VW exterior mirror-best way to get hinge stud out
mcvwbugs
mcvwbugs is offline
PostPosted: Fri Jan 19, 2007 6:49 pm    Post subject: VW exterior mirror-best way to get hinge stud out Reply with quote
My '55 never had a exterior side mirror. My question is how to extract the hinge stud without damage to car. What are the current types of mirror I should consider.
RareAir
RareAir is offline
PostPosted: Fri Jan 19, 2007 7:30 pm    Post subject: Reply with quote
Mounting a set of Albert Swan neck mirrors will do away with the need for hinge pins.
But if you want mirrors at the hinge, you'll need to drive the current pin out with an impact hammer or a mini sledge (atleast a 10lb model)
I'd recommend soaking the hinge area with some PB Blaster or Kroil to help loosen the pin. When you open the door, there's a lubricating point in the hinge that often goes ignored. Spray some lubricant in there. Lubricate a few times per day for 3-5 days.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
IN2VWS
IN2VWS is offline
PostPosted: Fri Jan 19, 2007 8:51 pm    Post subject: Reply with quote
There was some special tools to do the job
coad Premium Member
Samba Scapegoat
coad is offline
PostPosted: Fri Jan 19, 2007 9:04 pm    Post subject: Reply with quote
Understand that no matter how careful you are the odds are you'll screw your paint doing it.
bmtx
bmtx is offline
PostPosted: Fri Jan 19, 2007 9:12 pm    Post subject: Reply with quote
Tape some cardboard to the door to protect it the best you can, maybe an old towel for cushion as well.
bigways
bigways is offline
PostPosted: Fri Jan 19, 2007 9:42 pm    Post subject: Reply with quote
Those are a pain in the ass.... Use a hammer and a steel punch.
Mr. Loaf
Mr. Loaf is offline
PostPosted: Sat Jan 20, 2007 3:44 am    Post subject: WWest Reply with quote
Wolfburg West has an excellent "how to" article on how to remove and reinstall hinge pins on VW doors. They also sell the pins and the reamer that you will need to do the job correctly.
Never drive faster than your Angel can fly
$24,100 was too hard to resist.................
RareAir
RareAir is offline
PostPosted: Sat Jan 20, 2007 8:15 am    Post subject: Reply with quote
That's great. Is that tool still available off the shelf somewhere?
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
billb
billb is offline
PostPosted: Sat Jan 20, 2007 9:58 am    Post subject: Reply with quote
Some links that might help
http://www.wolfsburgwest.com/wired/HP.htm
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=HPREAMER1
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=HPREAMER2
http://www.sears.com/sr/javasr/product.do?cat=Mech...Cookie=Yes
http://www.eastwoodco.com/jump.jsp?itemID=1689&itemType=PRODUCT
Bruce
Bruce is offline
PostPosted: Sat Jan 20, 2007 2:47 pm    Post subject: Reply with quote
I first taped a shop rag to the door below the hinge to protect the paint. Then I taped a sheet of steel over top of the cloth. Hammer away, you won't ding the door panel. It is best to support the hinge so that the hinge itself does not take all the impact. If you hit it too hard, you can actually move the hinge relative to the door.
IN2VWS
IN2VWS is offline
PostPosted: Sat Jan 20, 2007 3:20 pm    Post subject: Reply with quote
I found mine at an old VW dealership.
If someone repopped these I think they will sell heaps of them.
I have seen 2 versions of them. The one pictured is a casting, and another that is fabricated from several pieces and welded together.
johnshenry
johnshenry is offline
PostPosted: Mon Jan 22, 2007 11:16 am    Post subject: Reply with quote
Here's mine:
If you have the right bit, taking the doors off is a breeze. This allows you to flip it upside down, prop the hinge on the edge of a surface and drive the pin down.
If you have air, these impact guns are not expensive. The only way to do it IMO.
See the "Doors" article at my website thebugshop.org for more info on hinge pins.
John Henry
'57 Deluxe
'56 Single Cab
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Mon Jan 22, 2007 12:45 pm    Post subject: Reply with quote
A lot of door pins are not gonna be moved by an air hammer. We have a middle of the range quality air hammer and 130 psi behind it. Soaked in Kroil for two weeks and also used heat. It just laughed at the air hammer but I was not laughing. Mad
johnshenry
PostPosted: Mon Jan 22, 2007 12:55 pm    Post subject: Reply with quote
I had a few that "laughed" at my cheesy dept store brand impact hammer... that is why I bought the I-R one pictured above. Thus far it is 44-0. I have yet to find anything it wouldn't budge (with no heat or oil). It has mushroomed a few drift pin tims, but never failed to drive a pin out.
If an impact hammer like that isn't going to budge a pin, I can assure you neither VW svc. tool nor sledge will either....
John Henry
'57 Deluxe
'56 Single Cab
Ninamashr
Location: City of Round Rock in the Great State of Texas
Ninamashr is offline
PostPosted: Mon Jan 22, 2007 1:22 pm    Post subject: Reply with quote
I also have an IR Impact hammer and the hinge pin I have is starting to laugh. Let's see it laugh to the 25 ton Dake hydraulic press I'm using this afternoon! Very Happy
1957 Karmann Kabriolet "Franky"
1957 Allstate trailer
Splitdog
Samba Split Personality
Splitdog is offline
PostPosted: Tue Jan 23, 2007 7:45 pm    Post subject: Reply with quote
johnshenry wrote:
Here's mine:
This is by far the best way. Ask any of the big resto guys.
CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker
Hefner
Hefner is offline
PostPosted: Sat Mar 02, 2013 2:29 am    Post subject: Reply with quote
What are the thoughts of drilling out a couple of very stubborn pins?
As for using heat THEN hammering out with a punch just how much heat is required, the paint doesn't matter the original is already gone.
Thanks, and apologies for dragging up an old thread...
1956 RHD Oval.
www.chrisgentle.com
www.customstreeter.com
