nerf965 Samba Member
Joined: January 09, 2006 Posts: 78 Location: Lisle, IL
Posted: Tue Jan 16, 2007 1:32 pm Post subject: Wiper switch |
What is the best way to replaced wiper switch and turn signal switch. Mine were in a box when I bought the car and I am restoring back to factory. Do i have to remove the steering column to slide trhem into place. Thanks fr the help |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Tue Jan 16, 2007 2:01 pm Post subject: |
Very easy project...
After removing the steering wheel and unplugging the wire harnesses, the switches will slide off the column (after removing the four bolts that hold them down). They come off as one piece. You may need to use the bushings between the old switches with the new ones. You'll also need to disconnect the rubber air hoses for the sprayer.
Good Luck. |
Posted: Tue Jan 16, 2007 3:27 pm Post subject: |
the problem i have the plastic wire harness to thick, which make me think it it the wrong switchs i bought one used from thing shop and one from the late great mike b. what are the part numbers that will work.
Tahnks again |
wings_n_fins Samba Member
Joined: May 02, 2006 Posts: 166 Location: Mangilao, Guam USA
Posted: Tue Jan 16, 2007 5:50 pm Post subject: |
Bucko has in his gallery a very helpful photo of the propper wiper switch wiring for when you're ready to assemble your motor. Just a helpin' hand if you need it. _________________ DAVE
'73 Thing
'07 Harley Sportster
'09 Jeep Wrangler Unlimited |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Tue Jan 16, 2007 8:20 pm Post subject: |
Thanks I was looking for that also, I am still try to get the switch down the steering wheel shaft. Plus my wiper switch switch has 6 terminals and the plug is 5. The old wipe switch had only 4 terminals.
Thanks for the help |
mattt Samba Member
Posted: Tue Jan 16, 2007 8:54 pm Post subject: |
Sounds like you have a later wiper switch with possibly some other functions. What colors are the wires on the switch you have? The 5 terminal wiper switches usually have a set of contacts to run an electric windshield washer pump. The 6 terminal one may have the possibility of having delay wipers as well. Part #s I dont know, but looking at the switch w/ wire colors, I can tell which is which. Can you put up a pic? |
Posted: Wed Jan 17, 2007 7:10 am Post subject: |
The wire colors I have are black/yellow black/gray green brown red/black.
What the po did, was take all the wires out of plastic and spliced in 3in of wire. it looks like a total hack job. I am just trying to get th wires down the tube and looks factory. Any help would be great |
