dirtydeedss Samba Member
Joined: November 19, 2005 Posts: 613 Location: Aldergrove BC Canada
Posted: Thu Feb 22, 2007 9:04 pm Post subject: type 4 in beetle |
im looking for some pics of type 4 engines in beetles. |
VeeDub_U Samba Member
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Fri Feb 23, 2007 4:16 pm Post subject: |
MarkM's 2275 type 4
_________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
Posted: Fri Feb 23, 2007 5:43 pm Post subject: |
In what configuration? Stock T4 or converted to T1. |
Posted: Fri Feb 23, 2007 5:48 pm Post subject: |
i was wanting too see the stock cooling system still on it. would it cool as good still? |
Volksnutt67 Samba Member
Joined: March 12, 2004 Posts: 14 Location: Airdrie,AB,Canada
Posted: Fri Feb 23, 2007 9:49 pm Post subject: |
Here is what my old Type 4 engine looks like with the original fan shroud on it in my beetle. Then the after with the type 4 911 fan shroud conversion. It runs about the same temp as far as I know.
Enjoy. |
thehecticskeptic Samba Member
Joined: December 08, 2005 Posts: 245 Location: philly, pa
Posted: Sat Feb 24, 2007 4:00 pm Post subject: |
dirtydeedss wrote: |
If you're thinking of doing the conversion go here
http://forums.aircooledtechnology.com/
I'm surprised no one's mention Jake Raby, he's the type 4 guy. You should conver to upright if going into a bug, and he markets the DTM shroud, which is expensive, but WORKS. |
Posted: Sat Feb 24, 2007 4:11 pm Post subject: |
With the lid closed. I split the lid and shifted the lower portion back about 6 inches then moulded it back to fit the body. The wing hides the shift. When open, the entire lid with the wing, tail lights and lower filler pieces, lift for easy access.
Not pretty but fully functional. Porsche 2.0 Fuel Injected. Cooling has not been an issue. Functional air intakes in front of rear wheels feed air to engine bay. I monitor engine oil temp and engine bay air temp. Engine oil runs about 190 deg F while bay temp holds to within a few deg of ambient outside temp. When parked the engine bay heats up to about 110 deg but quickly cools down when restarted.
markm Samba Member
Joined: July 21, 2003 Posts: 986 Location: Seattle, Via Beautiful El Sereno CA.
Posted: Sat Feb 24, 2007 5:57 pm Post subject: |
Skim wrote: |
MarkM's 2275 type 4
Great pic. Actually it is a 2702 type IV. dynoed at 176 horse at the wheels. Just rebuilt it with some Berg 48's and some headwork by Tim's ACVW.
Just ordered the A-1 exhaust, should be going into the car in the next week or so. |
beetleboy58 Samba Conquestador
Posted: Sat Feb 24, 2007 7:09 pm Post subject: |
markm wrote: |
Skim wrote: |
MarkM's 2275 type 4
That's the shit right there....sweeeet. |
walter kandetzki Samba Member
Joined: June 02, 2003 Posts: 918 Location: Dillwyn, VA
Posted: Mon Sep 02, 2019 6:23 pm Post subject: Re: type 4 in beetle |
didnt feel like posting a new thread but post them pictures |
