obus Samba Member
Joined: March 08, 2001 Posts: 11071 Location: just off Garden State Parkway Exit 81
Posted: Fri Jan 19, 2007 7:15 pm Post subject: |
Thanks again guys! I'm a stay-at-home-dad so you would think that I would have LOTS of time to get this thing on the road, huh? WRONG!!!
It's very difficult to get things like done sometimes but it will get done. I will be sure to keep updating as things progress.
Although many of the major things are done, quite few time consuming things still need to be done. The engine cradle and post turbo exhaust are next. Those two things kind of have to coincide since they both try to take up the same space on the drivers side. Then it will be on to the gauge cluster. After that there isn't anything else I can do without pullling the van in a ripping out the old, tired 1.9.
As far as the header, yes, it will be coated.
Hey Bryan, is that you? You know, "Bryan" from the other site? If so, it's good to see you here. How are things with your conversion?
Eric, a TURBO T3 get together would be really cool. It is amazing how many of them are running around in the NW. Your first WRX Vanagon is what prompted me to do mine. My van is kind of a turd body wise but hey, it looks less conspicuous that way, huh? _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
ToddWESTY Samba Member
Joined: November 01, 2006 Posts: 18 Location: Playa Del Rey
Posted: Fri Jan 19, 2007 7:16 pm Post subject: Excellent |
I have seen countless "previous owner did it" engine conversions in my life time, and almost always they are a freaking nightmare to deal with. Your commitment to doing it "right" ought to be required viewing for all considering such an endeavor.
Keep up the good work! _________________ GO WEST |
thumpergti84 Samba Member
Joined: October 20, 2004 Posts: 222 Location: Wisconsin
Posted: Fri Jan 19, 2007 7:42 pm Post subject: |
Amazing |
klepic Samba Member
Joined: February 05, 2004 Posts: 61 Location: Snohomish, WA
Posted: Fri Feb 16, 2007 4:57 pm Post subject: |
Loogy is crazy! I've known him for a large portion of my life and has always surpirsed me in what he thinks of.
He's the one who pushed me over the edge when it comes to cars. And thanks to him, I have a cut up Chopped Beetle that sits in my garage!
I BOW TO YOU!
fuzzymath Samba Member
Posted: Fri Feb 16, 2007 7:19 pm Post subject: |
Hmmm... I know I'm crazy, but I distinctly remember on this thread seeing pics of a custom fire extinguisher holder that Loogy had fabbed up. Where did they go? _________________ Note to self: Finish your projects. |
Crankey Samba Member
Posted: Fri Feb 16, 2007 7:30 pm Post subject: |
are you shure your not thinking about the project over on the Vortex ? I know that guy has shots of a fire extinguisher mounted on the seat pod. |
Posted: Sat Feb 17, 2007 2:44 pm Post subject: |
I was kidding about the fire extinguisher holder. Loogy had fabbed up a SS muffler mount but now the pics are gone. _________________ Note to self: Finish your projects. |
Posted: Thu Feb 22, 2007 2:39 pm Post subject: |
Looks like we lost a bunch of stuff in the crash. Here are the lost photos plus some new ones.
Muffler mount:
Post turbo exhaust. All stainless:
The exhaust still needs the welding finished. It's just tacked for now. The reason that I am waiting to weld it is because I have made a change to my plan. I have decided to run an RJES ( http://www.rjes.com/ ) bellhousing instead. This will change the length just slightly due to the elimination of the adapter.
My reasons are twofold. Nothing against the people who manufacture the adapters but RJES' bellhousing is a much better solution from an engineering and strength standpoint. The RJES bellhousing allows me to use the stock Subaru flywheel, pressure plate and starter. Which brings me to my biggest reason for changing from the adapter - the clutch!
The Subaru Sti uses a 240mm clutch set-up which is quite a bit larger than the stock Vangon's 228mm clutch. In the future, I plan on steadily increasing the power output of my engine to hopefully fulfill my goal of having a 400whp (450-475hp at the crank) Vanagon. I need the clutch to be able to support that much power. There are 228mm clutches out there that can support that kind of power but they are nowhere near street friendly. Because I can use the Subaru based clutch components, I will have a much wider selection of pressure plates and flywheels. The clutch disk will be a custom piece that RJES supplies.
If a person was using a normally aspirated Subaru engine, the RJES bellhousing provides the same ability to use the stock Subaru flywheel, pressure plate and starter. The non STi Subarus use a 225 or 230mm clutch. The stock VW 228mm clutch disk works with either of these and street friendy heavy duty 228mm VW clutch disks are available through the aftermarket.
I just ordered the bellhousing on Tuesday. I'll post some pictures of it when it arrives. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
24inchstance Samba Member
Joined: March 01, 2005 Posts: 133 Location: Santa Cruz, Ca
Posted: Thu Feb 22, 2007 3:53 pm Post subject: |
that thing is looking pissed! hOLY CRAP MAN. Nice work. |
ProvoCyclist Samba Member
Joined: December 07, 2004 Posts: 593 Location: Murray, Utah
Posted: Thu Feb 22, 2007 4:10 pm Post subject: |
Oh damn! And 400+ horsepower! So hot! _________________ Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Flash Silver LP7Y.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A |
Krautwagen Samba Member
Joined: March 30, 2004 Posts: 81 Location: Lakewood, CO
Posted: Thu Feb 22, 2007 4:18 pm Post subject: |
I can't get this stupid look off my face loogy! You and Eric D. (check out the www.vwvortex.com in the Vans/Transporters section) have totally made my simple 2.2L subaru conversion look like a drop in the bucket.
Nice work, keep the pictures and progress shots coming. I love this stuff! _________________ Andy
Lakewood, CO
1973 Type 1 Bug
1974 Type 1 Bug
1999 Eurovan MV
picklestein Samba Member
Posted: Thu Feb 22, 2007 4:28 pm Post subject: |
I'm sorry if this was already covered, but what year/model are you putting this thing in? Incredi! |
rs4-380 Samba Member
Posted: Thu Feb 22, 2007 5:16 pm Post subject: |
you've taken care of getting the power to the transmission, but how are you planning on getting the power through the transmission? (boom?) _________________ Dave
87 EJ25 Syncro GL |
Posted: Thu Feb 22, 2007 6:33 pm Post subject: |
Is that going to take the muffin for the "World's Fastest Vanagon"? Definitely in the running.
Go big or go home.... I think I hear my mama callin'. _________________ Note to self: Finish your projects. |
Waldemar Sikorski Samba Member
Posted: Thu Feb 22, 2007 7:09 pm Post subject: |
rs4-380 wrote: |
you've taken care of getting the power to the transmission, but how are you planning on getting the power through the transmission? (boom?) |
I think that a UN-1 from Denmark is on it's way. |
Posted: Thu Feb 22, 2007 9:03 pm Post subject: |
That loop around the axle is something special. _________________ Note to self: Finish your projects. |
Posted: Thu Feb 22, 2007 9:55 pm Post subject: |
klepic wrote: |
Loogy is crazy! |
Look who's talkin'!
picklestein wrote: |
It's going into my '84 turd daily driver.
rs4-380 wrote: |
The plan is to run a European 5 speed with a Peloquin diff. and a 4.14 r&p from Europe. With uprated 3rd and 4th, the TB diff. and the stronger r&p, it should survive just fine. I'm usually pretty easy on trannies, no side stepping the clutch, smooth shifts, etc, so I'm not too worried about it.
fuzzymath wrote: |
That loop around the axle is something special. |
Yeah, it's kind of sexy lookin', in a mechanical sort of way, huh?
I didn't want the exhaust to have to make a super sharp turn right after the turbo so going around the axle was a good alternative. Plus, I kind of like the way it looks (like anybody will be able to see it once it's installed).
Anybody want to buy a new adapter with a stage II Kennedy pressure plate?
Petervw Samba Member
Joined: July 04, 2005 Posts: 1020 Location: Sarnia Ont. Canada
Posted: Fri Feb 23, 2007 6:13 am Post subject: |
340-700 HP..just in case anybody hasn't seen this site www.xcceleration.com ...makes for an interesting read |
Posted: Fri Feb 23, 2007 9:16 am Post subject: |
loogy wrote: |
pm sent _________________ Note to self: Finish your projects. |
