KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Tue Nov 28, 2023 12:04 pm Post subject: Alternator/pulley/nut options |
I have a dual port Bug engine in my Bus, but this probably doesn't affect my question.
I am not a fan of the chrome pulleys and nuts that seem popular, and are on my engine currently. Bearings were replaced after noticing marks on the alt body from a rubbing pulley.
I am thinking of replacing my alternator (noise issue), and I am not sure what my best options are.
- Are higher output options as reliable? Do they require a different stand or pulley? PO installed big stereo, so a larger output may be wise. I may add a second battery later, too.
- Are the chrome pulleys/nuts different sizes? They all seem to use an acorn nut and not a regular VW style nut.
Opinions and experiences to share?
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Tue Nov 28, 2023 12:38 pm Post subject: Re: Alternator/pulley/but options |
I've run the gambit with after market pullies on my 71 camper. I ended up going back to the stock set up. Most after market pully kits are aluminum and my motor would hog out the keyways on both pullies. I tried serpentine belt kits and hi-po set ups but they all would fail and I would have to check to see if the pullies were loosening up constantly. Not worth the hassle to me. I went back to all stock components. It's been trouble free ever since.
Mi dos centavos.
https://www.cbperformance.com/product-p/2164.htm
https://www.cbperformance.com/product-p/1894.htm |
Devon-Dyno-Soar118 Samba Member
Joined: August 30, 2004 Posts: 849 Location: Devon UK
Posted: Tue Nov 28, 2023 1:41 pm Post subject: Re: Alternator/pulley/but options |
Original genuine pulley is the best, ideally the one with the interlocking tabs and slots in the pulley vs just the flat edges on the hub only. Every aftermarket one I have had was total garbage and went in the bin. _________________ 71 West coast Kombi
54 Oval, 60k km from new
Daves 68 Bug Project
Rust Collector. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Tue Nov 28, 2023 8:55 pm Post subject: Re: Alternator/pulley/nut options |
What noise? We replaced the bearings. The chrome dome nut sucks. I like a good old nut. The pulley is important. They sell cheap Chinese pulleys for like $7 but I like the quality $40 ones _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Wed Nov 29, 2023 12:05 pm Post subject: Re: Alternator/pulley/nut options |
After my bus started really eating alternator pulleys - especially the aftermarket ones, usually in 200-400 miles, eating a belt at the same time, and spitting the shims out between the metal of the pulley face and the nut as bits of mangled steel that were all that stopped it just spinning ..
Also after going through a long line of Brazilian crank pulleys thinking the reason the belt was slapping around and the pulley chewing cause was the bottom pulley having all kinds of runout ..
The alternator was replaced with some new random 75A alternator.
The crank pulley was replaced with a billet aluminium pulley because the groove in that is actually round and has basically zero runout.
The top pulley was replaced with another aftermarket junk pulley, but new.
The key was peened back into the alternator pulley as the slot for the key started opening up.
And I replaced the fan. Which must have got a bit bent when a local aircooled garage put the engine foam in with the ends facing the fan : the foam did not last ...
And all is peace now. Same belt and pulleys for at least 2000 miles, dont even have to move shims. _________________ Ancient vehicles and vessels
Posted: Wed Nov 29, 2023 12:50 pm Post subject: Re: Alternator/pulley/nut options |
A mis balanced fan will certainly destroy the top pulley! Good find.
It’s also worth checking the alignment of the top and bottom pulleys. _________________ 71 West coast Kombi
Rust Collector. |
KTPhil Samba Member
Posted: Wed Nov 29, 2023 2:00 pm Post subject: Re: Alternator/pulley/nut options |
aeromech wrote: |
What noise? We replaced the bearings. The chrome dome nut sucks. I like a good old nut. The pulley is important. They sell cheap Chinese pulleys for like $7 but I like the quality $40 ones |
I don't hear it, but my engine guy thinks there is an issue.
The main issue is the tock sound you guys noticed. I believe it's gotten worse, so I'm pulling the motor and stripping it, and he can rework the long block. He suspects a wrist pin or keeper is loose or broken. But we'll find out. It seems worse when cold and at rpms up to about 3K, where it goes silent. I assume the forces balance out and the oil provided a cushion at the higher rpms, but the clearance issue at the heart is still there, so out it comes.
The alternator question is just something to look into as the engine is out. And I am not a chrome fan. So this thread is asking about alternatives. I'll pay good money for good stock German if that will fit this alternator. |
