pm    Post subject: Reply with quote
Call Cranky Bob at DeMello Machine. (aka DMS)
vwracerdave
vwracerdave is offline
PostPosted: Sun Jan 14, 2007 12:24 pm    Post subject: Reply with quote
You do know that 1 of the 8 pins is slightly offset. This is called a SPG pattern. It is so the flywheel is indexed when everything has been balanced. Turn the flywheel 1 pin at a time till you find the correct match.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
efi67vw
efi67vw is offline
PostPosted: Sun Jan 14, 2007 12:25 pm    Post subject: Reply with quote
Sounds like the culprit to me.
77charger
77charger is offline
PostPosted: Sun Jan 14, 2007 12:28 pm    Post subject: Reply with quote
I bought a crankand flywheel from DPR it fit fine a lil tight but no probs.The off set can be a little tricky it only goes on one way that took me a couple turns to try and match it to the off set.
I was told by them also when i set endplay only use the 4 original dowel pins so it goes on easier and comes off easier.
Clyde Maddox
PostPosted: Sun Jan 14, 2007 2:50 pm    Post subject: Reply with quote
Thanks guys. I've heard good stuff on Berg and DPR before. The offset is not the problem, I'm a machinist by trade and am working too much overtime to be bothered with fixing someone else's mistake. I broke a 1/4-20 tap in one of the dowels and will finish getting it out on Monday. It would be more cost effective for me if they didn't put any holes in the crank at all, that way I could have simply used the flywheel as a fixture to ream the crank. Oh well, live and learn....
Thanks again for the info. DPR and DMS
nsracing
nsracing is offline
PostPosted: Sun Jan 14, 2007 5:23 pm    Post subject: Reply with quote
Why would a shop 8-dowel a flywheel without a crank attached to it?
The SPG jig is a cool tool no doubt, but unless you have the crank and flywheel mated together before drilling/reaming would be hard to match separately.
I stopped using the SPG pattern. I just use a Hartford SuperSpacer to space out the 8 dowels centering on the one original stud. I just put a matching mark so the two pieces will mate in the same position.
The beauty of it is that you can even misindex it and still match! Very Happy
Nothing like precision toolings.
jamestwo
jamestwo is offline
PostPosted: Sun Jan 14, 2007 6:35 pm    Post subject: Reply with quote
The bugpack flanged crank and flywheel are with out a doubt the finest avalable.
hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY.
vwdragracer
vwdragracer is offline
PostPosted: Sun Jan 14, 2007 8:18 pm    Post subject: Reply with quote
jamestwo wrote:
The bugpack flandged crank and flywheel are with out a doubt the finest avalable.
LOL James you crack me up sometimes
Going fast in a VW because to do so in anyything else is boring
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
jamestwo
jamestwo is offline
PostPosted: Sun Jan 14, 2007 8:25 pm    Post subject: Reply with quote
Why?
A flangd crank is the best way to secure the flywheel, rather then trying to band aid the normal setup. And face it, 8 dowel, wedgemate, weldmate all are band aids.
Oakley Diesel
Oakley Diesel is offline
PostPosted: Sun Jan 14, 2007 8:55 pm    Post subject: Reply with quote
I just love how my new scat crank and flywheel fit so well Rolling Eyes
Let my name be Feared at the gates of Hell as I exault the Savior!!
72 Super EJ20 turbo install in progress!
04 Excursion 6.0 w/ Spartan tunes
