A curious question... <Spare Tire Carrier>
msinabottle
msinabottle is offline
PostPosted: Mon Feb 19, 2007 9:26 pm    Post subject: A curious question... <Spare Tire Carrier> Reply with quote
Does anyone have a good picture of the spare tire carrier for an '86 or later Vanagon?
Apparently, they added some sort of lip to the latching plate so that you could get a slightly wider or larger tire up into it, and in as much as I know where there's a good welder, it would be interesting to see what the later mod looked like and to see if I could duplicate it. Winston's new rims are a bit larger in diameter, if the wheels themselves are less wide than the older ones--although they may fit. Still, if it's EASY...
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
wbx
wbx is offline
PostPosted: Tue Feb 20, 2007 12:50 am    Post subject: Re: A curious question... <Spare Tire Carrier> Reply with quote
If you want easy, you can do what i did... simply remove the retaining bars that go on top of the wheel (using bolts as the new pivot pins for the tray), and get some webbing and buckles to hold down the new wheel. No welding required, but this was all in an effort to switch from the stock 185 series tires to my current 205 series tires. This should help with a larger diameter, as well.
As far as i know, the later model tray/top bars are a straight bolt-on swap with our earlier setups.
If you just look at how the tray attaches, you can see how it is pretty easy to lower it a bit should you need to go more drastic.
-Damon
'84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go.
CF
CF is offline
PostPosted: Tue Feb 20, 2007 5:41 am    Post subject: Reply with quote
you can buy the "up grade" tire carrier from
van cafe
fast forward.ca
or you can get the tail gate model from jerrys rack
http://www.telusplanet.net/public/gary2a/rack/vanagonrack.htm
i have the roof rack and i love it.
joetiger Premium Member
joetiger is offline
PostPosted: Tue Feb 20, 2007 11:20 am    Post subject: Reply with quote
I don't have a pic handy, but it's just a two-inch extension on the front of the carrier where the hook rests, making it sit down a bit.
I'll bet Larry has a late model carrier he'd part with...He's got enough Vanagons over there!
Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com
Mad-Max
Mad-Max is offline
PostPosted: Tue Feb 20, 2007 1:50 pm    Post subject: Reply with quote
my parts for sale
http://www.thesamba.com/vw/classifieds/detail.php?id=551409
View user's profile Send private message MSN Messenger Classifieds Feedback
msinabottle
PostPosted: Tue Feb 20, 2007 11:45 pm    Post subject: Thank You! Reply with quote
That was very nice of you, Mad-Max (May I call you Mad?) and that's a good idea about calling Larry, Joe. I suppose the obvious thing to do is to see if the new 15" rim and alloy wheel fit as things are, but the Big O tires absolutely would NOT.
I hope it wasn't too much trouble to take that shot!
Best!
elwood91
elwood91 is offline
PostPosted: Wed Feb 21, 2007 7:03 am    Post subject: Reply with quote
Bend the carrier at the hinges at the back some as well. 215/75/15 BFG also needs some grinding on the frame to fit, but smaller tires shouldn't.
Mad-Max
Mad-Max is offline
PostPosted: Wed Feb 21, 2007 7:41 am    Post subject: Reply with quote
ya no problem, i had that photo for a while.
my real name is max, i was named after mel gibson in mad max so the nick name stuck!
Laughing
my parts for sale
msinabottle
PostPosted: Wed Feb 21, 2007 1:26 pm    Post subject: Interesting Mod! Reply with quote
So essentially you extended the hook and got a longer retaining bolt with a spacer. That, too, is intriguing. Thank you, Elwood!
wbx
wbx is offline
PostPosted: Wed Feb 21, 2007 3:42 pm    Post subject: Reply with quote
msinabottle,
you never said how big of a wheel/tire you are putting in there... Are you going monster truck?
-damon
msinabottle
PostPosted: Wed Feb 21, 2007 9:22 pm    Post subject: Big O, Won't Go! Reply with quote
No, I have those huge Big O R/T's on Winston, just now. Those don't REMOTELY fit in the original carrier, but might with some minor mods. It's an issue I never solved.
I did, though, get a Vredestein Comtrac to replace the Goodyear that was in the carrier when I bought him. That tire had cracked sidewalls and scared me every time I looked at it.
I've got a 5th Audi rim from Dogpilot, but I'll probably just leave the Vredestein there. It's good enough for emergencies, and fits fine. Still, if it was EASY to fix the old tire holder to a later tire holder... And I wanted to know!
Best!
ChesterKV
ChesterKV is offline
PostPosted: Wed Feb 21, 2007 9:56 pm    Post subject: Reply with quote
15 inch South Africa steel wheel and Michelin Agilis 51 tire (205/55 R 15 I think ? whichever size retains the stock diameter) will fit in my stock '84 spare tire carrier although it's tight...........but it fits fine..
1621
1621 is offline
PostPosted: Sat Feb 24, 2007 12:27 am    Post subject: Reply with quote
Check this one out, I have a 205/65R15 comfortably nestled up there. Piece of cake to put on.
http://www.van-cafe.com/vanagonparts.jsp?pa=ip&ip=764380099
Lundy
Raynor Shine
Raynor Shine is offline
PostPosted: Sat Feb 24, 2007 8:56 am    Post subject: Reply with quote
I just put the van-cafe one on mine. Holds a BFG AT 215 75 15 on a rhein rim at 10lbs. the only gripe I have is man that tire is heavy & you have to make sure not to pinch the coolant lines.
70coupyel
70coupyel is offline
PostPosted: Sat Oct 16, 2010 10:16 pm    Post subject: Reply with quote
I'm trying to use the bolt extention for the clamshell. Most auto stores will not have the 12mmx1.5 bolt in stock. Industral hardware store is the way to go.
27x8.5x14 is what I want to fit in my clamshell. Looks like I have rail to rail clearance and I just need to drop the clamshell down about 1.5 to 2.0 inches.
TheAndante wrote:
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc.
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer
70coupyel
PostPosted: Fri Jul 12, 2013 1:59 pm    Post subject: Reply with quote
Just an update.
The extension I made is only 1'' longer.
For my spare tire size (27 x 8.5 x 15) 1-1/4 to 1-3/8 would have been better. Stock steel wheel.
70 KG Coup
83 Westy Waterboxer
greebly
greebly is offline
PostPosted: Mon Jul 25, 2016 1:02 pm    Post subject: Reply with quote
The bolt on my 91 is a M12 x 1.75mm x 50mm the replacement bolt should be 90mm long with a 35-40mm spacer to drop it 1.5".
Vanagon Nut
Vanagon Nut is offline
PostPosted: Mon Nov 28, 2016 2:49 pm    Post subject: Reply with quote
Have other users of 15" 27.6" OD tires (e.g. BFG 15" AT KO) found that the had to clearance the frame rails to fit that 15" into the OEM spare tire location? I wish I'd known of that detail before buying 15" wheels! Wink
Neil.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
spooky_net
spooky_net is offline
PostPosted: Mon Mar 20, 2017 7:30 am    Post subject: Re: A curious question... <Spare Tire Carrier> Reply with quote
All,
Along the same lines, I have my spare tire on a swing away in the back (89 syncro w/ 16" wheels). I'm converting the front spare carrier to some storage space (for the BBQ gear Smile
So I'd like to replace the bolt with something that can be turned by hand like this:
http://www.jwwinco.com/products/section8/gn5334a/index.html
Quoting greebly: "The bolt on my 91 is a M12 x 1.75mm", which I got but seems that the threading is too coarse and it won't bolt in. Comparing with the original bolt in place seems to confirm that.
This kind a blows me away as the standard threading for M12 is 1.75mm and I don't understand why one would go for a finer one (which limits options dramatically).
Anyway, Am I the only one with that set-up? If not, what the threading spacing that I should get?
Thanks,
davevickery
davevickery is offline
PostPosted: Mon Mar 20, 2017 9:52 am    Post subject: Re: A curious question... <Spare Tire Carrier> Reply with quote
spooky_net wrote:
All,
Anyway, Am I the only one with that set-up? If not, what the threading spacing that I should get? Thanks,
I thought the spare tire carrier bolt was the same thread as a lug bolt, 14x1.5
