Steve22 Samba Member
Joined: March 05, 2004 Posts: 1389 Location: the wild unknown
Posted: Wed Aug 15, 2012 8:50 am Post subject: |
Just to update on the seal quality. I originally got my seals from CIP1, the inner seals (glass to frame) worked fine, but the outer seals (frame to body) broke at the seam about a week after the install I still hadn't even driven the car yet! Got a new pair of frame to body seals from WW, seems like the seam will hold, but we'll see. _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter |
vanilla_gorilla13 Samba Member
Joined: May 30, 2010 Posts: 133 Location: Hialeah, Fl
Blue69Baja Samba Member
Joined: September 04, 2008 Posts: 1065 Location: Fair Oaks
Posted: Mon Jan 28, 2013 7:22 pm Post subject: |
About a year ago I did a set for a friend... He helped me....WWMetric rubber this time.. Still perfect.... Still have to replace my Cip1's....They look awful!!!! But when someone sees them they think, well those are old rubber..... Perfect show and tell eh? Don't buy junk!
Jim _________________ 69 Baja with a 1914...
72 Super 100% orig...W/ factory air... 56,000mi
Even the spare is original.. |
broomhandle Samba Member
Joined: August 04, 2009 Posts: 122 Location: Half Moon Bay, Ca
Posted: Mon Jun 03, 2013 10:44 pm Post subject: |
I'm just about to install pop o's in my 69... The hinge part is no biggie, but the latch with the 3 holes...
Are there holes in the metal for it already? Do I need to peek behind to find the holes?
My latches are pitted pretty bad I hope I can get them to look semi ok...
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Mon Jun 03, 2013 11:25 pm Post subject: |
broomhandle wrote: |
There aren't holes, but it is dimpled. When I put pop outs in my bug, I pulled the window closed and held up the latches where they would be. I found the dimples pretty easy using my fingernail, and was able to screw the hinges on without drilling out the dimples. _________________ -Adam
'59 Mango Bus - getting buried in it
'69 Bug - sold and highly missed, so it stays in the sig |
Posted: Tue Jun 04, 2013 8:16 am Post subject: |
otis_bartleh wrote: |
There aren't holes, but it is dimpled. When I put pop outs in my bug, I pulled the window closed and held up the latches where they would be. I found the dimples pretty easy using my fingernail, and was able to screw the hinges on without drilling out the dimples. |
Ditto this. I used a sharp pick instead of a fingernail. after establishing the proximity of the latch I stuck the pick in one of the headliner holes and poked around on the metal and found the dimpled holes.
Like Otis said, "don't drill out the holes", just use the screws and an electric drill with a phillips bit.....
Posted: Tue Jun 04, 2013 8:20 am Post subject: |
You may find that the new hinges will be really difficult to make fit. I ended up using old hinges that I got with the used popouts.
Problem was that the metal plate that has the threaded holes for the hinge to attach to the window frame was not mfg'ed properly. The holes would not line up...
Posted: Wed Jun 05, 2013 11:58 am Post subject: |
Cool, thanks guys... Now I just need cooler weather, can you guys help with that?
I'm using old hinges. They are stock. But the clamps are pitted... Have to find a good way to polish |
Posted: Wed Jun 05, 2013 12:04 pm Post subject: |
Cool, thanks guys... Now I just need cooler weather, can you guys help with that? |
Sure, move out of Sac, it bakes up there! _________________ -Adam
Posted: Wed Jun 05, 2013 12:15 pm Post subject: |
Hot weather makes them easier to put on. Rubber is a lot more supple.
Here in SAC we are expected to hit 112deg on Sunday!
Warm dish soap and water work the best.
Do not use Armoral..
Posted: Wed Jun 05, 2013 12:49 pm Post subject: |
Blue69Baja wrote: |
Jim |
Yikes! And agreed on the heats effect on the seals and the dish soap... _________________ -Adam
savoy_man Samba Member
Posted: Wed Jun 26, 2013 7:45 am Post subject: |
Does anyone know the size of the screws for the hinge to body? I need to know the thread count and pitch along with the length. The used set of popouts I bought had the plate but not the screws with it. I could order the screws but I'm impatient and just want to go pick them up at the store.
Thanks |
Posted: Wed Jun 26, 2013 9:40 am Post subject: |
I'm on the road so I can not give you the screw specs.
Go down to an Ace hardware or some good one that has a great selection of screws..
Take the metal backing block with you, it has the threads for the screws.
The screws are taper head philips. You may have to get Allen's but that's ok.
The length is not critical in length, just long enough to make it all the way thought the post and the hinge hardware. If they are a little long will be ok.
Hopefully your hinge's are the old kind... I have found that some of the new hinges from some hinge kits are impossible to make work... Getting all the holes and the threaded backing block to ling up can be problematic.
Let us know how it goes.
EnerOnE Samba Member
Joined: December 10, 2011 Posts: 66 Location: Los Angeles
Fab4Fan Samba Member
Joined: June 17, 2005 Posts: 703 Location: Claremont, So-Cal
Posted: Thu Jun 27, 2013 8:03 pm Post subject: |
I think theyre aluminum. You need to remove the clear anodizing. I use oven cleaner and steel wool to remove it. then use really fine sand paper to remove scratches then use metal polish to remove the sanding scratches. _________________ -LeoDogg |
Posted: Thu Jun 27, 2013 10:21 pm Post subject: |
To be honest I havent done it on pop out frames, but ive done it on other trim, vin tags, motorcylce pieces , rc parts and wheels. Once you strip the clearcoat off you can polish it. It does start to lightly oxidize and get hazy after a while, but you just polish it up and its clean again. there are also wax sealers you can apply to have them last longer. Its just like polishing and maintaining any metal like mag wheels.
Do a google search for removing clearcoat from wheels to polish. Or removing anodizing.
If you try to sand out the scratches and buff them, that area will lose the clear anodizing and will not the match the rest of the frame. I also would remove all rubber before using chemicals.
This is just how I would do it; its worked for me on other aluminum. _________________ -LeoDogg |
Helirich Samba Member
Posted: Sun Aug 25, 2013 5:53 pm Post subject: |
Glad I found this thread. It answered most all my questions. But I do have one on installing the seal. I noticed on the frame where the hinge is it looks like you could undue the screws and pull one side out an 1/8". Then you could feed the rubber in the groove without all the pressure. Maybe I'm way off base here. Has any body tried this?
I just go my pop outs and will be installing them after I get new seals. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Aug 25, 2013 8:29 pm Post subject: |
The only downside I see is possibly stretching the inner seal just a bit- then pinching it when you retighten the screws. silicone spray and a plastic picnic knife should get the outer seal in the groove faster than trying to retighten those hoop screws IMO. _________________
EverettB wrote: |
FU#5 |
