Bern Samba Member
Joined: March 08, 2004 Posts: 152 Location: Issaquah, WA
Posted: Wed Feb 14, 2007 1:24 am Post subject: bigger tires, 2wd style... |
i've searched for quite some time and can't seem to come up with what i'm looking for, so figured i'd see if the info is out there...
basically i'm curious how big i can go on a 2wd van...currently i'm lowered, however thats gonna change, at least going to rock 85 westy springs, since it sounds like those are the tallest stock springs...or i'm thinking of going with the syncro.org lift springs... either way i'd like to go as large as possible... however i'm very much willing to go beyond those two options and lift the van, but i'm curious how much lift is needed to fit certain tires...
a buddy's syncro is rocking 225/70/16...are syncro much different that 2wd's in the clearance department?
i'm not too concerned about the slider door as i had already planned on extending the hinge to acomodate wider tires... also figured i'd be rolling fenders too...
also not concerned about power, i'll have enough of it to move the bigger rubber....
in the rear i figure shocks and trailing arm are the hurtles, while i can't do much about the trailing arm, except put in spacers, the shocks seem like the least of my troubles, changing around shock mounts won't be a big deal...
in the front not too sure of limiting factors aside from the fender itself...
so...any kind of info that anyone can glean on this would be great...
btw i'm going to be using the same benz 16" slk wheels i have now...except with bfg all terrains... forgot what the backspacing is off the top of my head...
thanks in advance! |
Mad-Max Samba Member
Joined: January 13, 2006 Posts: 384 Location: Puerto Rico
wbx Samba Member
Joined: April 11, 2005 Posts: 1254 Location: Monterey, CA
Posted: Wed Feb 14, 2007 1:07 pm Post subject: Re: bigger tires, 2wd style... |
What kind of springs do you have in there now?
-Damon _________________ '84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go. |
Bern Samba Member
Posted: Wed Feb 14, 2007 1:44 pm Post subject: |
the springs are H&Rs, the shocks need to be replaced but they're carats in the front, and i think kybs in the rear...
ya, it looks decent low, but for the last month i've really been on the fence about keeping it after i get done with the VR6 swap for it... i want/need something for camping this summer, and anything beyond a moderate dirt road is a bit too much to scramble up in its current state... a good syncro is outta my price range right now cause if i went syncro i'd want a westy.... i thought about buying a cherokee, but then i'd be driving a jeep, and i have no room for another car right now so that would be my only car and i'm not so keen on that idea... then the idea of lifting mine, even thought its 2wd, came to me, i'm not planning on mud bogging or anything too insane, i just want the clearance, and with a locker in the rear i figure i'd do ok... |
Posted: Wed Feb 14, 2007 1:54 pm Post subject: lifted 85 2wd westy |
Here is my lifted 85 2wd westy.
Have the syncro.org springs front and rear. Gave about a .25" lift (85s are the highest of the vanagons), but really leveled the van out and also made stiffer (better suited for westy).
The rims are 15x6 et30. The tires are BFG LT215-75R15.
Front shocks are silver KYB, the back shocks are white KYB.
About 18" from fender lip to ground.
My only problem is rubbing in the front under full compression (don't have the bumpstops).
I'm looking for a set of bump stops.
Love the setup.
tommy |
vwjedi Samba Member
Joined: November 29, 2005 Posts: 1463 Location: G-ville, FL - hopefully on a trail.
Posted: Wed Feb 14, 2007 8:41 pm Post subject: |
Mine is an '87 Wolfsburg edition, stock has the "carat" springs. I sourced a set of '85 Westy springs too. Swapped 'em out and installed Bilstein touring shocks, huge improvement, gained about 3" rear and 2.5" front with BFG 27x8's on stock 14" alloys. No rub, no issues.
I want to install a set of 16's too. Thinking either these Audi rims or a set MB E320 rims I have in the attic. I'll be intersted in seeing what size 16's anyone has fit under a 2wd, I guess my current set-up was too easy, so I am looking to complicate things.
_________________ 1987 Wolfsburg T25 still riding out. A bunch of other VW's passed on... |
914 mike Samba Member
Posted: Wed Feb 14, 2007 9:44 pm Post subject: |
Tommy, love the set up. Really nice. I have been on the fence about going with the BFG AT's on my 84 westy. It has 14" alloys. I didn't think 15" were possible on 2wd, but looks like it can be done afterall??
When you say rubs at full compression, does theat meen full compression of the steering rack in a tight turn on the streets or are you refering to full compression of the suspension as it articulates over uneven terrain?
Does someone make bumpstops to fix the problem or do you think they could be easily fabbed?
What are the rims off of?
Really nice rig,
Mike
84 Westy |
Posted: Thu Feb 15, 2007 6:28 am Post subject: rubbing on my 15s |
Thanks Mike. We love our westy. Unfortunately, the PO did 0 maintenance. So, she is down more than up (for now).
I believe the stock front suspension has bump stops integral with the shocks.... from my memory of looking at other vanagon front ends.
mine doesn't. Never rubs on the street. Only rubs when a heavy load and hitting either a huge bump (wheels straight rubs on the top) or when pseudo 4wheeling, and compressing the suspension with the wheels turned.
been a low priority looking for bump stops, as trying to get in-dash ac installed and has been a real bear! I'm planning on going to a junk yard to get the necessary hardware (for bump stops).
The in-dash AC is not a behr unit, but a european cooler air unit.
The rims were made in germany, apparently just for vanagons. Got them from fast forward.ca. But he has gone out of business. I think these are very similar to the ones TiiCo sells (currently out of stock).
tommy |
Bern Samba Member
Posted: Sun Feb 18, 2007 11:28 pm Post subject: |
thanks for the replies, lots of good info... i guess i'm starting to wonder how much lift i'll get vs a westy since i don't have all that extra gear in my van, although with the current plans it might get into the weight class of a westy...
i was thinking about trying to fit 225 or 235/70/16s...bigger than alot than i've seen, but not by much... how close are those 27s? coming to the rear trailing arm?
i'm getting excited at the prospect of camping in some deeper woods and higher up mountains this summer than last...
ajvoggy Samba Member
Joined: March 30, 2007 Posts: 19 Location: Red Deer AB
Posted: Fri Mar 30, 2007 5:38 pm Post subject: |
I just bought a 83 Westfalia and it has been lowered. In great shape, too. To see the lowered version goto http://s97.photobucket.com/albums/l234/cap132/ It have the Merecedes 16" SLK wheels now. Great look but a bone crunching ride. I want to raise it like vwjedi setup.. Are "carat" springs the manufacture as I need to get all the springs? Can the Syncro springs fit? Need some help here!! Thanx for the help |
Bern Samba Member
Posted: Mon Apr 02, 2007 11:48 pm Post subject: |
"carat" springs are from vanagon "carats" (a series or option kinda like GTI vs. golf).... carats springs are the lowest riding factory spring, so if you're looking to lift your ride height moderately, but not go super off road high, then those are the springs you're looking for...
if you're looking to go big you don't want carat springs...
syncro springs will fit in the rear, but not the front, the tallest factory springs are from a 85 westy....
aftermarket options are out there as well, like the syncro.org lift springs that are said to give about 1/2-1" higher lift than the 85 westy springs...
there are also option of lifting with spacers etc, but do some research as you start getting into territory of slightly more modifications to make it all work right...
hope this helps... |
