johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Tue Feb 20, 2007 10:22 am Post subject: Split steering lock? |
Don't know much about them, bought an NOS one a while back, considering putting it on my '50.
It has the 3 position key, and the white pushbutton. Bakelite cover on the back, screw terms. Is there an older one? Seems I saw one with a toggle switch that someone was calling a split steering lock??
I think this is the one I have (from the gallery search):
Also, what mods do I need to make for this? I presume I have to make a hole in the steering column, mods to the steering shaft too?
The '50 is getting split popouts, a new interior and a telefunken radio this winter... why not a steering lock while I am at it??? _________________ John Henry
'57 Deluxe
'56 Single Cab |
Suboval Samba Member
Tempie Samba Member
Posted: Tue Feb 20, 2007 11:09 am Post subject: |
Hmmm. Doesn't look trivial, I need the steering lock sleeve (or need to make one), and it looks like that kind is for an oval anyway (per the dash used in the tech bulletin)??
Maybe not good for my '50?
So this is the split one?
Anyone have one for sale???
Anyone install one of these with the steering lock sleeve and all???? _________________ John Henry
'57 Deluxe
'56 Single Cab |
splitvws Samba Member
Posted: Tue Feb 20, 2007 12:26 pm Post subject: |
John I have the one with the toggle switch in my 50 HEB and it also has an L part number. When I installed it my steering shaft already had the tabs on it and so did my 51 only needed to cut small oval hole in the column to match the lock housing. There is a pic of mine in the gallery but I dont know how to move it.
Dave |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
splitjunkie Samba Member
Posted: Tue Feb 20, 2007 2:20 pm Post subject: |
johnshenry wrote: |
Anyone install one of these with the steering lock sleeve and all???? |
I almost bought a 51 standard years ago that had one of those with the toggle switch so I would vote for that version being correct.
Like Dave said, you might already have the sleeve on your column. My 51 has the sleeve but has never had a lock. The sleeve is brazed on.
Chris |
semaphore Samba Member
Joined: May 25, 2001 Posts: 161 Location: on the computer
Posted: Tue Feb 20, 2007 3:05 pm Post subject: |
here is my steering lock on my 51 _________________ 59' euro vert
63' samba
57' kombi
51' crotch cooler split
vw-vintage Samba Member
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Tue Feb 20, 2007 5:36 pm Post subject: |
The steering shaft has a piece welded on it that has 4 'slots'. You need to get one of these shafts.
I'll look and see if I have another. _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
Posted: Tue Feb 20, 2007 8:08 pm Post subject: |
So does anyone know when that white pushbutton style was introduced? How far past the splits was it? Would it be embarrassing to put it on my split?
I wouldn't mind finding a split one for sure, but I bet they are pretty scarce. The later one I have is NOS, very nice.
When I yank the interior later this summer, I'll look and see if I have the lock collar on my column.
Thanks for the info............! _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Sat Feb 24, 2007 6:13 pm Post subject: |
<bump>
Does anyone know when that white pushbutton style was introduced?
I still can't decide if it is too "late" to put on my '50. Some of you accessory brochure librarians have any idea when this white pushbutton style came out???? _________________ John Henry
'57 Deluxe
'56 Single Cab |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2521 Location: Australia
Posted: Sat Feb 24, 2007 7:19 pm Post subject: |
Introduced late in 1954 and was applicable for cars from chassis #575415. _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Posted: Sat Feb 24, 2007 7:34 pm Post subject: |
IN2VWS wrote: |
Introduced late in 1954 and was applicable for cars from chassis #575415. |
Thanks. Somehow I knew you would have the answer...............!!! _________________ John Henry
'57 Deluxe
'56 Single Cab |
IN2VWS Samba Member
Posted: Sat Feb 24, 2007 7:50 pm Post subject: |
I would like to retract my last statement and replace it with this one.......
I found this in a 4/1952 catalog.
http://www.in2vws.com/images//in2vws_steering_locks%200001.jpg _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Posted: Sat Feb 24, 2007 8:54 pm Post subject: |
Ok, well maybe I *will* put it in my split. So it was used in late splits I'd guess. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Tempie Samba Member
Posted: Sun Feb 25, 2007 4:12 am Post subject: |
Om my 60
the pics
Ninamashr Samba Member
Joined: October 12, 2005 Posts: 1400 Location: City of Round Rock in the Great State of Texas
Posted: Wed Sep 12, 2007 7:02 am Post subject: |
Does anybody have a pic of this lock actually installed on a bug?
I'm trying to pick between these 2 locks for my vert. _________________ 1957 Karmann Kabriolet "Franky"
1957 Allstate trailer |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Nov 17, 2017 9:15 pm Post subject: Re: Split steering lock? |
Anyone have the shear bolt length measurement for these locks? _________________ In Stereo, Where Available! |
